wifi
Email error message with error as subject
Tue Nov 22, 2005 7:59 am
Instead of having dude email the message and the body as the error part, would it be possible to have it send the error in the subject. We use an sms relay app which only shows who it is from and what the subject is, then it you have to go and download the sms email with your phone which takes forever so you can see the body. By then the phonecalls have started and the customer is &^%$#@! me out.
uldis
Tue Nov 22, 2005 10:51 am
this feature will be in next release of dude - you will be able to put
variables in subject also.
xzafareman
Re: Email error message with error as subject
Wed Apr 15, 2015 9:07 am
yes there are plans to add graphing capabilities to dude???
lebowski
Fri Apr 17, 2015 1:13 am
You will be able to view a map of the objects in your network someday!
If you click the settings button (top left) click polling, click the ... button, double click the notification that you want to change the subject for... add or remove any number of things to the subject and body...
Users browsing this forum: No registered users and 49 guests
