savage
Re: v6.19 released
Wed Aug 27, 2014 6:06 pm
We fixed the issue. We had accidentally released the incorrect userman package, please re-download the userman package now.
So changes was made to userman that's not in the changelog? What else was changed that isn't documented -sigh-
Each and every single release, it's the same thing over and over... It's actually becoming laughable now.
Chupaka
Re: v6.19 released
Wed Aug 27, 2014 6:27 pm
The file still 80kb, the regular user manager is over 700Kb.
at least in the current torrent all user-manager's files are more than 700k =)
ndbjorne
Re: v6.19 released
Wed Aug 27, 2014 6:32 pm
Upgraded a RB951G-2HnD from 6.17 to 6.19.
It seemed ok until I shut it down: after a while it booted up and on log I found (see attached image).
I unplugged power, then powered it again and now
ros code
/system shutdown
works.
Bye
Chupaka
Re: v6.19 released
Wed Aug 27, 2014 6:37 pm
Normis, why are there two Netinstall files in torrent (netinstall-6.19.zip and netinstall-6.19-tile.zip) if they are identical? moreover, download link in 'Tile' section points to netinstall-6.19.zip :)
wispwest
Re: v6.19 released
Wed Aug 27, 2014 7:00 pm
Well this is a tough one. I have 2 PtP links, one is 30 and the other is 40 miles. They've always been fine with NV2, however I notice I get more 'real' throughput when using Nstreme now (used to be the opposite). So I switch to Nstreme and my speedtests on laptop at the edge of the links get 70/30 (compared to 50/20 with Nv2). So I think all is well. Then starting at 11:30PM all the way till this morning, there are random disconnects for 'no apparent reason'. When it works, it works great! Then out of no where, station drops registration for a few seconds, then comes back.
So.. back to NV2 for now. Wish Nstreme would be more reliable like it used to be.
CyberTod
Long time Member
Long time Member
Re: v6.19 released
Wed Aug 27, 2014 8:11 pm
+1 for nstreme. Do you still work on it ? On latest versions only changes for nv2 are mentioned. Nstreme needs only 1 improvement - no disconnections.
Maybe too soon to say, havent done testing, but my smokeping graphs show less packet loss in nv2 today.
Bigfoot
Re: v6.19 released
Wed Aug 27, 2014 8:37 pm
Userman Problem started in 6.19rc6 !!!
Can I have the correct files please !!!
Stillhard
Re: v6.19 released
Wed Aug 27, 2014 9:13 pm
It's from rc5, check my report here http://forum.mikrotik.com/viewtopic.php ... 24#p441524 :)
poizzon
Re: v6.19 released
Wed Aug 27, 2014 10:01 pm
21:41:30 ipsec,error phase1 negotiation failed due to time up. 01d4db047a60b9bc:0000000000000000
21:42:30 ipsec,error phase1 negotiation failed due to time up. 77ef7ebbe6072755:0000000000000000
21:43:30 ipsec,error phase1 negotiation failed due to time up. 84b2038687046a7f:0000000000000000
21:44:30 ipsec,error phase1 negotiation failed due to time up. 42deffb07e877772:0000000000000000
21:45:30 ipsec,error phase1 negotiation failed due to time up. 51399cc76d9cf438:0000000000000000
21:46:30 ipsec,error phase1 negotiation failed due to time up. 06bded99cac5be7f:0000000000000000
21:47:40 ipsec,error phase1 negotiation failed due to time up. 89a97510102ce77c:0000000000000000
21:48:40 ipsec,error phase1 negotiation failed due to time up. 3f89e001a721cbab:0000000000000000
21:49:50 ipsec,error phase1 negotiation failed due to time up. 218823fc05c11ed0:0000000000000000
21:50:50 ipsec,error phase1 negotiation failed due to time up. b6863d33d03abd58:0000000000000000
21:51:50 ipsec,error phase1 negotiation failed due to time up. 56afaac137289cf2:0000000000000000
21:52:50 ipsec,error phase1 negotiation failed due to time up. 3ba12327f25ba182:0000000000000000
21:53:50 ipsec,error phase1 negotiation failed due to time up. 9772820fef218c03:0000000000000000
21:54:50 ipsec,error phase1 negotiation failed due to time up. e0f9cea084fc72f2:0000000000000000
21:55:50 ipsec,error phase1 negotiation failed due to time up. f699872d6c861076:0000000000000000
21:56:50 ipsec,error phase1 negotiation failed due to time up. d14bf652f5792b1d:0000000000000000
21:57:50 ipsec,error phase1 negotiation failed due to time up. 29f50f1bcfb494ed:0000000000000000
21:58:50 ipsec,error phase1 negotiation failed due to time up. 0d818de75296c237:0000000000000000
RafGan
Re: v6.19 released
Thu Aug 28, 2014 1:35 am
Still waiting for this file... Almost 12 hours is not equel to now... It is still not fixed...
dayswaste
Re: v6.19 released
Thu Aug 28, 2014 2:40 am
Upgraded RB2011UAS-2HnD via "Check for Updates" in package list remotely. Had me worried but after +15mins it came back online.
jayd2k
Re: v6.19 released
Thu Aug 28, 2014 7:30 am
Back on July 5th I was reporting the following issue with MT support which, as of today, still persists.
Can't assign any bandwidth greater than 4294Mbps (32 bit) to a 10GbE interface:
ros code
[admin@DCCCR01.RT] /mpls traffic-eng interface> print
 #   INTERFACE                  BANDWIDTH  TE-METRIC REMAIN...
 0   sfp-sfpplus1                4294Mbps          1   4.2Gbps
 1   sfp-sfpplus2                4295Mbps          1  32.7kbps
[admin@DCCCR01.RT] /mpls traffic-eng interface> print detail
 0   interface=sfp-sfpplus1 bandwidth=4294Mbps k-factor=3 resource-class=0
     refresh-time=30s use-udp=no blockade-k-factor=3 te-metric=1
     igp-flood-period=3m
     up-flood-thresholds=15,30,45,60,75,80,85,90,95,97,98,99,100
     down-flood-thresholds=15,30,45,60,75,80,85,90,95,97,98,99,100
     remaining-bw=4.2Gbps
 1   interface=sfp-sfpplus2 bandwidth=4295Mbps k-factor=3 resource-class=0
     igp-flood-period=3m
     remaining-bw=32.7kbps
This keeps us from fully utilizing our 10GbE environment with MPLS on-top. Almost two months and even though I was following up, still this wasn't fixed. That's like offering a Porsche w/o a steering wheel. Know what I mean? ;)
This was tested on four CCR1036-8G-2S+ with ROS 6.19 installed. Since this seems to be a software bug it supposedly effects ALL 10GbE enabled boards.
Kindly fix this ...
Alessio Garavano
Re: v6.19 released
Thu Aug 28, 2014 8:21 am
Download from torrent only the usermanager package for ppc and upgraded succesfully, now work again! ;)
PS: need to set "uninstall" the previous package and reboot with the new package in the root folder of Files and ready!
normis
Re: v6.19 released
Thu Aug 28, 2014 9:17 am
No. the user manager package that was included, was broken. We re-released the version with a working user-manager package. No changes were made.
normis
Re: v6.19 released
Thu Aug 28, 2014 9:18 am
Could be browser cache. Rextended, check if you don't have a proxy or browser cache.
bds1904
Re: v6.19 released
Thu Aug 28, 2014 9:30 am
upgrading to 6.19 (from 6.18)broke the config on my x86 box. It broke the mangle rules (i use them for PCC load balancing) and the route rules. I confirmed the problem twice by downgrading, restoring from a backup config and upgrading again. The config remained broken even after downgrade.
I was able to backup, upgrade to 6.19 then restore the config, and it works just fine.
rextended
Re: v6.19 released
Thu Aug 28, 2014 9:48 am
Try yourself, just re-downloaded:
This is the official download link on download page:
http://download2.mikrotik.com/routeros/ ... 6-6.19.zip
user-manager is only 82.001 byte Aug/27/2014 09:52
Also the auto upgrade inside the routerboard download only 80.1Kbyte file
I have download also all_packages-ppc-6.19.zip and all_packages-mipsbe-6.19.zip, never downloaded before,
and the file is 73k and 65k instead the usual 800KB.
rextended
Re: v6.19 released
Thu Aug 28, 2014 9:59 am
I still see on download page "RouterOS v6.19 release candidate special release"
If you use multiple servers, the IP of http://www.mikrotik.com for my DNS is 159.148.147.196
Are you s ure the webisite is updated with new files?
I do not know if torrent containing right files, but auto-upgrade and webserver still release wrong user-manager packages.
rextended
Re: v6.19 released
Thu Aug 28, 2014 10:06 am
I'M INVESTIGATING ON TWO MORE MEMORY AND KERNEL ERRORS:
IS not easy write it on two word, I'm preparing the adequate description, but for now:
1) Kernel Crash or Panic when using MPPE encryption
pppoe-server [default-encryption settings for 6.19] <-> EoIP [default settings for 6.19] <=== cable ===> EoIP [default settings for 6.19] <-> pppoe-client [default-encryption settings for 6.19]
2) Out of memory on both pppoe-server and pppoe-client machine when traffic is passed over EoIP.
Traffic decrease memory available and the memory is never released:
pppoe-server [default settings for 6.19] <-> EoIP [default settings for 6.19] <=== cable ===> EoIP [default settings for 6.19] <-> pppoe-client [default settings for 6.19]
Hugok1
Re: v6.19 released
Thu Aug 28, 2014 10:30 am
I have upgraded 4 of our 67 Towers rb433AH routers from 6.18 to 6.19, however on 2 of the four the wireless settings was lost so we had to drive to reconfigure the boards. On the other two boards the settings was not lost... Same boards, same radios, plz plz plz Mikrotik, do NOT release something as a commercial release when it was NOT properly tested.
I am also awaiting a answer on a support ticket in regards to OSPF randomly locking up in version 6.18.
Hope to hear from you....
nkourtzis
Re: v6.19 released
Thu Aug 28, 2014 10:31 am
Same here. Cleared cache, nothing changed. Package downloaded from torrent is ok.
Rudios
Forum Veteran
Forum Veteran
Re: v6.19 released
Thu Aug 28, 2014 10:32 am
Are you using a proxy? I have tried to download the newer version from two different computers, each connected differently to the internet.
One is directly connected and I get a newer (bigger) version of the zip. But the other, connected via proxy (unmanaged by myself) is still downloading smaller package.
normis
Re: v6.19 released
Thu Aug 28, 2014 10:34 am
This is what I see in the server:
and from the ZIP:
rextended
Re: v6.19 released
Thu Aug 28, 2014 10:36 am
And inside the ZIP on the server?
Are the same server used for auto-update inside the routerboard?
Using this link (not present on any official download page)
http://download2.mikrotik.com/routeros/ ... r-6.19.npk
Finally I got the right file, but other users know that only if go to this forum...
normis
Re: v6.19 released
Thu Aug 28, 2014 10:37 am
yes.
rextended
Re: v6.19 released
Thu Aug 28, 2014 10:47 am
The server download2.mikrotik.com are solved as d355q2xs8kb5oj.cloudfront.net 54.230.79.3 and single user-manager package are ok, but on the zip on same server are wrong.
The server used from auto-update funcion from the routerboard is 54.230.77.67 and everytime obtain corrupted user-manager-6.19.npk of 80KB
Now I clear all DNS server cache, and retry.
normis
Re: v6.19 released
Thu Aug 28, 2014 10:48 am
they use DNS load balancing, you will get different IP each time. single package is the same as in auto update.
rextended
Re: v6.19 released
Thu Aug 28, 2014 10:53 am
Yes, yes, I know, but seems one server with that address >>54.230.77.67<< still not updated, I have try another server on cloudfront for the auto-update and now has the right file...
normis
Re: v6.19 released
Thu Aug 28, 2014 10:54 am
It could take a while until all AWS Cloudfront servers receive the "invalidation request".
dohmniq
Re: v6.19 released
Thu Aug 28, 2014 10:55 am
You could try adding a query string after the URL to cause a cache miss:
http://download2.mikrotik.com/routeros/ ... stion-mark
I just downloaded the zip and see this:
876625 Stored 876625 0% 08-27-14 14:28 00000000 user-manager-6.19.npk
~850KB
reshsv
Re: v6.19 released
Thu Aug 28, 2014 10:58 am
Hello.
We upgrade our CCR to 6.19 and get "kernel failure" and "reboot by watchdog timer"
I can send autosupout.rif file if needed.
Now we rollback to 6.14...
rextended
Re: v6.19 released
Thu Aug 28, 2014 10:59 am
~850KB
Again: i do not use cache or proxy. Or you intend Cloudfront cache?
rextended
Re: v6.19 released
Thu Aug 28, 2014 11:00 am
Hello.
You use EoIP tunnel?
dohmniq
Re: v6.19 released
Thu Aug 28, 2014 11:07 am
ANY cache - including transparent proxy caches run by your connectivity provider, Cloudfront transparent reverse proxies, browser cache, etc.
It's just a suggestion and could help other people.
normis
Re: v6.19 released
Thu Aug 28, 2014 11:08 am
We have repeatedly issued invalidation request for these files, it should be ok in a few minutes
zervan
Re: v6.19 released
This is insane! I've updated RouterOS to 6.19 last evening in multiple organizations and today they are calling me that WiFi authentication is not working, since I'm using userman :shock: How can you offer "stable" version with such a huge mistake?
I really need to download PPC version of fixed package ASAP, presented links are not working, there is still the old broken one, I tried http://download2.mikrotik.com/routeros/ ... sgdfgwgwer - contains broken package. I don't use any cache.
rextended
Re: v6.19 released
Thu Aug 28, 2014 11:09 am
Clearing DNS cache solve all problem for the "Check for Updates" feature on RouterBOARD, and also on the webiste.
For be explicit for other users: Master DNS cache, gateway DNS cache, office DNS router cache and PC DNS cache.
For the device than have acquired non-wirking IP, must be rebooted, after that when resolving again the DNS give good IP.
rextended
Re: v6.19 released
Thu Aug 28, 2014 11:14 am
INSANE IS USE ONE "JUST OUT" VERSION TO UPGRADE MULTIPLE DISTANT DEVICE ON PRODUCTION ENVIRONMENT!!!
Not only MikroTik, but also Cam... Cis... and Ubi... haved the same problem on some release...
zervan
Re: v6.19 released
Thu Aug 28, 2014 11:20 am
I thought that since there are public RC versions to download, each "stable" version is tested enough. Now I know that I was wrong. Why I upgraded so early? Because today is the last working day of public holiday here and there is only small part of users in those organizations working. Next week it would be worse.
But this debate will not help, could somebody send me a link to working Userman package?
EDIT: It seems that the last torrent file is containing bigger working package, I am downloading...
zervan
Re: v6.19 released
Thu Aug 28, 2014 11:31 am
Yes, it is containing big file, but now I don't know how RouterOS force to update this package. I tried to save it to router and reboot, it is not working.
EDIT: I have found hint from Alessio Garavano: need to set "uninstall" the previous package and reboot with the new package in the root folder of Files and ready!
chaf84
Re: v6.19 released
Thu Aug 28, 2014 11:33 am
Uninstall the wrong package then install the new one.
normis
Re: v6.19 released
Thu Aug 28, 2014 11:34 am
downgrade to v6.18, then upgrade to correct v6.19
zervan
Re: v6.19 released
Thu Aug 28, 2014 11:36 am
I was worrying that I will loose configuration and data, but it is working: I've set this package to uninstall, saved new one to router and than just one reboot - old package was uninstalled and the new one installed, it is working again.
rextended
Re: v6.19 released
Thu Aug 28, 2014 11:53 am
@zervan: If you read the forum...
I just upgrade my x86 with user-manager...
WHERE IS GONE USER MANAGER AND ALL THE USERS DATABASE????
Why on changelog that is not present? :twisted:
THE WEB INTERFACE DO NOT APPEAR AND "new" USER-MANAGER IS DISABLED BY DEFAULT AND ALL THE USERS AND PROFILE ARE GONE...
Reverting to 6.18 have solved the problem...
I love backups... ;)
NOw I check on another board what mess you have done with usermanager.
zervan
Re: v6.19 released
Thu Aug 28, 2014 12:03 pm
It is the question of trust. If I trust Mikrotik (doing well working), I will not hesitate to upgrade and I will not check each update on forum if somebody had worse luck before me. Last few months I didn't experienced any problems, so I had trusted.
reshsv
Re: v6.19 released
Thu Aug 28, 2014 12:26 pm
Hello.
Yes, we use EoIP...
Strange thing... also we have same problem on RB951Ui-2HnD with Eoip tunnel, with software 6.15, rollback to 6.14 don't solve problem, rollback to 6.13 - solve.
rextended
Re: v6.19 released
Thu Aug 28, 2014 12:39 pm
Hello.
Yes, we use EoIP...
It is why I ask you about EoIP, I'm expecting you have it because this:
http://forum.mikrotik.com/viewtopic.php ... 44#p444591
On the last 6.19 version I see memory problem with EoIP tunnel, oversized (> 14xx) UDP packet go to router memory and never be discarded, causing the router go out of memory...
I must write the correct procedure and submit it to support, the problem are easly REPLICABLE....
reshsv
Re: v6.19 released
Thu Aug 28, 2014 1:21 pm
Looks correct...
on RB951Ui-2HnD BOX we upgrade to 6.19 and shut down EoIP tunnel, and box works fine...
One of our CCR with 6.18 and EoIP works fine, but RB951Ui-2HnD with 6.14 reloading...
Which releases affected this problem?
rextended
Re: v6.19 released
Thu Aug 28, 2014 1:29 pm
Looks correct...
Surely 6.19, i do not use 6.8 till 6.16.
I use 6.7 on 4 RB1100AHx2 because MPPE bug still exist, and on dozen of machines on production environment 6.17 and 6.18 and no one have this EoIP problem.
StubArea51
Trainer
Trainer
Re: v6.19 released
Thu Aug 28, 2014 8:19 pm
Thanks MikroTik...
Running smoothly on a 2011 series..will test different CCRs in the next few days.
MadEngineer
Re: v6.19 released
Fri Aug 29, 2014 1:54 pm
Just updated an RB951-2n and all the firewall filter rules were gone. They all came back on a second restart :)
Most likely you just had to wait a while, until the list populated
i did give it some time, was looking at what backups i had and even i tested a filter rule. the firewall rules were 100% gone and not applied - the router was open to the world until I reset it again.
Checking again I've found the firewall rules had been re-arranged somewhat. Some of them seem to have been re-added in order that I last added them. For example I've always had drop everything else rules on forward and input as the last rules, but these moved up ahead of some rules I had added recently. A jump rule has moved below the whole chain it's supposed to jump to, a couple of accepts that had the same comment were next to each other but they're now split, a couple of log rules that used to be prior to their matching drop rules have also moved around.
MadEngineer
Re: v6.19 released
Fri Aug 29, 2014 2:11 pm
Bit of an odd one: begin creating a drop rule. Before saving it with OK or Apply, give it a comment and click OK to close the comment entry. You'll see it immediately creates an Accept rule. It correctly changes after hitting OK or Apply to close the already created rule.
andriys
Re: v6.19 released
Fri Aug 29, 2014 2:47 pm
It has always been like this. (Well, at least since 4.something, when I first learned about RouterOS). It has always been creating a rule upon comment addition, even though the rule might have not showed up immediately in the list in previous ROS releases.
Alessio Garavano
Re: v6.19 released
Fri Aug 29, 2014 4:20 pm
Good! +1 karma will be appreciated ;)
diablonet
Re: v6.19 released
Fri Aug 29, 2014 6:31 pm
Hello, I own a RB2011 UiAS-2HnD and I had troubles with this update.
I had version 6.18, and applied this into it: /system ntp client set enabled=yes primary-ntp=132.248.30.3 secondary-ntp=132.248.3.73 server-dns-names="0.pool.ntp.org"
When I update it to 6.19, it reboots itself in an endless loop, then downgrade it to 6.18.
I removed the NTP setting: server-dns-names="0.pool.ntp.org", then applied the update 6.19 and then it worked.
Tried a few times and I was able to replicate this issue always. Before update remove that server-dns-names setting if you applied, please fix this Mikrotik ;)
igb
Re: v6.19 released
Fri Aug 29, 2014 7:13 pm
I've just tried an upgrade on a 2011-UAS from 6.18 to 6.19. Various devices are connected to the switch ports, some of them using VLAN trunking; three VLANS are present. The hardware ethernet switch is not being used, everything is going via the CPU. There is a PPPoE connection to the Internet. The router comes back up, but many websites fail to load (load some initial content then hang). I had users to contend with, so backed out to 6.18 without much investigation.
Has anyone had similar problems? When I have the network to myself I will try disabling the firewall, as that seems to be an area of substantial change in this realise: I have firewall rules, both for IPv4 and IPv6, and my initial impression is that the websites that were failing to complete were all v4 (Google, for example, worked fine, and I normally access Google over IPv6).
samotoka
Re: v6.19 released
Fri Aug 29, 2014 9:05 pm
Hello, I own a RB2011UAS-2HnD-IN and I had troubles with this update too.
I had version 6.18 and after update my router become irresponsible , reset from lcd screen and router load some default config whit 192.168.88.1 but there is not connection to router even winbox , after 3-20 attempts i realized that default config starts wi-fi and via wireless connection and winbox i reset router with no default config , but router start continuous loop. Next step - netinstall , but after netinstall even i delete some config sets on netinslall app - after netinstal router again bacome iresponsibe via 192.168.88.1
Suggestions
1. netinstall app to have big button about netinstall with NO default config
2. LCD touch screen to have menu reset with NO default config
After two days 6.19 working well and smoothly , pptp is OK
AlexS
Re: v6.19 released
Sat Aug 30, 2014 9:57 am
Netflow is patchy
reboot -> works
reboot -> doesn't work
its a bit hit and miss weather it works, stoping and starting it doesnt seem to help either ..
rather weird
But I have a supposition it has some thing to do with my a sync routing, its not starting records unless it seems a syn packet ... i think !
A
andriys
Re: v6.19 released
Sat Aug 30, 2014 10:09 am
Netflow is patchy
reboot -> works
What netflow version do you use? V9 is supposed to report flow stats on a per-connection basis.
rjickity
Re: v6.19 released
Sat Aug 30, 2014 12:17 pm
i've just noticed new vlan options in the wireless interface:
/interface wireless vlan-id and vlan-mode
quite handy, just out of curiosity does it use the atheros chip or is this something the CPU does (a.k.a "/interface vlan") and will this affect card -> client tagging as well as card -> CPU ?
edit: i just tested it an it looks like its tagging both when activated. A suggestion would be, if there is no-tag specified than remove the vlan-id option from being set. As the option seems irrelevant without a vlan database. Unless it is used with capsman somehow i guess.
either way, an updated wiki would be great for this :)
JanezFord
Re: v6.19 released
Sun Aug 31, 2014 3:30 am
Upgrade from 6.18 to 6.19 erased all of my static dhcp leases. This happened on my crs125 and rb2011uas. The same thing happened on both units when I upgraded from 6.17 to 6.18. I did not have this issue with previous upgrades.
JF.
Zorro
Long time Member
Long time Member
Re: v6.19 released
Mon Sep 01, 2014 7:15 am
works fine. but 6.14 upgrade take almost eight/ten(not use clocks this time) minutes of looking at "booting" screen after reboot.
which slightly terrified mine(does MT employ some kind of media-check or other maintenance or anything else fail-safe related, that would be so MUCH time-consuming in recent verions ?), before it finally completed.
janisk
Re: v6.19 released
Mon Sep 01, 2014 11:58 am
Netflow is patchy
reboot -> works
definitely need more data on this.
roadracer96
Forum Veteran
Forum Veteran
Re: v6.19 released
Mon Sep 01, 2014 6:33 pm
6.19 upgrade definitely plays havoc on configs. I have a very simple config on my home router (CCR1016-12G). 3x Capsman APS, one bridge as LAN interface, one wan interface, NAT, IPv6, DHCP server. Upgrading from 6.18 made it so the bridge didn't show up in interfaces, but the router still worked and forwarded traffic fine. Rebooting the router a second time made it so nothing forwarded and the router rebooted every 60ish seconds. Ended up having to net install router and put config back on. So its running fine now on 6.19 with essentially the same config, just created on 6.19 not 6.18.
standart
Re: v6.19 released
Tue Sep 02, 2014 3:35 am
I can not turn ntp server in this version, already copied the ntp.npk to "Files" in RBs 750GL, and RB540G CCR1016 file. But in any work if the version is 6.19.
Can you help me?
parinya1957
Re: v6.19 released
Tue Sep 02, 2014 4:28 am
After update from v6.17 to v6.19 for 6 of my router board, 1 RB450G loose PPPoE config on interface and I need to go to device to restore backup. Lucky that this unit not far from my home.
Other was fine for 1 of RG450G, 2 of RB2011UiAS-2HnD, 1 of RB1100AHx2 and 1 of RB951-2n.
I have 2 RB450G and 1 was success but the other success on upgrade to v6.19 but loose some config.
pturkey
Re: v6.19 released
Wed Sep 03, 2014 1:18 am
I upgraded a hotspot that is connected to rhe gateway router.
When it came back on Most of my network went dead.
After recycleing the power it everything is okay.
RB333
I will not be upgrading anymore with 6.19.
meetriks2
Re: v6.19 released
Wed Sep 03, 2014 11:03 am
Cosmetic problem PPTP/SSTP server:
[admin@x] > ppp active print
Flags: R - radius
 #   NAME         SERVICE CALLER-ID         ADDRESS         UPTIME   ENCODING
<snip>
13   probe        sstp    xxxxx     0.0.0.0         1h19m42s AES256-CBC
14   probe        pptp    xxxxx     0.0.0.0         1h19m42s MPPE128 stateless
It shows 0.0.0.0 but is not. And was not showed this way in v5.26
[admin@xxx] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   91.230.51.86/27    91.230.51.64    ether1
<snip>
14 D 172.30.252.255/32  XXX.36.170.52    <sstp-probe-13>
17 D 172.30.252.255/32  XXX.28.108.110   <sstp-probe-14>
The clients pick the own IP address. Works fine.
Hope it gets fixed in v6.20
sergejs
Re: v6.19 released
Wed Sep 03, 2014 12:53 pm
diablonet,
please provide us with console output, when your router enters endless loop.
I have used the same configuration for “ntp client” as you specified, my router works without any reboots. Perhaps there is any other configuration that is required.
igb,
I assume you need to check mss (MTU/MRU configuration for PPP profile), and decrease mss to 1300 in /ip firewall mangle rules, by max-mtu max-mru configuration at ppp server.
AlexS,
please provide us (support@mikrotik.com) with support output file from your router, when traffic-flow does not work for you.
JanezFord,
please provide us (support@mikrotik.com) with support output file from 6.19 version, when DHCP-leases are erased.
samim,
please post your issues in the appropriate forum section, this thread is about RouterOS 6.19.
Zorro,
what hardware do you use?
roadracer96,
please provide us (support@mikrotik.com) with support output file from your router.
standart,
please post entire output of command that you use to enable NTP server, and error returned by MikroTik RouterOS.
parinya1957,
please share your configuration with us. We will try to repeat the same problem in our test networks.
pturkey,
please add more details to your problem description. It would be convenient to get console output from your router, when problem is present.
meetriks2,
share you ppp configuration for local and remote addresses, that are assigned to clients.
meetriks2
Re: v6.19 released
Wed Sep 03, 2014 1:12 pm
Here is my config, is very simpel. The linux clients have a static IP configured. I do not assign them.
[admin@x] /ppp> export
/ppp profile
set 1 idle-timeout=3m local-address=172.30.252.255
/ppp secret
add name=probe password=xxxx profile=default-encryption
[admin@x] /ppp> /interface
[admin@xx] /interface> export
set [ find default-name=ether2 ] disabled=yes
/interface ovpn-server server
set mac-address=AA:AA:AA:AA:AA:AA
/interface pptp-server server
set authentication=mschap2 enabled=yes max-mru=1460 max-mtu=1460
/interface sstp-server server
set authentication=mschap2 certificate=cert1 default-profile=default-encryption enabled=yes
Thanks!
snoppy
Re: v6.19 released
Wed Sep 03, 2014 5:49 pm
Hello!
CCR1036-8G-2S+EM
8000 simple queue, about 3500 active users.
we tested 6.19rc6 and had a poor perfomance.
now we test 6.19 and received some improvement
conntrack disable.
on one side we have 2G bonding, on enother side we have 10G.
when traffic 600Mbit/s 60Kpps, load 20%
when traffic 950Mbit/c 90kpps, load 100%, 5 sec and reboot adn so on.
on one side we have 10G, on enother side we have 10G.
when traffic 600Mbit/s load 20%
when traffic 950Mbit/c load 100%, 5 sec and reboot and so on.
ticket 2014081166000977 from 6.19rc6
suppout sent.
so, on increase in great performance in section "simple queue" it is necessary to dream
parinya1957
Re: v6.19 released
Wed Sep 03, 2014 6:28 pm
Here is my config for one of my RB450G which loose PPPoE when upgrade by click "Check for Update" in Package List. The other was done success.
add name=default-dhcp ranges=192.168.0.20-192.168.0.254
add address-pool=default-dhcp disabled=no interface=ether5 name=default
/interface pppoe-client
add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 comment=\
    "" dial-on-demand=no \
    disabled=no interface=ether1 keepalive-timeout=60 max-mru=1480 max-mtu=\
    1480 mrru=disabled name=pppoe-out1 password=password profile=default \
    service-name="" use-peer-dns=no user=user
/queue type
add kind=pcq name=ether5-PCQ-Upload pcq-classifier=src-address pcq-limit=40 \
    pcq-rate=1M
add kind=pcq name=ether5-PCQ-Download pcq-classifier=dst-address pcq-limit=40 \
    pcq-rate=13M
add address=192.168.0.1/24 comment="default configuration" interface=ether5 \
    network=192.168.0.0
add address=1.1.1.1/24 interface=ether5 network=1.1.1.0
/ip cloud
set enabled=yes
/ip dhcp-server alert
add disabled=no interface=ether5 on-alert=print
add address=192.168.0.0/24 comment="default configuration" dns-server=\
    192.168.0.1 gateway=1.1.1.1
set allow-remote-requests=yes cache-size=5000000KiB max-udp-packet-size=512 \
    servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.0.1 name=router
add action=drop chain=forward disabled=yes p2p=all-p2p
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
    "place hotspot rules here" disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
    src-address=192.168.0.0/24 to-addresses=0.0.0.0
/ip proxy
set parent-proxy=0.0.0.0
add check-gateway=ping distance=1 gateway=pppoe-out1 routing-mark=to_ether1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=81
set ssh disabled=yes
set api disabled=yes
/system clock
set time-zone-name=Asia/Bangkok
/system ntp client
set enabled=yes primary-ntp=17.82.253.7 secondary-ntp=17.72.255.11
/tool graphing interface
add interface=pppoe-out1
JanezFord
Re: v6.19 released
Wed Sep 03, 2014 8:53 pm
JanezFord,
I have already made new static dhcp leases .... if this situation occurs again with 6.20 (as it did with 6.18 and 6.19) I will provide you with support out file for sure.
both routers are in production environments and I can't just downgrade them and play around when I wish to. I have to find a free time slot and announce maintenance it to my customers ... If this weekend is free I will try to downgrade and upgrade again to provide you support out file with 6.19 version.
JF.
roadracer96
Forum Veteran
Forum Veteran
Re: v6.19 released
Wed Sep 03, 2014 10:35 pm
roadracer96,
I couldn't get one. Any time I tried to do that or export config, it would reboot. I had to net-install it.
ALEJANDROgordon
Re: v6.19 released
Thu Sep 04, 2014 4:45 pm
I have serious problem with the beta release, because the wireless link is unstable, the ccq down to 17/10%, in the 6.17 version using nv2 and wireless fp package, we have 99/99% ccq and the ping response is low.
sergejs
Re: v6.19 released
Thu Sep 04, 2014 5:11 pm
snoppy,
support is working on your issue. Thank you for the cooperation.
parinya1957,
pppoe-client configuration is lost, is it correct?
JanezFord,
Thank you for the update. I’m sorry for any inconvenience caused.
We had multiple routers with big number of static and dynamic leases, and none of them had issues during the upgrade.
parinya1957
Re: v6.19 released
Thu Sep 04, 2014 6:50 pm
parinya1957,
Yes, correct.
pturkey
Re: v6.19 released
Thu Sep 04, 2014 7:03 pm
I was unable to look.
My network was not accessible.
pturkey
Re: v6.19 released
Thu Sep 04, 2014 7:59 pm
RB711-5HnD
I upgraded to 5.19 and then tried a btest.
Within 3-4 seconds it lost wireless connection.
I changed to several AP's and got no connections.
I also tried a scan for a AP, there was nothing listed.
When I rebooted everything started working.
Tried two times with same resolts.
I did make a supout.rif.
After downgrading I ran the same btest and it was working okay.
ALEJANDROgordon
Re: v6.19 released
Thu Sep 04, 2014 9:55 pm
RB711-5HnD
5.19 or 6.19
joserudi
Re: v6.19 released
Thu Sep 04, 2014 11:00 pm
PayPal dont work in this versión. After upgrade from 6.13 show this error:
"PayPal - ssl connection error: handshake failed [unable to get certificate CRL] (6)"
pturkey
Re: v6.19 released
Fri Sep 05, 2014 1:42 am
6.19
joserudi
Re: v6.19 released
Fri Sep 05, 2014 6:11 am
With 6.19 paypal not works, Another friend say that until 6.18 it works fine.
Chupaka
Re: v6.19 released
Fri Sep 05, 2014 12:38 pm
Sergejs, a friend of mine called me a week ago when he upgraded his router to 6.19, and all his static leases disappeared, so definitely problem does exist :) JFYI
morf
Re: v6.19 released
Fri Sep 05, 2014 11:33 pm
Not working lease-script if using ip-pool in the address field. In other cases, works without problems.
Example:
/ip dhcp-server lease
add address="TEST_POOL" comment=\
    id_E0282F67-ED0E-4116-A743-03435D123444 mac-address=00:0F:02:68:43:7C \
    server="TEST_SERVER"
    id_B506877C-D021-4335-AC7A-C4AA03E2EAFE mac-address=20:89:84:61:30:7F \
    id_7C845A2E-870F-48A8-83CE-6675E9F3F3B4 mac-address=00:8E:F2:EB:0C:F1 \
Sob
Re: v6.19 released
Sat Sep 06, 2014 5:00 pm
NTP client server-dns-names reboot loop
1) Connect device (I used SXT Lite5) to ethernet, configure network address, default route and dns server (just minimal config).
2) Set /system ntp client set enabled=yes server-dns-names="0.pool.ntp.org" to enable NTP client. It will get correct time.
3) Reboot device, while still connected to network. Everything will be ok.
4) Reboot device, but this time without network connectivity (disconnect ethernet completely / connect it directly to notebook / put it into isolated VLAN / ...). Enjoy reboot loop. :twisted:
Or for quick reboot:
Take configured device (from step 1), connect it directly to notebook and set /system ntp client set enabled=yes server-dns-names="0.pool.ntp.org" from there. Wait few seconds for reboot. It will come up fine, because it reboots before it saves settings. Log will say that is was rebooted by watchdog timer.
littlebill
Re: v6.19 released
Sun Sep 07, 2014 5:34 am
steen
Re: v6.19 released
Sun Sep 07, 2014 2:10 pm
Hello Folks!
We updated a couple of CRS125, RB411, RB433 and SEXTANT(RB711G) from ROS6.15, on Sextant and RB433 we did also change to wireless-fp, all updates was successful, nothing unusal was observed.
However, the configurations on all devices contains nothing exotic, just simple static routing and queues plus vlans and trunk links.
We are still stuck to RoS6.7 on the core routers & firewalls, because of that routing marks (used for policy based routing) is still broken on all later releases we tested. Unfortunately that has lead to the business has decided to invest in some more Cisco ASA5510 and Cisco routers instead of the new CCR, but that is life.
Chupaka
Re: v6.19 released
Sun Sep 07, 2014 10:52 pm
what exactly did you test? is it repeatable on v6.19? how?
eavictor
Re: v6.19 released
Mon Sep 08, 2014 9:11 am
The firewall package is complete down.
I'm using 3 VPSs with RouterOS x86 to make my private TV Stream Server available from several place.
(That shitty ISP only provides private IPs)
After upgrade to 6.19, src-nat only function when src-address=0.0.0.0/0
if I set the src-address=1.2.3.4 or dst-address=1.2.3.4-1.2.3.10 the rule doesn't function.
firewall drop rules like src-address=!1.2.3.4 are malfunctioning, it blocks 1.2.3.4 but not other IPs.
firewall accept rule like src-address=1.2.3.4 doesn't functioning either.
This problem appears on all of my 3 VPSs,2 of my CCR1036-12G-4S, RB1100AHx2, RB951-2n, CRS125-24G-1S-2HnD-IN.
If support team members need my VPS for digging where the problem is, please PM or send me e-mail, I will open one of my VPS for you.
sorry for miss typing, "dst" should be replaced as "src"
I am awake without closing my eyes for over 20 hours.
rextended
Re: v6.19 released
Mon Sep 08, 2014 11:43 am
Please help:
http://forum.mikrotik.com/viewtopic.php?f=2&t=88902
For MikroTik staff:
Can you please consider to add one section of the forum dedicated esclusively for the prevention of the Internet threats?
The section is for communicate between various WISP / ISP to prevent and/or detecting threats, spam bot, brute force attack, DDoS and DoS, etc.
Thanks.
honzam
Re: v6.19 released
Mon Sep 08, 2014 11:56 am
Upgrade rb800 from 6.12 to 6.19 fail.
Power cycle needed :(
steen
Re: v6.19 released
Mon Sep 08, 2014 4:37 pm
For years we have tagged source address: scmgateway protocol: tcp/smtp with mailroute.
In routing we route all traffic tagged mailroute to smtp asa5510
Default gateways we have two using classic mikrotik failover, asa5510 is not any default gateway.
Suddenly after upgrade, one customer call in and say, hey where is my emails, customer complains.
After investigating where mail traffic went, all has been queued up in scmgateway, routerboard had not passed traffic on to asa5510, it is not going anywere and stay in mailqueue.
Rollback to RoS6.7 immediate solved the problem.
Chupaka
Re: v6.19 released
Mon Sep 08, 2014 4:52 pm
steen, can you repeat this situation in a test lab?
picacho99
Update from 6.12 to 6.19 without issues RB2011
Mon Sep 08, 2014 7:26 pm
1- Updated RouterBoof from 3.14 to ar9344_3.18.fwf before.
2- Upgraded from 6.12 to 6.19 without issues in a configuration that is summarize below:
- PPP across a fiber provider 100/10Mbits.
- IGMP forwarding with several clients.
- ABout 50 fireall rules.
- Multiple VLANs managed in both the ISP side and internally: VoIP, IPTV decoder and regular internet traffic.
- Authomated Script to update external DNS server.
- L2TP server to access internal Intranet.
After a week, nothing wrong....good job Mikrotik !!!!
WirelessRudy
Re: v6.19 released
Mon Sep 08, 2014 8:08 pm
Maybe if he would give us a printout of the firewall mangle, nat and route tables and rules we can see or repeat the issue ourselves..?
miguel1182
Trainer
Trainer
Re: v6.19 released
Tue Sep 09, 2014 4:58 am
I don't know if its hardware problem but since i'm upgraded my RB2011 simple queue start to have some problems, they work fine but like 5 seconds they give you 200% bandwidth speed you configured, then it only gives you 50% and at randoms intervals do the same like some kind of burst even if isn't configured on simple queue
Sorry for my bad english
AlexS
Re: v6.19 released
Tue Sep 09, 2014 2:33 pm
Netflow is patchy
reboot -> works
So does that mean if it doesn't see the syn it will not start the counters ?
A
adrcomms
Re: v6.19 released
Wed Sep 10, 2014 12:14 am
We loaded 6.19 on our ccr 36, simple queues very fast and cpu load very low.
problems:
customers on pppoe started to get double ip's as we permit 2 ips per account, one for the cpe at home and the other to be used on the hotspot, never seen two ip's on other versions.
hotspot started to block authorised clients or bypassed ip ranges.
backed down to v6.6 as this stable but the simple queues are slower.
Adrian
mramos
Re: v6.19 released
Wed Sep 10, 2014 6:14 am
Hi ...
I upgraded a RB411AR from 5.26 => 6.19 and since then the built in 2.4GHz interface started to disconnect from AP from time to time (e.g 3 ... 6 times a day).
With 5.23 It remains connected for months (AP uptime now ~180 days ROS 5.26 only G mode, 10MHz channel).
On 6.19 there is not the Rate Selection aditional feature LEGACY versus ADVANCED.
Which one is used?
Regards;
adyb76
Trainer
Trainer
Re: v6.19 released
Wed Sep 10, 2014 9:43 am
Installed on our CCR1036 which is our QoS, with many mangle rules and a comprehensive queue tree, passing over 800mbit/s at peak times. All went ok, not sure about performance improvements yet - tonight will be the best time to check this out.
Adyb
PastuhMedvedey
Re: v6.19 released
Wed Sep 10, 2014 1:46 pm
What's new in 6.19 (2014-Aug-26 14:05):
*) bridge - added "Auto Isolate" stp enhancement (802.1q-2011, 13.25.6)
Please tell me where you can find a description of this function in the documentation. Follow the link below, found nothing. http://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
andriys
Re: v6.19 released
Wed Sep 10, 2014 2:56 pm
In the aforementioned 802.1q-2011 standard, obviously. You can get yourself a copy of the standard document here.
Paragraph 13.25.6 says:
13.25.6 AutoIsolate
A Boolean. Set by management if isolate (13.25.20) is to be set, causing a Designated Port to transition to
Discarding if both AdminEdge (13.25.1) and AutoEdge (13.25.5) are FALSE and the other bridge presumed
to be attached to the same point-to-point LAN does not transmit periodic BPDUs—either as a Designated
Port or in response to BPDUs with the Proposal flag set (see 13.21). The recommended default of this
parameter is FALSE. AdminEdge and AutoEdge are both reset only on ports that are known to connect to
other bridges.
isai
Re: v6.19 released
Wed Sep 10, 2014 10:19 pm
Motherboards and firmware ect compatible with v6.xx?
many new boards out there...and your wiki only shows v3 and v4
Clauu
Re: v6.19 released
Thu Sep 11, 2014 11:38 am
I was modifing some dhcp settings/networks and after that bum all settings/networks from dhcp server section disappeared.. same for ip pools, all my 10pools had gone away.. i'm kind a tired of this very unpredictable behaviour every time i'm having emotions that something will go bad and i must reboot or it will crash etc
pchott
Re: v6.19 released
Thu Sep 11, 2014 1:35 pm
We are using Tftp over MikroTik and after upgrade to 6.19 we experience that we cannot transfer filenames with filename lenght 6? Does anyone alse uses TFTP over Mikrotik?
EDIT:
6x8bit = 32bit filename length and with uboot there is no way to transfer such filename. Looks like i have to go back to 6.15
zervan
Re: v6.19 released
Thu Sep 11, 2014 7:45 pm
It seems like there is something wrong with dhcp-server lease address-list parameter. Here is a line of my last backup - as an example:
  add address=192.168.1.91 address-list=klient mac-address=00:1E:74:DD:A3:9F server=dhcp-local
Everything was working for years. Today one of local admins contacted me about a new PC problem - he added new address, but something was not working. I found out that he didn't add address-list parameter as he should - well, but he just made copy of other leases and there is no address-list parameters at all and they were there till now. Did he delete them? I don't think so, I have also checked other of my routers where I use address-list (RB1200, RB751, RB2011) - none of them has address-list parameters set - they were lost probably after 6.19 update!
Here is the same line when I made backup now:
  add address=192.168.1.91 mac-address=00:1E:74:DD:A3:9F server=dhcp-local
The strange thing is that the old leases do add addresses to the list despite the fact that they are not listed in configuration.
Does somebody have this problem or I am the first one? This is the second serious bug in 6.19 that affected me :(
zervan
Re: v6.19 released
Thu Sep 11, 2014 8:24 pm
Another question about dhcp lease address-list problem is - how to fix that? I tried command
/ip dhcp-server lease set address-list=klient numbers=[find server=dhcp-lan2]
- but it is not displaying it neither and there are messages in the log like
dhcp,error dhcp-lan2: failed to add address-list klient for IP 192.168.3.62: already have such entry (6)
lambert
Long time Member
Long time Member
Re: v6.19 released
Thu Sep 11, 2014 9:45 pm
I believe the format of the set command is :
set {entry number(s)} things to set
Your command should have been in the format of:
/ip dhcp-server lease set [find server=dhcp-lan2] address-list=klient
But the error you are getting says that the address-list entry already existed in /ip firewall address-list
You can probably ignore that since some of your entries probably already had address-list settings.
zervan
Re: v6.19 released
Thu Sep 11, 2014 10:59 pm
The format is correct, the same error appears if I set address-list to particular lease number.
The first problem is that since manual setting of Address List in WinBox will remain and seems to work correctly (despite the same error in log), setting using command in Terminal is not working correctly. Maybe better said: it may work somehow "hidden", but the value is not displayed in Winbox, nor export. The second problem is that even working values (which are displayed in Winbox) are lost after reboot.
Is there anybody who can confirm this problem? I am the only one which is using dynamic address list from DHCP clients? I found a very simple way to reproduce the problem: add an Address List to some DHCP lease, reboot, check the DHCP lease - there is no Address List mentioned in 6.19.
tkgit
Re: v6.19 released
Fri Sep 12, 2014 6:37 am
i use rb751u2hnd, if i enable ppp-out 3g use usb 3g modem, cpu process suddenly rise to 100%
if i disable ppp-out, cpu process back to normal again, why? this problem began after RoS 6.xx
gvitalik
Re: v6.19 released
Fri Sep 12, 2014 8:50 am
I am not using 3g modem, and my router is RB951G-2HnD, but on each 7 day after reboot cpu process rise to 100%.
I don't know how to back it to normal, except rebooting.
zervan
Re: v6.19 released
Fri Sep 12, 2014 10:07 am
There is no need to reboot - closing Winbox and opening again is enough. I have reported to support.
zervan
Re: v6.19 released
Fri Sep 12, 2014 10:12 am
No problem with that using RB951Ui-2HnD + ZTE modem, nor RB2011UiAS-2HnD + Huawei modem, both with RouterOS 6.19 and previous. Check Tools -> Profile, which process is using CPU, maybe it is related to firewall rules or something like that.
gvitalik
Re: v6.19 released
Fri Sep 12, 2014 11:37 am
Hi zervan!
May be you know what is better to do in case ipsec show 96% of cpu in profile, but at this moment I have no any ipsec connection? I don't know why, but I have configured l2tp/ipsec vpn server before, but now there no any ipsec proposal and peers. If i open PPP->l2tp configuration and save it again, then the system re-create ipsec proposal, but after some period of time, this proposal will be "deleted" again.
zervan
Re: v6.19 released
Fri Sep 12, 2014 1:06 pm
Sorry, but I don't know the reason. Try to export configuration and check if there is really no forgotten ipsec / l2tp mentioned. Is this problem related to RouterOS 6.19? Was it working in previous versions? If not, you should create new post / topic in appropriate section of this forum and somebody will know to help, I think.
I have problems with high CPU load only when I am connected to Winbox and Profile show non-senses like "flash". When I disconnect, CPU load is low again (I can see it on graph). This problem I have for about 10 versions back. But it is probably not the problem you have.
zervan
Re: v6.19 released
Fri Sep 12, 2014 1:09 pm
I've got answer from Mikrotik support - this problem should be fixed in 6.20rc6. I will try in the evening, but I worry - what if there are some new bugs? Early implementation of 6.19 brought serious troubles to me.
rextended
Re: v6.19 released
Fri Sep 12, 2014 6:20 pm
What's new in 6.20rc6 (2014-Sep-08 10:16):
*) pppoe client - increase connection timeout to make connection establishment
possible on busy pppoe server;
*) dhcp server - change default lease time from 3 days to 10 minutes
to avoid running out of IPs;
*) ipsec - allow binding modeconf address to username;
Winbox v3 is required for router’s configuration.
SERIOUSLY? IS STILL FULL OF BUG AND IS NEEDED FOR 6.20!!!???
zervan
Re: v6.19 released
Fri Sep 12, 2014 6:37 pm
Unfortunately, yes. I have upgraded one of my routers to 6.20rc6 to test if Address List of DHCP Lease is fixed (it is not) and it is not possible to connect with the old good Winbox :(
CyberTod
Long time Member
Long time Member
Re: v6.19 released
Fri Sep 12, 2014 6:41 pm
I am connecting through Dude, because it is more convenient to work with a lot of devices. If I will not be able to that anymore because it is using old winbox version that is a major problem for me.
P.S. I just found a workaround for that by making a custom tool in Dude and if indeed winbox 3 is required for administering v6.20+ I will post a short guide with some pictures.
noyo
Re: v6.19 released
Fri Sep 12, 2014 7:10 pm
solution is:
1. Create a directory "Dude" in the C:\
2. Copy the new winbox3 to C:\Dude\
3. Go to Dude > Tools > + end
3.1. name: Winbox3
3.2. command: "C:\Dude\winbox3.exe" [Device.FirstAddress] [Device.UserName] [Device.Password]
Connect to new winbox:
Right click on the device > tools > winbox3
Works on windows, how and on Linux under Wine.
good luck :)
CyberTod
Long time Member
Long time Member
Re: v6.19 released
Fri Sep 12, 2014 7:14 pm
I just did that :)
With the exception that my path points to where my winbox3 is currently saved.
The downside is that the integrated in Dude winbox connects a lot faster. And the known bug of not remembering session with the new one.
noyo
Re: v6.19 released
Fri Sep 12, 2014 7:19 pm
t's terribly sad that we have to pay for underdeveloped software.
Also a shame that mkrotik tests its software on the clients :(
mperdue
Re: v6.19 released
Fri Sep 12, 2014 11:26 pm
I decided to be carefull before deploying 6.19. I have some spare's here at the office so I've upgraded 12 units and bricked 4. Two Rb133c's, one RB SXT 2nd (new out of the box), and one RB912UAG-2HPnd (new).
They will light up quickly one beep and then nothing.
How can I unbrick these units?
-Michael
athlonxp78
Re: v6.19 released
Fri Sep 12, 2014 11:30 pm
WTF!!!??? The Beta3 of Winbox v3 is buggy and you "lock us" to work with this version?
Are you crazy?
It´s a JOKE?
steen
Re: v6.19 released
Sat Sep 13, 2014 10:40 am
Hello Folks!
We successfully updated about 1/3 of of our MT equipment to RoS6.19 and firmware, we also enabled wireless-fb package on them. RB411, RB433, SXT, SEXTANT and a couple of switches CRS125.
We did it in small steps like, first a baseline reboot then update RoS + reboot, then update firmware + reboot and last enable wireless-fb + reboot.
Still the routing marks for policy based routing is broken so we are stick to RoS 6.7 on those.
kobuki
Re: v6.19 released
Sat Sep 13, 2014 5:01 pm
Are you crazy?
It´s a JOKE?
I must agree. The v3 beta3 cannot reliably re-open the windows and their arrangements when I open an old session auto-imported from winbox2. This effectively makes it completey useless in production. Please save us from testing your half-baked code. There are a lot of small problems and mistakes one can tolerate when forced upon. This is certainly not among them.
bajodel
Long time Member
Long time Member
Re: v6.19 released
Sun Sep 14, 2014 9:54 am
if confirmed I think ros 6 series will stop at 6.19 for me ..
.. pure crazyness
hashbang
Re: v6.19 released
Sun Sep 14, 2014 6:00 pm
+1
winbox 3 is buggy. It doesnt run properly on wine. The cursor will blink on the extreme right of ip address but if u use back space it will delete the 1st octet of ip address. So painful for anyone who uses keyboard and doesnt watch the screen :P. Specially when u have a long list of devices in your winbox list.
xcom
Re: v6.19 released
Mon Sep 15, 2014 2:05 am
If this will be the case for all firmwares going forward, I will take my switch off my network and set it on fire...
I am a linux user and having to install wine to run another buggy ass application... Hell no!... You can keep the spoon.
:evil: :evil: :evil:
lambert
Long time Member
Long time Member
Re: v6.19 released
Mon Sep 15, 2014 2:48 am
We're complaining that pre-release RouterOS requires pre-release Winbox?
Maybe MikroTik just wants to ensure that they get some Winbox 3 feedback from the people who are already demonstrably risk takers. If you are running RCs, you are a risk taker.
Anyone who cares should e-mail support and ask them if they intend for Winbox 3 to be production ready before RouterOS 6.20 is released.
Personally, I think it would be a mistake for MikroTik to require Winbox 3 to manage any RouterOS 6.x release. They can require whatever they want of the RCs. They can require whatever they want for 7.x. But the 6.x releases should not require untested management methods.
And none of that has anything to do with RouterOS v6.19. Start another topic already.
AlexS
Re: v6.19 released
Mon Sep 15, 2014 4:11 am
I'm presuming you can still ssh to the box.
If not then 6.19 will also be my final firmware..
A
kapulan
Re: v6.19 released
Mon Sep 15, 2014 12:17 pm
Remote mac-telnet not work(connection timeout) all v6 version change the wireless mode to station bridge !Change the mode to simple station work again the mac-telnet.I use NV2 .
Mt team please fix this problem.
zyzelis
Re: v6.19 released
Mon Sep 15, 2014 12:45 pm
Just upgraded a whole network to v6.19.
Devices are CCR1036, 1100AHx2, SXT lite5;lite2, SA5r2, G2HnD, G-5HPacD-SA, G-5HPacD, RB433GL, OmniTik-U and UPA,
RB750GL, 750, 750UP, RB2011-LS;RM;UAS, RB951G;U, RB711-5h,RB911-5Hnd and grooves A52HN.
works stable so far, no "kernel failure" crashes, all wireless devices with fp packages
Thanks Mikrotik for stable package.
snoppy
Re: v6.19 released
Mon Sep 15, 2014 12:57 pm
Hi all!
we tested 6..20rc6
4000 simple queue
active users from 900 for 3800
conntrack ON
load 100%,traffic up to 1.7Gb/s
when load to 90-100% (1.7G) router freeze on 5-10 seconds and traffic down to 700Mb/s
connrack OFF
load 10-15% traffic up to 2.3Gb/s
sometimes load 100% and router freeze for 5-10 seconds , but traffic not down.
sometimes load up to 40-50% and then slowly going down to 10-15%
suppout was sent.
Ticket#2014081166000977 with Martins S.
voxframe
Re: v6.19 released
Mon Sep 15, 2014 4:07 pm
normis!
This really bothers me!
Why do you lock us into beta firmware/software before stabilizing the current branch!
Before you did it with the 2011 board and 6.x firmware. Some boards worked with 5.x and some (after a still undocumented hardware change) require 6.x.
Now you are doing it with a buggy version of winbox!
Guys... STOP! STABILIZE THE DAMN THING! Then slowly implement changes. winbox3 should not make ANY appearance in 6.x. It should be reserved for 7.x
Come on! All I want is for things to be stable like 5.26, but I can't run it on half of your hardware, and currently no version of 6.x is trustable.
adyb76
Trainer
Trainer
Re: v6.19 released
Mon Sep 15, 2014 6:54 pm
We have recently upgraded to 6.19 from 6.7 on couldcore router with ubiquiti AF24 and now have FCS errors on interfaces that have an AF24 connected to them.
We have this issue previously and you guys managed to fix it but it's reared its ugly head again....
Thanks,
Adyb
hashbang
Re: v6.19 released
Tue Sep 16, 2014 8:40 am
adyb76 please post the screenshot
vox +1
steen
Re: v6.19 released
Tue Sep 16, 2014 1:37 pm
Hello Folks!
We now updated even more RB411 and SXT and SEXTANT:s to RoS6.19 and wireless-fp, no problems so far.
The only observation is that the RB devices takes long time to come back on the network after updating RoS, the same is after the firmware is updated and when switching package from wireless to wireless-fb.
Well, then we have to broken routing marks that prevents us from upgrading several edge routers, business has decided to pick another brand to replace them.... :-( Policy based routing is a must for us.
OlegM
Re: v6.19 released
Tue Sep 16, 2014 1:44 pm
Version 6.19 CCR. Accordingly CCR serves as PPTP server. The role of the client VPN connection that uses torrents. Noted in the PPTP connection, that when working torrents connection is not broken, but the packets lost as long as you do not restart PPTP. And it was seen in the earlier versions.
zyzelis
Re: v6.19 released
Tue Sep 16, 2014 2:16 pm
It was early to be happy with 6.19.
On CCR1036 which is connected via SFP to RB260GSP now i regullary get FSC error on link.
Already tried to turn off autonegotiation and set to FDX 1G, problem still persist
Before CCR was on 6.12 and such problem wasn't......
So be carefull. :?
Robinson
Re: v6.19 released
Wed Sep 17, 2014 12:01 am
After upgrading Ros 5.20 to Ros 6.19 Sextant (RB711-5HnD) lost WLAN port. After disconnecting and connecting the power supply interface has returned, but with defoult settings. 1 hour on a 6 km. remote tower to return the the link. :?
slebrun
Re: v6.19 released
Wed Sep 17, 2014 1:12 am
We upgrade a pair of 493AH routers to 6.19, and saw EoIP start dropping packets > 1422 bytes. Rolled back to 6.17, no problems.
We did not, however, upgrade the far end of the EoIP tunnels, which may or may not have wound up working better.
bajodel
Long time Member
Long time Member
Re: v6.19 released
Wed Sep 17, 2014 8:47 am
6.20rc9 works with winbox2 ..thanx :D
gemwk2
Re: v6.19 released
Wed Sep 17, 2014 11:30 am
There is a problem with RB SXT G-5HPnD r2. This board restarting itself because of kernel failure and log is like this "00:42:21 system,error,critical router was rebooted without proper shutdown by watchdog timer ".
normis
Re: v6.19 released
Wed Sep 17, 2014 11:36 am
how is your watchdog configured? maybe it is pinging some address
hedele
Re: v6.19 released
Wed Sep 17, 2014 12:31 pm
Welp... no more rc testing (or upgrading, for that matter) for me then...
I'll stay on 6.18 on all of my devices, since EoIP (which I use it a lot) is broken on 6.19.
6.18 was a great release (the first really stable and usable one with no major bugs for my use-cases in the whole 6.x branch) and I hold on to it dearly.
normis
Re: v6.19 released
Wed Sep 17, 2014 12:38 pm
why?
hedele
Re: v6.19 released
Wed Sep 17, 2014 12:57 pm
Well as you can read from some of the feedback in this thread, winbox 3 does not seem mature enough for production use yet.
Also, I don't think that there is any technical reason that winbox 3 is required for new rc builds, it's probably just politics to force people into beta-testing winbox 3.
gemwk2
Re: v6.19 released
Wed Sep 17, 2014 4:06 pm
Watchdog is configured by default, no configuration is set.
kliq
Re: v6.19 released
Wed Sep 17, 2014 5:06 pm
Hi all,
We've been working with Mikrotik since v2.9.5 and have followed the progress and changes at Mikrotik for a number of years. We thought we'd throw our 2 cents in on the forums and maybe help pinpoint a few issues. :)
We have been rolling out 6.19 and picked up on similar issues as faced by gemwk2; on about 20 6.19 devices we have deployed, 4 of them are constantly (2-3 times daily) rebooting due to watchdog timeout.
The watchdog is configured in different ways on all 4 devices, all but one are watching a specific IP and the 4th is just enabled as default. We did try disable the watchdog but the board needed a hard reboot as it froze a couple of hours later. If any other information is required please let us know.
noyo
Re: v6.19 released
Wed Sep 17, 2014 5:39 pm
See if your CPU jumps to 100%.
U is not so with Lite5 update 5.26 -> 6.19. Yesterday I turned off the wireless-fp and it did not work. Today, some three hours ago in August alone restarted.
Watchdog also have a default set.
Mikrotik a confused and August restaruje.
visalink
Re: v6.19 released
Wed Sep 17, 2014 5:44 pm
I also have this problem.
I'm moving to VPLS.
nsayer
Re: v6.19 released
Wed Sep 17, 2014 9:58 pm
Sometime between 6.16 and 6.19 L2TP VPN between my mac and iPhone and my routerboard has broken.
I went in and made sure that the configuration was correct (so far as I know), including "enable IPSec" and adding the shared secret on the L2TP server page.
What I get on the mac side is "IPSec connection failed <IKE Error 65535 (0xffff) Unknown error>"
and in the system log,
IKE Packet: receive success. (Initiator, Main-Mode message 4).
try to get pskey by the peer's address.
couldn't find the pskey by address [routerboard].
couldn't find the pskey for [routerboard].
I'm really, really, REALLY sure the shared secret is the same on both sides.
WTF?
armandfumal
Re: v6.19 released
Wed Sep 17, 2014 11:21 pm
It is your choice. You can also go to Cisco and pay thousand euro for the device and many more for the service...
MKT do a very good job...
noyo
Re: v6.19 released
Wed Sep 17, 2014 11:26 pm
Man, you pay for it. I really want to buy the product on a half fit?
Think out what you're saying.
I like solutions Mikrotik, I would not trade them for anything at all else, but wants a product who works.
armandfumal
Re: v6.19 released
Wed Sep 17, 2014 11:27 pm
I'm using EoIP on CCR, RB2011, RG951 without any issues with 6.19, work stable...
noyo
Re: v6.19 released
Wed Sep 17, 2014 11:31 pm
And for me as you can see in the graph is not stable. I uwielu people also is not stabile, that in itself is already available 6.20rc shows that there are errors.
Apparently, your network will not fully benefit from the opportunities mikrotik.
I lite5 restart once a day, so do not tell me that it is stable, because it is not.
armandfumal
Re: v6.19 released
Wed Sep 17, 2014 11:46 pm
we have hundred mkt devices under 6.19 without any big issues, may be your problem is coming to specific usage in your config, your case must be analysed by MKT support...
TikUser
Re: v6.19 released
Thu Sep 18, 2014 1:56 am
I'm having a very strange issue. My backup files on the 493g are getting bigger and bigger, but the configuration is the same. Only the textual backups have the same size. Where is the problem? Any suggestions?
The rb493g has 2 wifi cards inserted. One is disabled, and the other serves as AP (2.4GHz).
patrikg
Re: v6.19 released
Thu Sep 18, 2014 10:34 am
The backup files, i assume that it also take backup of the logs and much more.
Not only the config.
snoppy
Re: v6.19 released
Thu Sep 18, 2014 11:40 am
Hello
we have some CCR1036-8G-2S+EM
when traffic grow up to 3Gb/s and more, SNMP does not work correctly.
this ccr connected to other switch
and SNMP statistic from this switch-port has not failures, and traffic 3.5Gb/s
this problem in all versions, whitch we tested and uses
from 6.13 to 6.19, and all 6.20rcX.
vadimbn
Re: v6.19 released
Thu Sep 18, 2014 6:19 pm
I observe a memory leak on this version of RouterOS. Ticket#2014091866000668 has been created.
nsayer
Re: v6.19 released
Thu Sep 18, 2014 7:04 pm
WTF?
Bueller?
maxfava
Re: v6.19 released
Thu Sep 18, 2014 11:16 pm
Normis,
I noted 6.19 has changed mcs ht user interface in winbox on AC devices when I set fixed data rate.
Could you kindly address me how new User Interface works?
Before was with check box and able to set single mcs rate, now is a drop down box showin from 0-9, 0-8, 0-7.
Thanks.
Massimo
nsayer
Re: v6.19 released
Fri Sep 19, 2014 4:52 pm
WTF?
Bueller?
Bueller?
mrz
Re: v6.19 released
Fri Sep 19, 2014 6:45 pm
Enable ipsec debug logs, try to connect and after failure generate supout file. Send this file to support at mikrotik.com
OlegM
Re: v6.19 released
Fri Sep 19, 2014 10:39 pm
Tell me how to write the rules in the firewall to use Layer 7, to block sites by domain, that would not die CCR. I certainly understand that this issue is not the place, but on x86 does not fall even when the error interfaces, and CCR constant problems.
paoloaga
Re: v6.19 released
Sat Sep 20, 2014 3:51 am
do I miss something or the IPv6 iBGP route reflection doesn't work?
joegoldman
Forum Veteran
Forum Veteran
Re: v6.19 released
Sat Sep 20, 2014 7:15 am
Finally upgraded my core CCR's to 6.19 last night - so far no problems but some problems I held off reporting from my old version still exist.
Normally I am sitting 3-10% CPU usage, but it will randomly spike to 50+% CPU usage with no major network events. From some of the profiles I've been able to capture it seems to be the networking process spiking but they are sporadic and only last for ~5 seconds so I can't even capture a supout.
It is still painfully slow to filter and search the route table. I have about 540k IPv4 routes loaded and I can do a x.x.x.x in dst-address filter without it taking MINUTES, or searching where blackhole=yes or comment="blah". I dont mind 20-30 seconds but minutes is too long when investigating issues.
Surely there is a better way like referencing the FIB directly as if it does when actually doing the routing?
I used to have another issue where /system resources CPU % would differ from the reported 'idle' amount (inversed) in the profiler, by up to 5-10%, but this seems better, still closely looking though.
noyo
Re: v6.19 released
Sat Sep 20, 2014 10:08 am
In my case it helped to /system reset-configuration no-defaults=yes and the configuration of RB again.
Uptime 1d and 7h
karina
Re: v6.19 released
Sat Sep 20, 2014 10:38 pm
With due respect zervan, the mistake is upgrading production routers to the latest version quite so quick. I would advise testing before deploying any software or if not possible watch the forum while others test
Begetan
Re: v6.19 released
Sun Sep 21, 2014 3:52 am
I put CCR-12G-4S-EM with ROS 6.19, made configuration of SNTP client. Put DNS name instead of IP.
Then I upload ntp package and restart device, after that I completelly lost connections.
I have to go at morning and immediattely fix the problem. Could anyone tell me which version is good for CCR?
It looks like NTP is broken here and this is the worst release ever! Please provide me link to official package 6.18 for Tile.
honzam
Re: v6.19 released
Sun Sep 21, 2014 9:54 am
http://download2.mikrotik.com/routeros/ ... e-6.18.npk
nz_monkey
Re: v6.19 released
Mon Sep 22, 2014 2:05 am
+1 we are still running 6.5 in prod, and are only now an entire year later evaluating 6.19 for our next upgrade.
Zdenekhb
Re: v6.19 released
Mon Sep 22, 2014 11:42 am
Tested 6.19 on SXT5G-HnD Link... but Throughput is very bad.
Link is Only-N, 20/40 above, nv2 signal -40dB to -45dB on both chains. no wireles-fs enabled
6.19 winbox freeze ... try BTest and Throughput is 1-10mbps (WTF?) in 1TCP connection
Downgrade to 6.18 Try Btest and Throughput si 70-80Mbps in 1TCP connection.
Zdenek
zyzelis
Re: v6.19 released
Mon Sep 22, 2014 11:47 am
Zdenek
What about other end?
Try to enable wireless-fp with 6.19 and i think your wtf will change to wow :).
onnoossendrijver
Re: v6.19 released
Mon Sep 22, 2014 1:37 pm
Zdenek
Well, -40 to -45 is a bit strong. Try adjusting it to -50 to -55.
k0st3k
Re: v6.19 released
Mon Sep 22, 2014 10:52 pm
how to uninstall dude ? :)
jarda
Re: v6.19 released
Tue Sep 23, 2014 12:31 pm
Netinstall? Or maybe from console if possible?
k0st3k
Re: v6.19 released
Tue Sep 23, 2014 1:20 pm
in console not possible.......i think only netinstall can help :shock:
voxframe
Re: v6.19 released
Tue Sep 23, 2014 3:28 pm
Any updates on 6.20 progress?
zervan
Re: v6.19 released
Tue Sep 23, 2014 10:17 pm
I was explaining that: I thought that since there are public RC versions to download, each "stable" version is tested enough. Now I know that I was wrong. Why I upgraded so early? Because today is the last working day of public holiday here and there is only small part of users in those organizations working. Next week it would be worse.
Sorry, but if a software is stated as "stable release", it should work and it is not good to test each version again. Here in 6.19 I found two bugs which are serious for my usage, but only a few users use this specific functions. Which version should I stay in? Almost in each version I've found some bugs, hoping next release will fix them. In some version before there was a bug related to multiple SSTP sessions (disconnecting), it was fixed. Some bugs nobody else reported here, just me - e. g. DHCP Leases Address List problem (it should be fixed in 6.20rc6, but it was just partially, still not fixed in 6.20rc9 which I tested latest). So what should I wait for? This kind of bugs I will not see immediately - it will take a time. Waiting is not a solution.
Many will agree that Mikrotik should really improve development. Why not to have odd (new functions and improvements) and even (just fixes) versions? I am recommending and implementing Mikrotik products - but it is shame when my customers are complaining that something stopped to work after upgrade.
noyo
Re: v6.19 released
Tue Sep 23, 2014 10:36 pm
I would urge you not to upgrade to 6.xx, is broken. MikroTik not fully test their software, only counts on the free beta testers
We pay, require an efficient software
All v6.xx is fucked in full.
I had updated a couple of RB711, Lite5, RB2011, RB912 to v6.19 or 6.7, and each August restarts from time to time due to the watchdog.
Watchdog has never been set - the default configuration.
After the downgrade v6.19 to v6.7 CPU up to 100% (ipsec). IPsec has never been used.
It helps to CPU 100% IPSEC:
/system package disable security
/system reboot
#waiting for restart
/export file=conf
/system package enable security
/system reboot
/system reset-configuration no-defaults=yes keep-users=yes run-after-reset=conf.rsc
#A couple of times I did not work, so I need inputs on the mac and perform again
Ticket#2014091366000293
Looks like some problems with installation. Would it be possible to netisntall
that boards, It will format all partitions and install valid RouterOS version
Downgrade ALL to v5.26 and firmware 3.10.
littlebill
Re: v6.19 released
Wed Sep 24, 2014 3:42 am
6.7 sstp server 2011 --- Map2n 6.19 sstp client. upload will never go above .75 mbit,
i was barely able to get down to 6.7 and i was able to go over 7mbit on tunnel, but i have the same IPsec 100 % cpu usage
i tried netinstall 6.7 but the unit will not boot correctly with default config. it came shipped at 6.15, so not sure it can go that low, really wish it would, unit is kind of useless right now
and no i won't upgrade off 6.7 till we have proven vpn is working reliably
savage
Re: v6.19 released
Wed Sep 24, 2014 12:09 pm
Hopefully this is a cosmetic bug...
[admin@MikroTik] > /system resource print
uptime: 10m55s
version: 6.19
build-time: Aug/26/2014 14:05:51
free-memory: 1841.2MiB
total-memory: 1893.6MiB
cpu: Intel(R)
cpu-count: 16
cpu-frequency: 2127MHz
cpu-load: 0%
free-hdd-space: 146.5GiB
total-hdd-space: 146.7GiB
write-sect-since-reboot: 14730
write-sect-total: 14730
architecture-name: x86
board-name: x86
platform: MikroTik
[admin@MikroTik] >
The server has 12GB of memory, not 2GB. It looks like the 1 before the 2 has been cut off (both in winbox, as well as console).
Also experiencing RX errors on a Intel 10Gig interface (looks like a constant 1/sec), currently downgrading to 6.18 to see if it's version related or not.
snoppy
Re: v6.19 released
Wed Sep 24, 2014 1:11 pm
memory more then 2G can used onle in CCR
on other platforms ROS only 2G max.
mperdue
Re: v6.19 released
Wed Sep 24, 2014 5:33 pm
Our system is running a mixture of 6.1 on the AP's and 5.6 on the clients.
I pulled copies of 6.9 and decided to first upgrade the miscellaneous units that I had here in the office.
Out of 13 units upgraded to 6.9, 6 units would not restart or respond after reboot.
3 rb133c's (using mipsle code)
1 rb 411 (using mipsbe code)
1 rb 750 (using mipsbe code)
1 rb 911 ((using mipsbe code)
I managed to recover the 411, 750 and 911 units using netinstall and did manage to get 6.9 on it.
The rb133c's won't take any version that I offer them. Though I am going to take them home this weekend and try using a an old win xp machine com ports due to the usb com port option I am trying to use in a Win 7 machine.
I simply can not take the chance of upgrading clients and not having there units upgrade as expected. I can not pay for service calls to go replace units when they fail to upgrade. And I have probibly 20% of my network still on rb133c's which I have had a 100% failure rate on.
Has anyone else's experience been this way?
Regards,
Michael Perdue
SmythNet, CEO
www.smyth.net
276-783-3333
Thalid
Re: v6.19 released
Wed Sep 24, 2014 5:49 pm
These units are probaly to old to run ros v6
in general units support 2v updates and these boards are from around 2006
http://routerboard.com/pdf/rb133ugA.pdf
mperdue
Re: v6.19 released
Wed Sep 24, 2014 6:06 pm
Then why would they release 6.x code for them then?
Ljubo
Re: v6.19 released
Wed Sep 24, 2014 6:18 pm
Regards,
Michael Perdue
SmythNet, CEO
http://www.smyth.net
276-783-3333
Thalid
Re: v6.19 released
Wed Sep 24, 2014 6:22 pm
just refering to what i read in some older posts like this one
http://159.148.147.201/viewtopic.php?f= ... us#p161880
bazzer
Trainer
Trainer
Re: v6.19 released
Wed Sep 24, 2014 7:13 pm
It states "RB111, RB112, RB133C, RB150 devices are not supported in v6, please use v5." on the download web page. http://www.mikrotik.com/download
mperdue
Re: v6.19 released
Wed Sep 24, 2014 7:48 pm
Ok, thanks. At least now I know why 6.x bricks the units and that I'll be unable to upgrade further. - Michael
SiB
Re: v6.19 released
Sun Sep 28, 2014 4:20 am
21:41:30 ipsec,error phase1 negotiation failed due to time up. 01d4db047a60b9bc:0000000000000000
21:42:30 ipsec,error phase1 negotiation failed due to time up. 77ef7ebbe6072755:0000000000000000
21:43:30 ipsec,error phase1 negotiation failed due to time up. 84b2038687046a7f:0000000000000000
21:44:30 ipsec,error phase1 negotiation failed due to time up. 42deffb07e877772:0000000000000000
21:45:30 ipsec,error phase1 negotiation failed due to time up. 51399cc76d9cf438:0000000000000000
21:46:30 ipsec,error phase1 negotiation failed due to time up. 06bded99cac5be7f:0000000000000000
21:47:40 ipsec,error phase1 negotiation failed due to time up. 89a97510102ce77c:0000000000000000
21:48:40 ipsec,error phase1 negotiation failed due to time up. 3f89e001a721cbab:0000000000000000
21:49:50 ipsec,error phase1 negotiation failed due to time up. 218823fc05c11ed0:0000000000000000
21:50:50 ipsec,error phase1 negotiation failed due to time up. b6863d33d03abd58:0000000000000000
21:51:50 ipsec,error phase1 negotiation failed due to time up. 56afaac137289cf2:0000000000000000
21:52:50 ipsec,error phase1 negotiation failed due to time up. 3ba12327f25ba182:0000000000000000
21:53:50 ipsec,error phase1 negotiation failed due to time up. 9772820fef218c03:0000000000000000
21:54:50 ipsec,error phase1 negotiation failed due to time up. e0f9cea084fc72f2:0000000000000000
21:55:50 ipsec,error phase1 negotiation failed due to time up. f699872d6c861076:0000000000000000
21:56:50 ipsec,error phase1 negotiation failed due to time up. d14bf652f5792b1d:0000000000000000
21:57:50 ipsec,error phase1 negotiation failed due to time up. 29f50f1bcfb494ed:0000000000000000
21:58:50 ipsec,error phase1 negotiation failed due to time up. 0d818de75296c237:0000000000000000
+1
now 3th try to upgrade... v6.19 stable for 3h and wait for specific reason to do downgrade into v6.4, I hope this release is truly stable.
Support file was send to MikroTik Support Team (I before enable logging ipsec as debug to memory).
Clauu
Re: v6.19 released
Sun Sep 28, 2014 12:05 pm
Ipsec errors here too, rb2011uias+6.19
> ipsec,error failed to get valid proposal.
> ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
> ipsec,error phase1 negotiation failed.
supout sent to mikrotik
miguelgoncalves
Re: v6.19 released
Mon Sep 29, 2014 12:54 am
I was about to deploy an RB450 as a router to an OOB management network where rock solid stability is a must. I will throw this RB450 in the trash and use another thing.
- Beta testing in a production environment is not for me.
- Reading a thread on a forum to determine if a stable version is really stable is not for me. It takes time. Time is money. With this development pattern MK is not that cheap.
Alternatives? I will be using pfSense on an ALIX board for this situation. For everything else: Cisco. It's expensive but it works! They publish firmware updates with small changes and they tell exactly what has been changed. The software version I am using in my ASAs is 8.4.7(22). They will stop providing corrections for the 8.4 line in March, 2016. This is 18 months away. This kind of information is required for a production environment. I don't understand MikroTik. I really don't.
Cheers,
Miguel
jarda
Re: v6.19 released
Mon Sep 29, 2014 10:37 am
I am willing to pay post fee if you would like to send it to me instead throwing it to trash.
vb101
Re: v6.19 released
Tue Sep 30, 2014 10:23 am
One effect that I experienced after upgrading from 5.25 to 6.19 on a RB951G and then restoring a backup file taken from another RB951G running 5.25 - routing & switching through the device was quite slow (5-7Mbit/sec), in the end the issue was resolved after reseting mac-address on master interface of the switch group, it seems that overriding mac address for the switch group interfaces was causing slow switching & routing.
steen
Re: v6.19 released
Tue Sep 30, 2014 6:02 pm
Cheers,
Miguel
Hello Folks!
We had to give up on MT devices in some situations due to two things, policy based routing and l2tp tunnels could not pass more than some megabyte of data till they simply stopped passing traffic. The lt2p MT devices is stuck in RoS6.7, which in our case is very many devices at all customer and company side offices.
The policy based rotuing devices where replaced with ASA5510, which works like a charm since years back. We do not like to be stuck in low versions, neither do we like to use the very big power consuming ASA5510 and catalysts switches, which also is expensive to buy and keep, but they do work.
However we have a success story with all MT wireless devices, they saved our company wireless business. The same goes for CRS 125 switches, they have been successfully implemented on our datacenter and replacing older cisco switches, but they do lack one cruical function and that is spanning tree, which makes them impossible to build redundant layer 2 network. For that we still uses cisco and hp switches.
But who knows, in some future even MT will fix policy based routing and that l2tp tunnel bug and implement spanning tree in CRS 125 swiches.
Overall, without Mikrotik devices, our company had been out of business years ago!
paoloaga
Re: v6.19 released
Wed Oct 01, 2014 3:18 am
One mandatory feature is Per VLAN Spanning Tree, which prevents us from switching old Cisco switches to CRS ones.
ste
Re: v6.19 released
Wed Oct 01, 2014 11:42 am
Now I run into a MPLS Problem with v6.19. After a connected bridge was updated/rebooted the bridged
network (even MPLS routers own address) is no longer reachable from our network. The route distributes
in ospf and LDP but packets do not get through. I cant repair it be disabling enabling the interface. Seems
I have to reboot the router and kick some hundred customers.
I am really pissed to debug all the time. Sent supout ...
aizhihuxiao
Re: v6.19 released
Wed Oct 01, 2014 12:18 pm
I found a bug when using routeros to be pptp client.
some problem cause pptp tunnel disconnected, but pptp client still hang in there. It will not reconnect automatic, I have to disable pptp client and enable again then it works.
zyzelis
Re: v6.19 released
Wed Oct 01, 2014 1:25 pm
Hello ste,
try to disable rstp on affected bridges. :)
ste
Re: v6.19 released
Wed Oct 01, 2014 2:25 pm
Hello ste,
There are bridges (physicaly) connected. The interface to this bridges is not bridged within ros.
So for sure no rstp problem.
ste
Re: v6.19 released
Thu Oct 02, 2014 10:34 am
A nightly reboot solved the problem ... for a while.
So there is a bug in MPLS which might be in a place near you ... soon.
sergejs
Re: v6.19 released
Thu Oct 02, 2014 12:34 pm
Users browsing this forum: DanMos79, dima, dsfak, dvdlss, lurker888, Marc1963, stef70, whernandez and 134 guests
