sb1349
SNMP
Fri Jan 06, 2017 4:20 am
Having an issue with more recent versions of the dude being able to read snmp on cisco and ubiquity devices. The snmp interfaces will not populate but snmp walks will show information. Devices that do not show snmp interface information.
Cisco 3560 & 2960 -- Only interface does not populate.
Ubiquity Unifi Switch -- Interface & IP tabs do not populate
Snmp is working properly and being graphed by the following devices.
RB 3011
Ubiquity Unifi AP AC
RB 912
The last version that I can tell works properly is 6.36.4. Testing with both 6.38 & 6.39.4 shows the errors with snmp.
sb1349
Re: SNMP
Sat Jan 21, 2017 3:08 pm
Would anyone know if this is a bug or if the dude is changing the way snmp is handled and not to expect third party hardware to be read properly. I manage a mixed equipment handling equipment from several vendors.
plisken
Re: SNMP
Mon Jan 23, 2017 1:32 am
You can import the oids in the dude already done, congratulations!
I can not even import the mibs in the dude.
Nowhere not find a good explanation or incomplete.
very frustrating
sb1349
Re: SNMP
Mon Jan 23, 2017 3:27 am
These have been things that have worked sense before the version 4 beta 3 days and stopped recently working.
Last time I loaded a mib I believe the way to load it was using winbox to transfer the file to the /dude/files/mibs/ directory or something similar. Once the MIB.txt file is there it is read into the system automatically and you will be able to see the mibs node tree show the newly imported data.
plisken
Re: SNMP
Mon Jan 23, 2017 8:32 am
The MIBs are indeed not to be in the directory Mib. But in the root.
I also not know the proper procedure.
Mikrotik must learn to make at to provide good and clear documentation.
PaulsMT
Re: SNMP
Mon Jan 23, 2017 12:19 pm
Did you take a look at this article:
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Files
The SNMP problem with other vendor is know, we will try to fix it. Please try latest bugfix version 6.37.4, can you repeat the SNMP issue ?
plisken
Re: SNMP
Mon Jan 23, 2017 2:06 pm
Yes and it don't works
I send now a email with supout.riff
sb1349
Re: SNMP
Mon Jan 23, 2017 3:42 pm
PaulsMT I am running 6.36.4 which is the most current version found where the interface counters are working. I am also running the latest beta version 6.39rc15 in a test environment which the counters are not running. Having 2 released non beta versions where this major feature is not working and not finding any word without digging thru many forum posts is kind of a let down.
dmitryfromchel
Re: SNMP
Mon Jan 30, 2017 6:52 am
I have the same bug after migration (export-import) form TheDUDE 4.0b3 (on Windows) to 6.38.1 (on CCR1016). SNMP shows all devices (Qnap, Windows Server, D-link, Printers Epson Xerox, RouerBoards) BUT not works with all DELL switches. We use many models: 4032f, 6224, 5548, 2048, X1052 - no one shows information on SNMP->Interfaces tab. Settings on devices are not changes.
(added) 6.37.4 works fine (on CCR1016).
plisken
Re: SNMP
Mon Jan 30, 2017 7:55 am
Indeed,dmitryfromchel, it is and always remains the same.
Mikrotik people, make the dude easier to integrate more mibs and pictures of another brand and more models from Mikrotik devices. Forgive my pronunciation. But why do only half the job. Let the mibs inporteren easier expired why only reed.Make that we can add the mibs and images in an easy way.
or immigrate more brands and models so that we do not need to waste our time. I hope'm done something about it. This can not be so difficult.
plankanater
Re: SNMP
Mon Mar 06, 2017 10:12 pm
This is also occurring with RB250GS running Dude 6.38.3
icecybe
Re: SNMP
Thu May 11, 2017 12:43 am
this is the problem with alcatel 6224 switches, that are a few hundred in my newtork :)
Also wich can be the problem when or why in old version all work's fine and here new version new board and child mistake.
It would be great to know any escape from this problem.
icecybe
Re: SNMP
Fri May 19, 2017 7:05 pm
seems to me that i buy this board only to make dude work and now i get nice piece of....board, with half working monitoring. Maybe need to do a thing from start to end :)
Users browsing this forum: No registered users and 60 guests
