jamwatn1
How to show current user
Thu Jun 05, 2014 8:43 pm
Just want to see if anyone could help me?
Im looking to show the Current logged on Windows user when hovering over a computer.
One way I thought it might be possible is scripting a way of showing the most recent folder in C:/Users and fetching the name of it. EG: C:/Users/User01 and having the name of that folder show up.
Hope someone can help?
Justin
rextended
Re: How to show current user
Fri Jun 06, 2014 8:33 pm
Go to Microsoft forum, this is MikroTik forum.
jamwatn1
Fri Jun 06, 2014 8:38 pm
I'm asking about The Dude not a Microsoft product
rextended
Fri Jun 06, 2014 8:41 pm
The most reccent folder can be also 1990 (for example)...
The user folder is created when the first time the specified user are logged, and is not updated for every logon.
jamwatn1
Fri Jun 06, 2014 10:28 pm
It is when using roaming profiles. When a user logs on to a box, a copy of their profile is downloaded/modified. If I could get the dude to find the recently modified folder in c:/users it could display who is logged on theoretically.
rextended
Sat Jun 07, 2014 1:22 am
Can be...
keithBy
Sat Jun 07, 2014 1:35 am
I added this to the appearance of the computer
[Logged_in_User()] Which is the following function
array_element(execute("cscript.exe",concatenate("//NoLogo C:\\ra\\whoisloggedon.vbs ",User_Pass()),"C:\\WINDOWS\\system32\\"),1)
whoisloggedon.vbs is the following script
'loggeduser.vbs
' Sample VBScript to discover which user is logged on
' Author Guy Thomas and John Eck
' Version 2.5 - December 2005
'Modified by gsandul to logon to remote host using
'username and password specified from command line
'Set objPassword = CreateObject("ScriptPW.Password")
'strComputer = "192.168.0.60"
'You can uncomment the following 3 lines and
'specify hardcoded domain, username and password
strDomain = "xxx"
strUser = "xxxxxx"
strPassword = "xxxxxxx"
'wscript.echo wscript.arguments(0)
', wscript.arguments(1), wscript.arguments(2), wscript.arguments(3)
strComputer = wscript.arguments(0)
'If you hardcoded domain, username and password
'comment the following 3 lines
'strDomain = wscript.arguments(1)
'strUser = wscript.arguments(2)
'strPassword = wscript.arguments(3)
'wscript.echo strdomain, struser, strpassword
Set objSWbemLocator = CreateObject("WbemScripting.SWbemLocator")
Set objWMIService = objSWbemLocator.ConnectServer(strComputer, _
"root\CIMV2", _
strUser, _
strPassword, _
"MS_409", _
"NTLMDomain:" + strDomain)
' You suppose to be authentificated
' Now you can write any WMI function
Set colComputer = objWMIService.ExecQuery ("Select * from Win32_ComputerSystem")
For Each objComputer in colComputer
If not objComputer.UserName = "" Then
strLogonUser = Split(objComputer.UserName,"\")
strLogonUser(1) = UCase(Left(strLogonUser(1),1))& Trim(Mid(strLogonUser(1),2,20))
Wscript.Echo strLogonUser(1)
'Wscript.Echo strLogonUser(1) & " is logged on to " & strComputer
Else
Wscript.Echo "No_one_is_logged"
End If
Next
' End of Sample Logged on VBScript
Users browsing this forum: No registered users and 60 guests
