I am using the Dude server (4.0beta3) to monitor our network. A few days ago some of the icons turned white. When you click on them it says the status is unknown. Reprobing does nothing. Nothing I seem to do will get them working. I am using a simple ping to check the status of everything. Anyone happen to run in to this before? It's probably something I've done but I sure can't figure it out. Any help would be appreciated.
