ExtraElectrons
Dude Password Recovery on Win 7 Platform
Tue Jun 05, 2012 7:34 pm
I just spent days setting up the Dude software on my desktop Win 7 machine. I set a Dude password last night, but it does not work today!!! :(
Can I copy a certain file/folder from my lost password install, Un-Install the dude software, THEN re-Install a clean version, and then copy the files/folder from the orginal install, to recover all that work???
THANKS!!! :D
gsandul
Re: Dude Password Recovery on Win 7 Platform
Thu Jun 07, 2012 9:14 am
This will not work, but passwords are stored in clear text on sqlite database
You can install python 2.7 and run this script to restore your password.
import sqlite3
import sys
def getname(stri, pos):
    return stri[pos + 1:pos + ord(stri[pos])+1]
def get_ip_mask(stri, pos):
    ip_mask = ''
    for i in range(3):
        ip_mask = ip_mask + str(ord(stri[pos+i:pos+i+1])) + '.'
    ip_mask = ip_mask + str(ord(stri[pos+3:pos+4])) + '/'
    for i in range(3):
        ip_mask = ip_mask + str(ord(stri[pos+i+4:pos+i+5])) + '.'
    ip_mask = ip_mask + str(ord(stri[pos+7:pos+8]))
    return ip_mask
conn = sqlite3.connect(sys.argv[1])
for row in conn.execute("select * from objs"):
    blobstr = str(row[1])
    if (blobstr.find("separatePanels") > 0):
        pwd = getname(blobstr,blobstr.find("password")+9)
        username = getname(blobstr,blobstr.find("sys-name")+9)
        ip_mask = get_ip_mask(blobstr,blobstr.find("allowedAddress")+16)
        print username, pwd, ip_mask
Script argument should be file named dude.db located in dude setup folder.
This file is locked by The Dude, that is why you should stop The Dude before you run the script.
lebowski
Tue Jun 12, 2012 1:50 am
When on the rare occasion the dude flips out it usually dumps the entire configuration :( very sad news, you should be able to log in as admin with no password or what ever the default password is. There has been very little done with tools to recover real data in a broken database.
Hey gsandul good to see you are still lurking :)
gsandul
Tue Jun 12, 2012 1:58 pm
Yes I do, but no more lots of interesting questions for me. :(
You remember me.... Nice. :)
SiB
Mon Aug 31, 2015 10:20 am
It's still work for 4.0b3, THANKS!.
tonygrim
Tue May 03, 2016 11:08 pm
gsandul - you rock! With the assistance of your script I was able to migrate my 4.0b3 database to a new machine, after days of tearing my hair out. :-D
Many thanks!
Tony
rodrigomazzali
Tue Jan 24, 2017 2:12 pm
gsandul - When did you talk about putting in the argument what would it be? Just explaining I do not know anything about Python and I'm with my Dude stopped because I can not remember the admin password for Bkp. Please help me
m05gv
Fri Jun 02, 2017 11:53 pm
Hi, gsandul.
Can you help me?
i've got this error:
line 17, in <module>
IndexError: list index out of range
Thank you.
Eamerty
Wed Sep 13, 2017 10:27 am
To complete the Windows 7 login password reset program???
THANKS!!! :D
It won't work, you need to find a way to reset your forgotten password ,you can rerun the computer
morarz
Fri Oct 05, 2018 3:17 pm
Hi, gsandul.
Can you help me?
Thank you.
I've the same problem, someone know solution ?
I have a The Dude 4.0 Beta3
