• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Custom layers on Network Map  Page 1 of 1
 [ 4 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
ins0mnia
 Post subject: Custom layers on Network Map
PostPosted: Sat Mar 24, 2012 1:54 am
Offline
I googled but found almost nothing about creating additional layers for a network map. The only 2 are links and dependencies and it doesnt seem to exist a button/setting that I can add.
Any ideas?
Thanks!
Top
 Profile
DynStatic
PostPosted: Sat Mar 24, 2012 9:17 pm
Offline
It is what it is. You're not finding it because it's not an option.
Top
 Profile
ins0mnia
 Post subject: Re: Custom layers on Network Map
PostPosted: Mon Mar 26, 2012 6:40 pm
Offline
Thanks for your response :)
Top
 Profile
lebowski
PostPosted: Tue Mar 27, 2012 12:27 am
Offline
If you want to have a view of say a log file (on the bottom) and the Probe column (on one side) with the map in the middle try this...
Open the Panels contents, click +, name your pannel "StatsView" or something you like, click OK. Double click on your new panel, it should open in a new window, expand it till it is big enough to add parts to it. In the unknown drop down click on the top network map, in the grey bar click on the 4th icon so a new panel appears below the map.
In the unknown drop down on the new panel select action.log. click on the time column to sort by time.
In the grey bar click the 1st icon, this will put a panel to the right of the map.
In the unknown drop down on the new panel select Services...
HTH,
Lebowski
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 4 posts ]
Board index » Other topics » The Dude
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
