zvera4
Do not close The Dude
Tue Jan 24, 2012 1:04 pm
How to make that the user couldn't close Dude on a dagger?
PS: Sorry my english
normis
Re: Do not close The Dude
Tue Jan 24, 2012 1:05 pm
on a dagger? what does that mean?
zvera4
Tue Jan 24, 2012 2:00 pm
Icon of closing of the program "X"
normis
Tue Jan 24, 2012 2:02 pm
why? is there any way to do this for any other Windows program? I don't think so
zvera4
Tue Jan 24, 2012 2:41 pm
That the user couldn't close the program.
normis
Tue Jan 24, 2012 2:43 pm
you can write in russian maybe, because from your english, I can't understand the problem
zvera4
Tue Jan 24, 2012 4:20 pm
Существует ли такая возможность, чтобы The Dude невозможно было закрыть из под прав пользователя?
Точнее чтобы пользователь случайно не закрыл программу ...
lebowski
Tue Jan 24, 2012 4:52 pm
I don't think you are going to find a decent way to do this but what your looking for is kiosk mode or a program to put the dude into a kiosk. You might find it very easy to use the dude web page in kiosk mode in IE. But finding a program that will put the dude.exe into a kiosk mode will be harder I took a very brief look and didn't find anything....
normis
Wed Jan 25, 2012 8:13 am
Just like I already said, this is not a Dude request, but a Windows request. Any user in Windows can terminate any program. Even if the "X" button is disabled, he can do this in another way. Would you write to Microsoft to avoid accidentally closing Excel? This is a strange request.
zvera4
Wed Jan 25, 2012 2:53 pm
Жаль. Хотелось бы блокировать "x" кнопку. Чтобы юзер случайно не закрыл программу. Речь не идёт об ALT+F4, диспетчере задач и т.д.
stmx38
Long time Member
Long time Member
Thu Jan 26, 2012 10:28 am
zvera4
If Dude started as Service than user can close Dude Gui, but Dude Service will continue to work.
А какая задача у вас ? Ежели речь о неприрывности работы, то уберите возможность у пользователя останавливать сервисы, и рапускайпе Dude серсивом - тогда она будет работать даже при закрытом Dude клиенте.
zvera4
Fri Jan 27, 2012 2:52 pm
Задача в том, чтобы приходили сообщения от DUDE в его клиентскую часть, например, "Свитч 1 не пингуется" и т.д.
А если юзер закроет (выйдет) из клиентской части, то такого сообщения не будет.
stmx38
Long time Member
Long time Member
Sat Jan 28, 2012 6:18 pm
zvera4
Dude 4.0 b3 --> Local Server --> Run Mode: as service
А потом можете закрывать клиента и всё у вас будет работать. Dude будет рабоать сервисом и осуществлять все проверки что вы настроили.
blue
Sat Jan 28, 2012 9:20 pm
It would be cool that instead of close, X button do the minimize on tray. There a lot of other windows programs that have that feature. I don't think that is to hard to implement that feature.
blue
Sat Jan 28, 2012 9:23 pm
Oh, i see that there is a "promise" from uldis to do that in this article:
http://forum.mikrotik.com/viewtopic.php?p=13167#p13167
lebowski
Mon Jan 30, 2012 3:56 pm
There is a program called "tray it" that will put any program into the tray.
http://www.teamcti.com/trayit/trayit.htm
Users browsing this forum: No registered users and 61 guests
