wildbill442
Router OS 5.x and Dude 3.6
Thu May 19, 2011 6:00 pm
Dude 3.6 will not connect to RouterOS 5.x via SNMP.
Upgrading to Dude v4.0beta3 resolved the problem.
normis
Re: Router OS 5.x and Dude 3.6
Fri May 20, 2011 11:52 am
Dude doesn't care about RouterOS version because it can monitor any SNMP compatible device, not just MikroTik routers.
wildbill442
Fri May 27, 2011 2:37 am
weird... cause v3.6 wouldn't read the SNMP values off of any devices I had running ROS 5.x. I upgraded to the beta version of dude and it seemed to fix it.. Maybe I just needed to restart the dude service... either way its working now so I'm happy.
Beccara
Long time Member
Long time Member
Fri May 27, 2011 2:47 am
We monitor a large number of 5.0 devices without issue
heavyd
Mon Sep 12, 2011 10:52 am
I monitor over 150 devies with dude V3.6 running and ALL routerOS V 5 snmp breaks after 7 days or so. Restart the server and all is good then.
eszaknet
Wed Oct 19, 2011 12:03 am
Hi!
Your Dude server is an X86 or Routerboard? Because my Dude server is X86 and I have this problem...
natanielklug
Thu Oct 27, 2011 1:47 pm
Hello all,
I am having a similar problem. I was using The dude v4.0beta3 and I had some problems with "invalid OiD" in most of the SNMP communications even getting all the information I need throw SNMP Walk. So I decided to test the v3.6 of The Dude and it is now working fine for most of the devices but, in RoS v5.x I can't see the RouterOS version or event Interfaces under RouterOS tab of the device (throw SNMP I can read everything now).
Just to ilustrate I am sending this image:
Uploaded with ImageShack.us
Is there anything I can do besides upgrade Dude?
Att,
Nataniel Klug
heavyd
Thu Nov 03, 2011 8:14 pm
Have a x86 with RouterOS and dude installed .. Have the same issue with 4.0Beta3.
eszaknet
Mon Feb 06, 2012 1:42 am
Make a virtual machine, and install on it the Dude. If the Dude crashed, then reboot the virtual machine. It's around 10 sec and it is independent from the phisical router...
It is not the best, but better than nothing
kapulan
Mon Feb 06, 2012 10:26 pm
I have already installed x86 machine the beta3. Dude stop the snmp monitoring the 5.XX version ros device. Working about ten days fine and stop the snmp. But the interesting way 4.xx version ros device working fine not stop the snmp protocol. Restart the dude server working again fine and can monitoring 5.xx devices.
The dude monitoring 500 ros devices,cisco,motorola,saf radios etc..
Users browsing this forum: No registered users and 22 guests
