luoraymond
Ping problem on Dude
Sat Mar 02, 2013 4:23 am
I got a strange problem with Dude software. I installed Dude 4.03 beta on my PC (windows 7 pro), after successful installation, I added some wireless devices and added ping service to test the connectivity between my PC and those devices.
when I pinged only one device, Pinging was perfect(less than 1% packet lost), however when I simultaneously pinged multiple devices (more than 3, less than 7), more than 20% packet got lost. delay time was the same as before. But I could simultaneously ping all these devices very well using window ping command on my PC( less than 1% packet lost for all devices) . which means network connection is very good, right?
I tried to modify some parameters, such as packet size, TTL ,Probe settings etc. it didn't work. and then I installed Dude 3.6 on another laptop, it got the same problem. Dude does not support multiple pinging ?
BTW, UAC on windows already disabled.
anybody can help me ?
thanks a lot.
brosky
Re: Ping problem on Dude
Mon Mar 04, 2013 6:19 pm
Maybe you have some ICMP rate limiting device in between ?
lebowski
Mon Mar 04, 2013 8:54 pm
Seems like something else is going on... I started a bunch of pings from the dude and had 0 packet loss.
Here it shows 9 pings running. Have you tried to change the dude to run as high or real time priority?
Lebowski
luoraymond
Tue Mar 05, 2013 9:51 am
hi, lebowski, many thanks for your reply.
could you please give me more details how to change the dude to run as high or real time priority?
BTW, the devices I pinged are all remote VSAT devices. the delay tiem of pinging is more than 600MS.
thanks.
lebowski
Tue Mar 05, 2013 8:18 pm
To change the priority of a service you could use system internals process explorer and use a program that changes it at start-up if you find it helps.
http://www.askvg.com/how-to-permanently ... k-manager/
With a 600ms rtt you might just be confusing the dude ping. Maybe create your own ping probe out of ping with different timeouts?
HTH,
Lebowski
Exaile
Fri Apr 18, 2014 12:42 pm
Hello! Using 4.0beta3 and recently began to notice high latency response times to local nodes. from 100 + to 250 milliseconds. If the server and disconnect the poll - it becomes law. What settings can I tweak? Ping is set to 32 bytes with TTL 255, the number of attempts - 7, 3000 ms interval. General survey of 30 to put one minute update interval and label 10 seconds. Thank you if you will help.
Users browsing this forum: No registered users and 27 guests
