When do you plan fixing the problem?!?!?!The Dude does not save any data after reboot on HEXgr3 neither on flash nor on the SDcard. After reboot the SD "disk1" becomes "disk2" if Dude is installed on it. If you change Dude path to "disk2" then the name of the SDcard would again becomes "disk1" after another reboot.. It is like a hell... I couldn't save any data on Dude after RB reboot.. What is it? The OS version is 6.38RC25
PS... On 6.37.1 - the same dulls
I hopefor you that is not a too much of a burden for you in your life missing a working Dude after a reboot. Mikrotik knows about this and is working or is going to work on solving this and please be patient with them.When do you plan fixing the problem?!?!?!The Dude does not save any data after reboot on HEXgr3 neither on flash nor on the SDcard. After reboot the SD "disk1" becomes "disk2" if Dude is installed on it. If you change Dude path to "disk2" then the name of the SDcard would again becomes "disk1" after another reboot.. It is like a hell... I couldn't save any data on Dude after RB reboot.. What is it? The OS version is 6.38RC25
We bought because of the possibility of launching dude, but I can not run !!!
6.38rc31 still does not fix the bug.
Your custom uploaded mibs/images/etc need to be stored in: "(data-path)/files/" directory.
You can still use Dude as syslog server. The difference is that the syslog messages will be stored under Log section.The last version with syslog is the 4b3. Not the previous like you wrote. And it is well known. Mikrotik promised to put it back somehow one day...
But after reboot you loose all the logs.. How to avoid?You can still use Dude as syslog server. The difference is that the syslog messages will be stored under Log section.
How to use national letters then? Please include Unicode fonts instead of these useless fonts...Now we see only bars instead national symbols...maxkrok - Custom fonts is not suggested. Also note, that custom files can be placed only under dude/files directory.
Read here:great...
....but where is the User Manager package ???
What do you mean with this comment?That's great.
Are you running latest version? I haven't noticed such issues with snmp setting configuration.i don't know but when i click to cnahge snmp profile on mikrotik devices all dude-client hag-up and close.
For a while no TheDude uses the same port as Winbox. It cannot no longer be changed separately from that.Since i didn't find the page where i can change the default port for dude client.
https://wiki.mikrotik.com/wiki/Manual:T ... nToNewDudeAlso it is possible to migrate from windows to mikrotik devices.
Really, beforre yealing here that anything is wrong.. be shure to read properly manual not for mikrotik but for L2 and routing properties too. I read your post twice and i really don't understand what you really want from your notebookWhy oh why is Mikrotik so utterly useless at providing documentation and instructions for new users? I have a hEX with 32GB of flash memory and The Dude server installed. The purpose is specifically to allow us to .....
How does that relate to the original post? Make a new topic if you would like to ask a different question.Nothing is "SOLVED".. When you will implement the multifile syslog facility, like for others devices? What is the problem with that for 750GR3 ?????
Correct me if I'm wrong, but DST NAT is only available in the PREROUTING chain and if process initiated locally the only available chains are OUTPUT and POSTROUTING.Make DST NAT on outgoing SMTP traffic
Yes you can! And good idea.I want to use the internal speaker of HEX s for The Dude allerts.
Is there a way to make that?
