Morpheus1607
Syslog Server 4.0beta3
Thu Aug 28, 2014 2:27 pm
Does anyone use the Syslog Server on Dude?
i had enabled in on the Server, but nothing comes to Syslog
where will the Syslog from client go?
lebowski
Re: Syslog Server 4.0beta3
Tue Sep 02, 2014 6:40 pm
I have been using it, syslogs should be recorded into Program Files\Dude\data\files I believe all syslog entries are recorded into action log. If you want them accessible in the dude you need an entry in settings->syslog that is "log to syslog". I think that is the default.
If you have custom regular expressions separating syslogs you put them in before "log to syslog" and they will be logged into their own log file. Every Cisco log entry has a -X- where X is the severity so I created a separate log for each severity level.
Lebowski
Users browsing this forum: No registered users and 31 guests
