I apologize as this is probably a very basic question for this forum. I am a home user and not a networking expert. Just enough to be dangerous. From what I understand, this is one of the best apps to use for network monitoring and mapping.
I have a Netgear Nighthawk X4 R7800 router. I'm not crazy about the consoles monitoring and map - it's very buggy. I've also used it's Genie app, which is a bit better, but still not that great. My network has a number of devices attached including extenders, an access point, Roku's, iPhones, kindles, a few laptops, TV's...etc.
I've installed The Dude on a Windows 10 box and keep getting a status of "Connect failed: 100061: No connection could be made because the target machine actively refused it."
I have tried the following to connect and tried each with combinations of the bullet points:
- Server, I have used the main IP of my network given to me by Netgear's console for the Remote Access Management. I have also used my router IP in the Lan/IP setup
- Mode: tried both plain and secure
- Port: I've used several, including matching the port noted on remote management
- User Name: Used admin and the user name of my router's console
- Password: blank and used the router console password
- Firewall: turned off on my box where The dude is installed.
- Netgear Remote Management: Tried on and off - also turned off the NAT firewall.
Over the last several days, I've looked through the documentation and forums but nothing has seemed to work. Feels like I'm really close but I must be missing something.
If I'm way off base, please don't waste your time writing a lengthy explanation. I don't want to waste your time if it appears this might be too advanced for me at this time. And you can tell me so - I don't get offended easily! I'm still learning from trial and error. In fact, most things I've learned about networking (and computers in general) have been from trial and error. I've spent many nights over the last 20 years reinstalling operating systems that I managed to corrupt - funny thing is that my family thinks I'm a technical genius.
Any help is greatly appreciated!
Thanks!
Eric
