warez
What IP Source for Dude use to monitor hosts?
Mon Oct 17, 2016 11:28 am
I have Dude on CHR. In system have severals IP Addresses
What IP address Source the Dude use to monitor hosts?
How i can setup this?
LetMeRepair
Re: What IP Source for Dude use to monitor hosts?
Thu Jan 18, 2018 10:16 pm
This some old topic, but I came across the same problem now. I need (or would like) to define the source address used for probing etc.Since there seems to have been much work going on for the Dude, is there possibly a soluton to this meanwhile?
4lex
Fri Jan 19, 2018 8:21 am
It uses own selected as a default route, but you can set preferred-src-ip, for example:
add address=8.8.8.1/32 interface=ether1 network=8.8.8.0
add address=10.1.1.1/29 interface=ether1 network=10.1.1.0
add address=172.16.1.2/24 interface=vlan100-ether1 network=172.16.1.0
add distance=1 gateway=8.8.8.2
add distance=1 dst-address=10.0.0.0/8 gateway=10.1.1.2 pref-src=10.1.1.1
add distance=1 dst-address=172.16.0.0/12 gateway=10.1.1.2 pref-src=10.1.1.1
add distance=1 dst-address=192.168.0.0/16 gateway=10.1.1.2 pref-src=10.1.1.1
So private network (10.0.0.0/8, 172....) will be pinged with src 10.1.1.1,
172.16.1.0/24 - from 172.16.1.2 - as directly connected,
all other addresses will be reachable with source ip 8.8.8.1 as default.
LetMeRepair
Fri Jan 19, 2018 1:23 pm
Thanks, that's a nice idea. So far i only used this setting when I had to manage multiple (WAN) IPs in the gateway subnet, never thought of using it this way.
Users browsing this forum: No registered users and 45 guests
