DavidPicard
Ping not working on Windows 7 Ultimate 64 bits
Tue Jan 12, 2010 4:16 am
I recently upgraded my computer form Windows XP Pro 32 bits to Windows 7 Ultimate 64 bits.
I have re-installed Dude and imported the config file...
Everything is working well except that all devices are reported as down...
Firewall not activated...and SNMP pooling is working
Anyone have a solution to that issue?
Thanks in advance
David Picard
Network-Admin
Sogetel Inc
roadracer96
Forum Veteran
Forum Veteran
Re: Ping not working on Windows 7 Ultimate 64 bits
Fri Jan 15, 2010 2:12 am
I just moved my dude server to one of my 2008 x64 servers and it works fine. Is UAC disabled?
DavidPicard
Tue Jan 19, 2010 5:08 am
Thanks for the tip.
Disabling the UAC resolved my issue.
Regards
David
jma_sp
Wed Oct 06, 2010 2:10 pm
I have the same issue under Windows 7 Professional 64 bits, dude 3.6 is unable to make ping to hosts in the network. snmp works OK.
Regards.
lebowski
Wed Oct 06, 2010 5:50 pm
Did you disable UAC? Is the service running with administrator rights?
imendoza
Fri Oct 15, 2010 3:56 am
simple dude running as administrator and go with that work, as happened to me
leon84
Fri Oct 22, 2010 7:09 pm
sorry i have the same problem... what is UAC ?
lebowski
Sat Oct 23, 2010 1:41 am
GOOD GOD MAN HAVE YOU EVER HEARD OF GOOGLE.
/s (little humor for those not so inclined)
normis
Mon Oct 25, 2010 9:19 am
UAC: http://en.wikipedia.org/wiki/User_Account_Control
In other words, make sure your Windows account has administrative privileges, or simply disable all those annoying warning messages, firewalls, antiviruses etc.
viktorc
Fri May 13, 2011 12:35 pm
Disabling UAC is needed only for creating "The Dude Server" service (menu Local server -> as service).
After that, Dude can be running with UAC enabled connecting to Dude server running as service.
(Tested on Win 7 64-bit, Dude 4.0beta3).
BerKo
Mon Aug 08, 2011 12:52 pm
I also have same prob. I disable the UAC , firewall, and aLso my antivirus . But I still have prob. When I run dude server everyThing is fine. But after a while it has same prob.
Any suggestions!??!
Users browsing this forum: No registered users and 18 guests
