eben
Norification if speed on a link drops
Thu Jul 15, 2010 1:22 am
I'm monitoring a router using Dude.
SNMP ID (6) is the speed of the link.
I was wondering how I could go about setting up some sort of a notification to let me know if either the Tx or the Rx on that link was Zero (0).
In other words, I'd like to get an email or SMS (this part I know how to do) if the link were to logically go down. It often happens that the link is physically up, but there's no traffic on the link due to the upstream traffic provider having problems.
Thank you.
adrianatkins
Long time Member
Long time Member
Re: Norification if speed on a link drops
Thu Jul 15, 2010 1:23 am
Ping their gateway ?
eben
Thu Jul 15, 2010 9:47 am
Not quite that simple.
The traffic providers keep on changing the routes out of their data centres depending on load and which international circuits are actually up and running. More often than not.
gsandul
Thu Jul 15, 2010 10:47 am
Hi, eben
It is not hard to make such a probe, but it will deffer in Dude 4.0 beta from 3.x
So I need to know your Dude version to help you.
eben
Thu Jul 15, 2010 11:04 am
I'm using 3.6
gsandul
Thu Jul 15, 2010 5:57 pm
Ok.
The task is to notify when interface transfer rate on interface index 7 is less than 1Mbit/s (you can change it to whatever)
1) Create 2 functions
You can change interface index to your. The difference between function is in OID we check.
the functions codes are
<?xml version="1.0" ?>
<dude version="3.6">
 <Function>
  <sys-type>57</sys-type>
  <sys-id>20107</sys-id>
  <sys-name>If_7_in_rate</sys-name>
  <code>if(oid("1.3.6.1.2.1.2.2.1.10.7"),round(rate(oid("1.3.6.1.2.1.2.2.1.10.7")*8)),-1)</code>
  <descr>**** The inbound rate on interface number 7</descr>
 </Function>
</dude>
 <Function>
  <sys-id>20130</sys-id>
  <sys-name>If_7_out_rate</sys-name>
  <code>if(oid("1.3.6.1.2.1.2.2.1.16.7"),round(rate(oid("1.3.6.1.2.1.2.2.1.16.7")*8)),-1)\0d\0a</code>
  <descr>**** The outbound rate on interface number 7</descr>
 </Function>
</dude>
You can copy XML and paste it in function tab.
The function will return the bitrate of data going through interface.
NOTE: the functions will return -1 if we do not have SNMP access to device for any reason (wrong SNMP community, or no IP access)
2) Next we need to check if functions are working correct. We need to make something like this picture.
to do it - edit device appearance by right clicking on device (go to next post no more than 3 pictures are allowed where)
gsandul
Thu Jul 15, 2010 6:08 pm
The code of appearance is
[Device.Name]
If 7 in rate = [If_7_in_rate()]
If 7 out rate = [If_7_out_rate()]
[device_performance()][Device.ServicesDown]
Now you need to create 2 probes
The code for probes is
 <Probe>
  <sys-type>13</sys-type>
  <sys-id>20138</sys-id>
  <typeID>8</typeID>
  <functionAvailable>If_7_in_rate() > -1</functionAvailable>
  <functionError>if(If_7_in_rate() = -1,"SNMP Read Error",if(If_7_in_rate() > 1000000,"",concatenate("Warning Low inbound traffic rate on interface 7 the current rate = ",If_7_in_rate()," Bits per second")))</functionError>
  <functionValue>If_7_in_rate()</functionValue>
  <functionUnit>Bits/s</functionUnit>
 </Probe>
</dude>
 <Probe>
  <sys-id>20437</sys-id>
  <typeID>8</typeID>
  <functionAvailable>If_7_out_rate() > -1</functionAvailable>
  <functionError>if(If_7_out_rate() = -1,"SNMP Read Error",if(If_7_out_rate() > 1000000,"",concatenate("Warning Low inbound traffic rate on interface 7 the current rate = ",If_7_out_rate()," Bits per second")))</functionError>
  <functionValue>If_7_out_rate()</functionValue>
 </Probe>
</dude>
go to the next post
gsandul
Thu Jul 15, 2010 6:14 pm
Now add services to the device and have a look what happens when
the rate is slow
The device is not accessible
Do you see the magic? :)
Hope it was helpful :)
adrianatkins
Long time Member
Long time Member
Thu Jul 15, 2010 10:03 pm
Kor ! Genius !
lebowski
Thu Jul 15, 2010 11:32 pm
gsandul is the man!
Quick question though, in the past if you built an IF statement with "-1" for false the dude would consider it a value instead of NULL.
Simple just use 0 instead of -1 in your if...
bad
good
if(oid("1.3.6.1.2.1.2.2.1.10.7"),round(rate(oid("1.3.6.1.2.1.2.2.1.10.7")*8)),0)
BUT I have not tested this in beta4.
gsandul
Fri Jul 16, 2010 11:24 am
1) Had found 1 issue in probes.
<Probe>
  <typeID>8</typeID>
</Probe>
</dude>
Need to change description in function error from inbound to outbound (copy/paste issue)
must be
<Probe>
  <typeID>8</typeID>
  <functionError>if(If_7_out_rate() = -1,"SNMP Read Error",if(If_7_out_rate() > 1000000,"",concatenate("Warning Low outbound traffic rate on interface 7 the current rate = ",If_7_out_rate()," Bits per second")))</functionError>
</Probe>
</dude>
2) lebowski
good
is not rely good, when traffic is very low the system may say "SNMP error" instead of Low traffic rate = 0. And, also rate function returns 0 while establishing baseline, so probe will return SNMP error instead 0.
3) When using Dude 4.0 you must change functions in order it to work because rate function had changed it's behavior.
<dude version="4.0beta2">
 <Function>
  <sys-id>7765875</sys-id>
  <code>if(oid("1.3.6.1.2.1.2.2.1.10.7"),round(rate(diff32(oid("1.3.6.1.2.1.2.2.1.10.7"))*8)),-1)</code>
 </Function>
</dude>
 <Function>
  <sys-id>7765878</sys-id>
  <code>if(oid("1.3.6.1.2.1.2.2.1.16.7"),round(rate(diff32(oid("1.3.6.1.2.1.2.2.1.16.7"))*8)),-1)</code>
 </Function>
</dude>
NOTE: we use diff32 function because 1.3.6.1.2.1.2.2.1.10.7 is 32 bit counter, we should use diff64 when working with 64 bit counters.
eben
Fri Jul 16, 2010 12:50 pm
Thanks guys!
I've not looked at this yet as running the business has come between me and this project : :(
lebowski
Fri Jul 16, 2010 6:39 pm
Thanks gsandul - you always make the nicest stuff.
n21roadie
Tue Jul 20, 2010 9:08 pm
I tried to setup dude v3.6 for wlan speed notification, but two problems
(1) I have missed where to select Wlan interface as it appears to monitor the eth interface
(2) "parse failed" when i tried to add service to device
attached are screenshots
tagno25
Tue Mar 20, 2012 4:20 am
I am trying to get this working without SNMP, is that possible? Or do I need to enable SNMP?
lebowski
Wed Mar 21, 2012 5:07 pm
No
mrasti
Sat Sep 28, 2013 10:33 am
hello, thanks for you useful and complete answer to questions, i have a problem like this topic,
i want see throughput of my cisco switch interfaces on dude map, near the device icon, is it possible ? and how ?
i want see ethernet 1 to 24 tx/rx rate on map.
please show me how.
thanks.
gilbertoandrade
Wed Dec 02, 2015 8:34 pm
Hello!
Very nice post!
A doubt, Why sometimes it's returns value negative on interface ex. current rate = -784576104 Bits per second ?
kenjix
Wed Aug 28, 2019 6:13 pm
Is this functional on ver 6.45.2 of the Dude?
Users browsing this forum: No registered users and 34 guests
