jarda
Re: CAPsMAN v2 ready for testing
Wed Dec 10, 2014 1:02 am
You should set roaming functionality on the clients to the more aggressive option.
ebreyit
Thu Dec 11, 2014 12:17 am
In multi-AP installations I've also been using the following to assist in nudging clients onto AP's whilst moving around.
In most scenarios it works great. Some applications might suffer from the sudden drop off though (VOIP).
Streaming has worked fine for me whilst jumping from one AP to another. Play with the signal ranges to find what works best.
/caps-man access-list
add action=accept client-to-client-forwarding=yes interface=all signal-range=-80..120
add action=reject interface=all signal-range=-120..-81
bleblas
Thu Dec 11, 2014 9:51 am
Re
yes i use access list but access list work only when client connecting to AP, not when it is connected and then signal making worses.
i use access list
and write some script to kick client with bed signal
:local MAXsignal "-78";
    :local capsClientId;
    :local capsClient;
    :local capsClientSignal;
    :foreach i in=[/caps-man registration-table find] do={
    :set capsClientId [/caps-man registration-table get $i];
    :set capsClient [/caps-man registration-table get $i mac-address];
    :set capsClientSignal [/caps-man registration-table get $i rx-signal];
    :if ("$MAXsignal" > $capsClientSignal) do={
    /caps-man registration-table remove $i;
    :log info "Caps script kick user $capsClient signal $capsClientSignal";
but it's not work perfect, some https session make disconnect and need re-logon and some business applications too
bleblas
ebreyit
Thu Dec 11, 2014 10:03 am
Hi bleblas
My experience is that if set correctly Access List will disconnect an existing client if signal drop below threshold if set correctly as per Wiki
You should be seeing log entries stating that a client has disconnected, signal too weak!
I then see it immediately register on the next AP (if there is one to goto)
http://wiki.mikrotik.com/wiki/Manual:In ... ccess_List
Warning: If there is no entry in ACL about client which connects to AP (wireless,debug wlan2: A0:0B:BA:D7:4D:B2 not in local ACL, by default accept), then ACL for this client is ignored during all connection time.
For example, if client's signal during connection is -41 and we have ACL rule
/interface wireless access-list
add authentication=no forwarding=no interface=wlan2 signal-range=..-55
Then connection is not matched to any ACL rule and if signal drops to -70..-80, client will not be disconnected.
To make it work correctly it is required that client is matched by any of ACL rules.
If we modify ACL rules in previous example to:
add interface=wlan2 signal-range=-55
add authentication=no forwarding=no interface=wlan2 signal-range=..-56
Then if signal drops to -56, client will be disconnected.
bleblas
Thu Dec 11, 2014 10:19 am
hi ebreyit
no way, i test it on 6.23 capsman v2 9-12-2014 , and access list works only when you connecting ..
and faster testet on capsman 1 on 6.22,6.23-rc
add access list
add action=reject interface=all signal-range=-120..-70
connect with good signal 120..-60 and then go away then signal go to -76 and worses
bleblas
ebreyit
Thu Dec 11, 2014 10:32 am
Hi bleblas,
If that is your only access list rule then it's not complete.
As per the wiki and my code example you need to include an accepting rule first so that the client is included in the connected clients ACL, once there it can then be controlled by further rules which will disconnect clients when the signal drops too low.
I have this running on a couple of networks al now using 6.23 and all working as expected
hi ebreyit
add access list
bleblas
bleblas
Thu Dec 11, 2014 10:37 am
re
i have access rule but it was secend, i change to first accept and then reject and check.
thx
bleblas
ebreyit
Thu Dec 11, 2014 10:40 am
Great, that should work for you once switched as the list operates top to bottom.
re
thx
bleblas
bleblas
Sat Dec 13, 2014 12:48 am
Hello
Today i test this configuratins of access list and it is work nice
It's disconnect with week signal
Thx for help
Bleblas
hadyatef
Sat Dec 27, 2014 11:10 am
Hi All
As I have a project need 55 Access points controlled by Access point controller
i like to do it with CAPsMAN facility of mikrotik RouterBOARD
my question is which is the suitable Access point can i use in my project?
I read something about a new Mikrotik APs is that true ? is it efficient?
can i use any of TP-Link products ? which kind?
nuru
Sat Dec 27, 2014 12:38 pm
hadyatef.
TP-Link can only work as a normal CPE in a Mikrotik CAPsMAN configured network.
The AP (CAPs) you can use for Mikrotik WLAN controller (CAPsMAN) has to be a RouterOS powered AP, but you will want to use Mikrotik AP for compatibility reasons.
The space you want to cover will usually determine the type of AP you want to use.
For the WLAN controller (CAPsMAN), almost any Mikrotik router can be used as the WLAN controller, but you need to consider the CPU and memory of the router because that will determine the numbers of AP (CAPs). CPE, user and traffic that the WLAN controller will be able to handle.
Another thing to note is all Mikrotik device must have a post 6.14 RouterOS but you will want to go for the latest RouterOS, there has been a lot of improvement and bug fixes after 6.15. Remember also that CAPsMAN V1 is not compatible to CAPsMAN V2.
Hope this help
hadyatef
Sat Dec 27, 2014 7:29 pm
hadyatef.
Hope this help
nuru
thx for yr repky
you put ne in the right way
can you give a recommendation of MT AP types you suggest
nuru
Sun Dec 28, 2014 10:44 am
hadyatef.
Hope this help
nuru
thx for yr repky
Like I said before, a lot of things will determine what type of AP you want to use. About all Mikrotik AP will do, as long as it has the right RouterOS version.
Is the area you want to cover a close space or an open space?
What is the nature of obstruction along the signal propagation path?
How far are your CPE or client from the AP?
What bandwidth are you looking at?
I use Basebox 2 & Basebox 5`with Ubiquiti Airmax antenna for Outdoor open space. The Ubiquiti Antenna are quite pricey, you may want to use Mikrotik AP with SISO that requires cheaper antenna, but will lack the performance, signal quality and bandwidth of a MiMo systems.
And RB951 for indoor. Just bought some cAP 2n about two weeks ago but not installed yet.
Nurudeen
avenn
Wed Dec 31, 2014 6:28 pm
Currently getting to grips with CAPsMAN2.
I've been experimenting with channel allocation and setting them to "auto" / blank.
At the moment the auto frequency option selects any channel (1 to 11) and this can lead to AP channel overlap (using 20 MHz channels). It appears as though as long as there is no overlap/interference with the 5 MHz centralish channel it will allocate the next one along.
Therefore in the 2GHz frequency range I only want the auto frequency to select from channels 1, 6 and 11.
From memory I need to create a scan-list that includes 2412, 2437, 2462. I expect this to prevent the overlap problem - to an extent.
However in CAPsMAN2 I don't seem to be able to choose scan list is an option?
Is this not a feature? Perhaps I'm looking at it from the wrong angle?
Can anyone help?
Regards
Aidan
redbullsteve
Fri Jan 02, 2015 7:31 pm
Can anyone help?
Regards
Aidan
This is a feature that I think needs to be added, I have the same problem, I raised it a while ago but Mikrotik don't seem to understand the requirement and think the way it is currently implemented is the way forward.
I want to be able to select the channels used as per the scan list.
avenn
Fri Jan 02, 2015 11:37 pm
hi redbullsteve,
thanks for reply.
that's a shame and disappointing. I would consider this to be a regression not progression.
perhaps they will add it later and just forget to tell us!
Regards
Aidan
Zwodka
Sun Jan 11, 2015 10:34 am
Hi All!
When I add a new Interface there are two MAC: "mac-address" and "radio-mac".
What is the difference?
Z,
22hn
Sun Jan 11, 2015 5:20 pm
Feature request
On CAPsMAN "Registration Table" tab, I would like to have a column for CAP identity and SSID.
EDIT: Found out that SSID is only missing in winbox 3...! In the older version it's there...!
Lansman
Mon Jan 12, 2015 10:28 am
Wireless-cm2 package can be downloaded from the Mikrotik download page under release candidate:
http://www.mikrotik.com/download[/quote]
Sorry. I have been looking for a package called Capsman, or wireless-cm2, or anthing else that might be it.
Where do I find it? I seem to have found one for PPC, but the computer is a Routerboard. wireless-cm2-6.25rc5-ppc.npk Will that work in a Routerboard? I guess I sometimes just do not get it.
normis
Mon Jan 12, 2015 10:31 am
Here it is:
PPC is a type of RouterBOARD. You must choose the appropriate system type, MIPS or PPC or other
Lansman
Tue Jan 13, 2015 10:41 am
Thank you. Oh... stupid me... one extra click did it. :? Thank you.
chechito
Tue Jan 20, 2015 7:26 am
to improve roaming and client behavior its very important the ability to control datarate set
the day capsman can do it the results will be much better.
acl method its very imprecise
StubArea51
Trainer
Trainer
Tue Jan 20, 2015 8:22 pm
Just curious how many APs CAPsMAN is designed to support? How many have been tested by MT?
uldis
Wed Jan 21, 2015 1:22 pm
we have seen customers that manage more then 600 cap interfaces on one CAPsMAN.
lunchboxrts
Thu Jan 22, 2015 5:06 am
Having a serious issue with capsman v2. radios are rb912's running the current version 6.25(started with the first beta of v2). we have carts of hp stream 11 with realtek wireless cards, when more than ~10-15 connect to a single access point the throughput drops to almost nothing and the client begin to drop off. this happens without transferring data just connected. when i disable capsman and run the ap unmanaged the issue mostly goes away. the client chipset is rtl8723be, i know your going to say its the realtek but this does not happen on my meraki ap's(trying to get away from meraki)
The capsman controller is a ccr1009 and caps devices are running in local forwarding mode. it appears that the capsman is having an issue with the keeping up with the clients.
uldis
Thu Jan 22, 2015 10:11 am
please make a support output file from CAPsMAN and that CAP when you see this problem and then send them to support@mikrotik.com
Also provide what wireless configuration you use when you do not use CAP.
StubArea51
Trainer
Trainer
Fri Jan 23, 2015 1:20 am
That's great...what platform were they using for the CAPsMAN?
uldis
Fri Jan 23, 2015 4:51 pm
If I remember correctly than it was CCR1009.
czolo
Fri Jan 23, 2015 10:20 pm
We just have finished our third installation with Capsman, and we have some ideas:
1) Radius server should be cofigured for specific interface, like in hotspot, where I can chose a domain for a hotspot and than setup radius for a specific domain. In access-list it will be useful to have automated config for a specific authentication type. Now I have to choose interface from a list every time after update of the name. It can be more automarted
2) In registration all information should be visible like in normal mode (last-ip, routeros version etc.)
3) you should explain how regexp in names is working. MT gave us an option, bot nobody write an update to wiki. I want to see the interface with specific config with a specific name, now it's impossible. The same situation on CAP side - all interfaces have name wlan1,wlan2... - it should be the same name like in capsman.
avenn
Fri Jan 23, 2015 10:30 pm
Plus 1 for czolos suggestions
leoktv
Trainer
Trainer
Sun Jan 25, 2015 11:28 pm
I have been running 250 interfaces with caps-man and plus 800 clients online this was done with a ccr1009-8G-1S
bartjoo
Mon Jan 26, 2015 11:31 am
Question1:
i want to auto provision with the auto provision tab. But it dont work :(
I connect the AP with the CAPsMan. That works. When i put the CFG in the CAP on tabblad INTERFACE, it works.
But when i go to tab Provisioning, and make a new rule, it dont work on the interfaces. :(
Someone could tell me why?
In the attachment my settings.
I tried, Create Dynamic enabled and Create enabled.
I tried also with the radio MAC (not 00:00:00:00:00:00).
Question 2,
I have some AP's at restaurants. But they have a managed SSID (my SSID) and his own SSID for Local connections.
Is it possible to make with CAPsMan 1 managed and 1 unmanaged SSID. OR 2 managed but 1 of this is connected to the bridge on the clients side. ?
tnx for helping!
tnx for help.
bartjoo
Mon Jan 26, 2015 1:50 pm
Ah! The provisioning works! i had to delete the Interfaces.
now i will try the local forwarding.
i found this document.
http://file.accesspoint.hu/pdf/uldis.pdf
greetz
SubOrbit
Tue Jan 27, 2015 12:21 am
I have a RB751U-2HnD with ROS v6.25 and I cannot get CAP to connect to CAPsMAN, even if the capsman is on the same routerboard.
Identical configuration (without the 127.0.0.1 IP address) works like a charm on RB951G-2HnD. I would eventualy like the 751 to connect to the capsman on the 951, but since even a local connection doesnt work, I guess the problem in somewhere on the 751 board.
I have reset the board to defaults, set a local IP on the ether1 interface, added ether1 to bridge-local and disabled NAT, all firewall rules and DHCP server. Those are the only changes I have made from the default configuration.
I then enabled CAPsMan and CAP (see screenshot), but the connection is never established.
Any suggestions? Thanks!
JasonEde
Tue Jan 27, 2015 10:22 am
Did you manage to narrow down cause of your problem? We're about to roll out 912's for our radio on a 1100AHx2 capsman
uldis
Tue Jan 27, 2015 10:50 am
SubOrbit,
try to remote the CAPsMAN Name and Certificate common name and then check again if it establishes connection.
Also enable the caps,debug and wireless,debug logging so you would see the results of the CAPsMAN selection and some other debug logs.
SubOrbit
Tue Jan 27, 2015 12:49 pm
SubOrbit,
I have removed capsman name and certificate common name and enabled caps,debug and wireless,debug. CAP discovery finds CAPsMAN, but after CAP Discover > Select, it says it did not find a suitable CAPsMAN (see screenshot)
SubOrbit
Tue Jan 27, 2015 2:44 pm
To answer my own question: my CAPsMAN names was wrong and when I removed the name, I did not disable the field (the capsman names field was still white), you have to disable the field (it has to be greyed out).
Everything is running smoothly now. Thanks!
bartjoo
Wed Jan 28, 2015 8:39 am
for me everything works now. local and forwarding.
another question, is it possible to use a variable for the SSID?
like: SSID: Test_[Identity] ?
Greetz
Bart
izytech
Wed Jan 28, 2015 8:43 pm
Is it possible to get information on which cap-interface a wireless client is connected to when using radius accounting? Perhaps in username field or in any other field if its possible. When using quite a lot of remote CAP it would be nice to collect som statistics over usage per remote cap.
Perhaps like this in username field
MACHW@CAPINTERFACENAME
Best regards,
Thomas
bartjoo
Thu Jan 29, 2015 9:42 am
Hello, another question. I made a FORWARDING bridge and it works fine.
But when i do a scan on this forwarding network, i found my apple tv airplay on the local network. How is this possible? This is a different network (or isnt?)
tnx for your help.
uldis
Thu Jan 29, 2015 1:34 pm
if your cap interface in the full forwarding mode is in the bridge port with your local network then you will be in the same local network where you wireless clients are connected.
bartjoo
Thu Jan 29, 2015 1:39 pm
I tried both.
with and without the local bridge. in both options airplay is there.
My config is:
AP1 - FULL Forwarding to datacenter (VPN), this is my hotspot (10.5.50.0/24)
AP2-virtual LOCAL FORWARDING with local bridge. (192.168.1.0/24) in the CAP MENU from the AP.
When i connect to AP1, i dont want to see thing on the local network. (like airplay).
When i connect to AP2, i want to see apple tv.
I tried also:
CAP MENU, disable local bridge. Only full forwarding. But i can activate Airplay also with AP1.
Do i need to work with VLAN?
uldis
Thu Jan 29, 2015 3:18 pm
AP1 and AP2 isn't in the same bridge? If not then you should not see the AP2 devices from the AP1.
msport
Thu Jan 29, 2015 9:36 pm
Hi
Have been testing capsman, and it has some almost good enough features that we like, but is lacking in others:
We have a "big" network of 5Ghz AP's, all with their own ssid. Many stations use static ssid and as centralized CPE management is not possible, it is difficult to fix.
What I tought we would get with capsman, for starters:
Centralized management of radios. Feks, setting no ssid, cause all radios in group to use what is locally defined. (same principal on all settings basically)
Mac only authentication of clients (cpe's). Looks like capsman has this, but lack of features is not making it possible to use.
Centralized management of CPE related stuff. Signal, software upgrades etc.
Is this something that may happen sometime?
BR
Kim
bartjoo
Thu Jan 29, 2015 11:00 pm
Hmm, i thought i know the problem. But its not. it dont work :(
connected with the hotspot, i found the 192.168 adresses with a scanner :(
bartjoo
Fri Jan 30, 2015 11:53 am
Hmm, i think i found something.
Even if i dont have a wifi connection, its possible to remote my apple tv.
so, its not a problem / question for capsman. sorry!
So, i will test capsman further. tnx for helping!
juanvi
Fri Jan 30, 2015 5:36 pm
Hi to all,
We have a all-in-one solution with radius(usermanager) for hotspot and wireless clients thanks to capsman. Features like CoA for wireless and EAP authentication using username/password for UserManager are missing but are in mikrotik's to-do list. With alternatives and some scripting we are doing the job almost fine.
We are very happy with capsman since we have 108 SSID's (54 radios) working as hotspot and wifi AP but there is a capsman feature i'm missing because clients can't connect in high density wi-fi zones. I'm aplying several methods for improving performance but there is a problem because we can not disble low wi-fi data rates. I can not disable only 802.11b too. Can't optimize the airtime utilization if we are allowing oldest modulations and 1Mbps data rates. Only option is allowing 802.11n ONLY and lower data rates are allowed anyway.
Can anyone tell me if this proposal would be effective ? Should be implemented ?
PD: We will use capsmanv1 until changes "test" to... at least "RC"!!! K'mon Mikrotik
JasonEde
Mon Feb 02, 2015 4:30 pm
We're finding that users keep getting disconnected (temporarily) and the throughput isn't that good (we've had 7Mbps x 2Mbps when we've a 100Mbps feed into our office). We're running capsman on an 1100AHx2 and the CAPs on RB912 (we've 2 of them). Everything is on RouterOS 6.23.
We've the access connection rules mentioned above to reject weak signal. The people getting disconnected are literally 3m-4m away from the access point.
uldis
Mon Feb 02, 2015 4:50 pm
Please upgrade to v6.25 with CAPsMAN v2 and check again.
Also check the wireless/caps debug logs for those disconnection reasons.
JasonEde
Mon Feb 02, 2015 4:53 pm
Will upgrade and try again. Where is the Capsman changelog? Doesn't look like it is part of the main changelog.
JasonEde
Tue Feb 03, 2015 10:28 am
All units are now running on 6.25 and I'm still seeing a lot of disconnects and moving between APs. Sample of the logs are below. All these devices are stationary in the building...
08:22:03 caps,info 74:E2:F5:22:12:67@AP2-Net1 connected
08:22:03 caps,info 74:E2:F5:22:12:67@AP1-Net1 disconnected, registered to other interface
08:22:07 caps,info 9C:04:EB:31:9B:BF@AP1-5GHz-Net2 connected
08:22:19 caps,info 9C:04:EB:31:9B:BF@AP1-5GHz-Net2 disconnected, too weak signal
08:23:23 caps,info F4:1B:A1:9A:19:0A@AP1-Net1 connected
08:23:29 caps,info F4:1B:A1:9A:19:0A@AP1-Net1 disconnected, 4-way handshake timeout
08:23:30 caps,info C8:85:50:6C:11:0B@AP1-Public-5G connected
08:23:30 caps,info C8:85:50:6C:11:0B@AP2-2.4GHz-Public disconnected, registered to other interface
08:23:31 caps,info C8:85:50:6C:11:0B@AP1-2.4GHz-Public connected
08:23:31 caps,info C8:85:50:6C:11:0B@AP1-Public-5G disconnected, registered to other interface
08:23:37 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 connected
08:23:40 caps,info B8:E8:56:76:05:C3@AP2-5GHz-Net2 connected
08:23:40 caps,info B8:E8:56:76:05:C3@AP1-5GHz-Net2 disconnected, registered to other interface
08:23:43 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 disconnected, too weak signal
08:23:46 caps,info B8:E8:56:76:05:C3@AP2-5GHz-Net2 disconnected, too weak signal
08:23:48 caps,info B8:E8:56:76:05:C3@AP1-5GHz-Net2 connected
08:23:50 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 connected
08:23:54 caps,info C8:85:50:6C:11:0B@AP1-2.4GHz-Public disconnected, extensive data loss
08:23:56 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 disconnected, too weak signal
08:24:05 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 connected
08:24:08 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 disconnected, too weak signal
czolo
Fri Feb 06, 2015 4:24 pm
I have a question, why I can't configure vlan-mode on virtual-ap?
I can set it in normal mode only for master wlan card. If I'm using capsman, I can put a traffic from specific slave vap into a vlan. So why this funcionality is not accesible in normal mode for manualy created vap?
sguox
Trainer
Trainer
Sat Feb 14, 2015 9:27 am
is there any plan to support station bridge?
JanezFord
Mon Feb 16, 2015 10:23 am
+1 for Last-IP
I would also like to see RT/TX CCQ and signal-to-noise.
Anyone knows how to set WMM, HW Protection Mode, Preamble Mode, HW Retries and other advanced mode parameters with CAPsMAN v2 ? If it is not yet possible does anyone know if there are any plans to add these configuration options to CAPsMAN v2 in the future?
JF.
Zwodka
Thu Feb 19, 2015 8:27 am
I plan to by a RB911G-2HPnD and a RB911G-5HPnD for AP. But they have Licence Level 3 : no Wireless AP permitted :-(
But what about in CAPsMAN configuration?
I mean:
- one Licence Level 4/5/6 RB as CAPsMAN,
and
- RB911G-2HPnD/-5HPnD serie as CAP device.
juanvi
Thu Feb 19, 2015 10:12 am
I mean:
and
I'm not sure but i think is the same for CAPSMAN. At the end you have one ap and is remotelly controlled.
I think you need L4 license to have more tan one client in local or CAP (ptp link is allowed with L3 license).
I've buyed 2 SXT Lite2 and are L3. They say: "SXT Lite2 is a low cost, high transmit power 2.4GHz (2312 -2732MHz depending on country regulations) outdoor wireless device. It can be used for point to point links or as a CPE for point to multipoint installations"
Anyway not tried yet but i've readed ptp is posible with L3 and bridge/station bridge mode.
I'm not 100% sure. Only logic answer.
uldis
Thu Feb 19, 2015 7:30 pm
you need RouterOS Level 4 licenese to make a board as a CAP AP.
Level 3 license is only for point-to-point pinks.
Station-bridge mode is not supported with CAPsMAN at the moment.
Zwodka
Fri Feb 20, 2015 8:13 am
Thanx for the answer!
juanvi
Fri Feb 20, 2015 10:45 am
I mean:
and
Uldis said: "you need RouterOS Level 4 licenese to make a board as a CAP AP.
Level 3 license is only for point-to-point pinks."
I do not understand why an L3 AP with one client (ptp) is possible and the same, but remotelly controlled, is not possible.
Can you explain please?
Uldis said: "Station-bridge mode is not supported with CAPsMAN at the moment."
CAP=Controlled Access Point
CAPsMAN= Manager for Controlled Access Points
Looking for "Controlled STATION" ??? CSTA??? And his manager... CSTAsMAN...
What sense has this???
Today do not understand anything. ;-)
uldis
Fri Feb 20, 2015 1:06 pm
Currently CAPsMAN is not designed for management of the WISP APs as it doesn't support Bridge mode that is required for Station-Bridge and WDS that is required for the Station-WDS.
We might add those features later when we have finished the rest of the CAPsMAN planned features.
juanvi
Wed Feb 25, 2015 6:39 pm
Ok. I understand you now but, this is an option for a inadvisable full bridged network. Broadcast domain becomes huge and have their pants down for a broadcast storm. Best route at CPE and isolate your network from client's broadcast. Ap mode under CAPsMAN would be advisable. I'm right?
bartjoo
Fri Feb 27, 2015 9:43 am
Hello, Is there a list available with the (roadmap) new features?
hngjared
Tue Mar 03, 2015 9:26 pm
I'm just starting to demo the CAPsMANv2.
When I remove the CAPsMAN from the network for a few seconds and reconnect my APs(CAPS) do not reconnect unless I reboot or disable/re-enable the CAP in the wireless interface of the AP.
Is this normal? Is there a setting I'm missing that allows the units to sync back together after a brief interruption?
I appreciate any feed back.
bartjoo
Tue Mar 03, 2015 9:28 pm
No, this is not correct. When he gets a connection with CAPsMAN again, he will send the WiFi signal again.
hngjared
Tue Mar 03, 2015 9:48 pm
I appreciate the quick response.
My problem is I unhooked the CAPsMAN controller from the LAN for about 30 seconds and plugged it back up. Once plugged back in the access points never sync back with the controller? You'd think this would happen quickly and automatically. But, I'm unable to get the units to SYNC back with the controller unless I reboot or disable/re-enable the CAP on the AP.
Worst case scenario. My controller drops offline for 5 minutes. Would I be required to go around and reboot 200 APs to regain sync to the controller? Do I need to implement a script to disable/re-enable the CAP. How do other people get their equipment to regain access to the controller?
Thanks!
bartjoo
Tue Mar 03, 2015 9:51 pm
Thanks!
could you tell more about your infrastructure and mikrotik OS / Capsman version?
hngjared
Tue Mar 03, 2015 9:58 pm
I'm working in a testing environment with a very basic layout.
I'm using the latest version of Router OS and CAPsMANv2 on 6.27.
I have a 5 port RB450G gateway connected to a 5 port 750UP POE switch powering 4 RB912UAG-2HPnD APs. I have the 450G acting as the controller for the 4 APs.
Everything works fine until the AP loses connection to the controller for as little as a few seconds. After that the AP never re-establishes a connection back to the controller.
Thanks!
bartjoo
Fri Mar 06, 2015 9:52 am
Thanks!
Hmm, could you upload a image of your settings for CAPsman?
or your settings file from your main and client routeR?
uldis
Fri Mar 06, 2015 11:00 am
are you using wireless-fp package or wireless-cm2 package?
The CAPs are connected to CAPsMAN via MAC connection or IP connection?
hngjared
Fri Mar 06, 2015 4:21 pm
Using wireless-cm2 package and connected via MAC.
Very basic created Config and applied to the CAP when it showed up in the interfaces.
Again, everything works fine until the CAP disconnects from the controller. There after it will not reconnect until the CAP is disabled/re-enabled or the AP is power cycled.
Thanks!
bartjoo
Fri Mar 06, 2015 4:22 pm
Thanks!
could you try it with IP addresses? I work with IP's and it works fine.
hngjared
Fri Mar 06, 2015 5:13 pm
Thanks!
I tested for a bit longer. I originally tested with only the CAPsMAN Address (IP) configured in the CAP. Once I added the CAPsMAN Name everything started syncing immediately after reconnecting to the network.
Not sure why the IP address wasn't working but we'll take it.
chechito
Sat Mar 28, 2015 7:22 pm
CAPsMAN is mostly meant for managing of access points in hotels, homes, apartments, offices etc. the clients in these places are windows and mac laptops, phones etc.
I thing, you need more work about fast roaming in capsman 2
Wifi device need to lost of signal on cap1 to connect another cap2, but wifi device can work long time with cap1 on signal -89 even the cap2 is closer with signal -40
bleblas
one solution is manipulating datarates, disabling slower datarates client jump to another AP before reaching such lower signal level.
but capsman not allow manipulating datarates, its the main reason because i dont use capsman
chechito
Tue Mar 31, 2015 4:40 am
i note the same result using acl to disconnect weak signal clients, i think client signal strength fluctuate a lot and generates false positives on the acl.
I encountered disabling lower datarates a more effective strategy to disconnect weak signal clientes before they degradate performance of the AP, its the main reason i dont use CAPSMAN, because CAPSMAN NOT SUPPORTS DISABLING DATARATES ON RADIOS :( :( :(
chechito
Thu Apr 02, 2015 1:04 am
testing package on rb951g
without connecting to CAPSMAN
slower wifi performance and random disconnects
ros 6.27, firmware 3.22
rolling back to wireless-fp :?
uldis
Thu Apr 02, 2015 7:31 pm
Please contact support@mikrotik.com about this problem and also tell us how you are measuring the performance.
popovdv
Thu Apr 16, 2015 7:17 pm
Please add feature to CapsMan controller to see what frequency using remote CAP
avenn
Fri Apr 17, 2015 6:32 pm
Feature update please:
When will scanlist and registration table with frame + hw-frame details be implemented in CAPsMANv2.
We need to be able to adpat more to layer 1 and monitor layer 2 as you can when AP standalone.
The lack of these features is a signiifacnt regression especially for a large scale implementation.
Regards
Aidan
JasonEde
Sat Apr 18, 2015 9:42 am
On 6.27 (ppc on 1100AHx2) with CM2 enabled if I try and get the OID list for snmp monitoring I can see...
/caps-man registration-table> print oid
0 ;;; Accept connections if signal stronger than -80
mac-address=.1.3.6.1.4.1.14988.1.1.1.4.1.1.16.104.63.132.124.142.85
uptime=.1.3.6.1.4.1.14988.1.1.1.4.1.3.16.104.63.132.124.142.85
tx-bytes=.1.3.6.1.4.1.14988.1.1.1.4.1.4.16.104.63.132.124.142.85
rx-bytes=.1.3.6.1.4.1.14988.1.1.1.4.1.5.16.104.63.132.124.142.85
tx-packets=.1.3.6.1.4.1.14988.1.1.1.4.1.6.16.104.63.132.124.142.85
rx-packets=.1.3.6.1.4.1.14988.1.1.1.4.1.7.16.104.63.132.124.142.85
tx-rate=.1.3.6.1.4.1.14988.1.1.1.4.1.8.16.104.63.132.124.142.85
rx-rate=.1.3.6.1.4.1.14988.1.1.1.4.1.9.16.104.63.132.124.142.85
tx-signal=.1.3.6.1.4.1.14988.1.1.1.4.1.10.16.104.63.132.124.142.85
rx-signal=.1.3.6.1.4.1.14988.1.1.1.4.1.11.16.104.63.132.124.142.85
However, a snmpwalk or snmpget for these yields nothing... Does this work for anyone?
Edited to add... I've just managed to browse this..
iso.3.6.1.4.1.14988.1.1.1.5.1.1.16.104.63.132.124.142.85 = Hex-STRING: 10 68 3F 84 7C 8E
iso.3.6.1.4.1.14988.1.1.1.5.1.3.16.104.63.132.124.142.85 = Timeticks: (7145200) 19:50:52.00
iso.3.6.1.4.1.14988.1.1.1.5.1.4.16.104.63.132.124.142.85 = Counter32: 5326
iso.3.6.1.4.1.14988.1.1.1.5.1.5.16.104.63.132.124.142.85 = Counter32: 7354
iso.3.6.1.4.1.14988.1.1.1.5.1.6.16.104.63.132.124.142.85 = Counter32: 51
iso.3.6.1.4.1.14988.1.1.1.5.1.7.16.104.63.132.124.142.85 = Counter32: 59
iso.3.6.1.4.1.14988.1.1.1.5.1.8.16.104.63.132.124.142.85 = Gauge32: 13000000
iso.3.6.1.4.1.14988.1.1.1.5.1.9.16.104.63.132.124.142.85 = Gauge32: 58500000
iso.3.6.1.4.1.14988.1.1.1.5.1.10.16.104.63.132.124.142.85 = INTEGER: 0
iso.3.6.1.4.1.14988.1.1.1.5.1.11.16.104.63.132.124.142.85 = INTEGER: -59
This looks like the data I'm looking for, but is on 1.1.1.5 not .4 as reported above. Is that a mistake in what is reported when you do print oid?
ivicav
Mon Apr 27, 2015 6:48 pm
I set one pair of RB 951G-2HnD in production but I have a bunch of issues here. Here is my log:
17:38:57 caps,info 84:63:D6:98:85:0C@cap3 disconnected, extensive data loss
17:38:58 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:06 caps,info 00:BB:3A:F6:70:02@cap6 connected
17:39:12 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:12 caps,info 00:BB:3A:F6:70:02@cap2 connected
17:39:16 caps,info 00:BB:3A:F6:70:02@cap2 disconnected, received disassoc: sending station leaving (8)
17:39:20 caps,info 00:BB:3A:F6:70:02@cap6 connected
17:39:26 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:26 caps,info 00:BB:3A:F6:70:02@cap2 connected
17:39:30 caps,info 00:BB:3A:F6:70:02@cap2 disconnected, received disassoc: sending station leaving (8)
17:39:34 caps,info 00:EE:BD:AB:4D:93@cap5 connected
17:39:35 caps,info 00:EE:BD:AB:4D:93@cap3 disconnected, registered to other interface
17:39:35 caps,info 00:BB:3A:F6:70:02@cap6 connected
17:39:41 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:41 caps,info 00:BB:3A:F6:70:02@cap2 connected
17:39:47 caps,info 00:BB:3A:F6:70:02@cap2 disconnected, 4-way handshake timeout
17:40:03 caps,info CC:89:FD:A8:90:CC@cap6 connected
17:40:09 caps,info CC:89:FD:A8:90:CC@cap6 disconnected, received disassoc: unspecified (1)
17:40:13 caps,info CC:89:FD:A8:90:CC@cap5 connected
17:40:18 caps,info CC:89:FD:A8:90:CC@cap5 disconnected, received disassoc: unspecified (1)
17:42:09 caps,info CC:89:FD:A8:90:CC@cap6 connected
17:42:14 caps,info CC:89:FD:A8:90:CC@cap6 disconnected, received disassoc: unspecified (1)
17:42:19 caps,info CC:89:FD:A8:90:CC@cap5 connected
17:42:23 caps,info E8:99:C4:B7:15:5E@cap2 disconnected, received disassoc: sending station leaving (8)
17:42:24 caps,info CC:89:FD:A8:90:CC@cap5 disconnected, received disassoc: unspecified (1)
17:44:15 caps,info CC:89:FD:A8:90:CC@cap6 connected
17:44:20 caps,info CC:89:FD:A8:90:CC@cap6 disconnected, received disassoc: unspecified (1)
17:44:25 caps,info CC:89:FD:A8:90:CC@cap5 connected
17:44:30 caps,info CC:89:FD:A8:90:CC@cap5 disconnected, received disassoc: unspecified (1)
As you can see there is lot of drop outs. Clients keep disconnected sometimes after few minutes, sometime after few seconds... And some of clients are OK.
telipcomx
Tue May 05, 2015 5:29 am
Hi I was used capsman v1 with rb1100 and arround 40 hotspots with rbmetal or groove, my expience is bad all y clients have a problems with "radius server not responding" or "username or password not found" and the clasic "your account is use now" , this version have solution for this problems
thanks
hengst
Thu May 07, 2015 4:57 pm
Any news about :
- live auto frequency selection per AP ( based on live Spectrum , without having enable/disable interface )
- auto Tx-power control ( based on own neighbour Ap's )
or is this already build in at the moment ?
avenn
Fri May 08, 2015 1:14 pm
Any news about :
+100000
chechito
Fri May 08, 2015 6:52 pm
Any news about :
ok lets take other brands marketing to the reality:
to do that you request its necessary a second radio on the ap for the only purpose or spectrum analysis and neighbor monitoring.
Automatic spectrum analysis requires a development beyond the actual scope of ROS.
Some people like all in life to be automatic but it has associated costs.
i will be happy with datarates and ht mcs manageable from CAPsMAN its the only thing prevents me from using CAPsMAN
hengst
Mon May 11, 2015 1:02 pm
maybe better id is to let the Ap create its own little statistics database in some time about freq / neighbours / CCQ etc. and let the Ap make a decision of what settings to use based on statistical information over some time.
In time it would tune itself to the best setting available on the location if set to "auto config". or for those how like to be in control, let capsman notify you the Ap probably could perform better on channel X with setting X , and you could click a provision button to make it real.
NetworkMeister
Sat May 16, 2015 11:28 am
I have constant problems with certificates when running CAPsMAN and CAP on the same router. Whenever I do a fresh configuration, issue new CA & certificates and join local CAP to CAPsMAN on the same router, things work fine. However, after reboot of the router, I am starting to get certificate errors. Apparently CAP is trying to locally install Certificates it gets from CAPsMAN, but fails to do so, since the certificates are already installed (well, it's the same router!). This process keeps repeating for about 2 days, until router runs ouf of memory and reboots :) I have no problems with CAPs that connect from other routers.
I have set local CAP configuration to Certificate: none, but the issue remains.
Any idea?
wombat
Mon May 18, 2015 9:27 pm
Hi!
Where can I get package of CAPsMan v2 for 6.29 (RC20)? in all_files is not there..
Thank you.
karlisi
Tue May 19, 2015 10:20 am
Hi!
Thank you.
http://www.mikrotik.com/download/share/ ... mipsbe.npk
Change "mispbe" with you router architecture.
solaoxo
Wed Jun 10, 2015 9:20 pm
When CAPsMAN v2 switch latency, no better than the switched wds, wds truly seamless switching.
Cornmeister
Mon Jun 22, 2015 1:37 pm
When I take a look at the logs, I see a lot of MAC addresses for all connecting clients.
is it possible to enter a description for these addresses to identify them ?
something like
12:08:15 caps,info IPhone6_A@AP_Switchruimte connected
12:08:21 caps,info IPhone6_A@AP_Woonkamer_Pa_en_Ma connected
12:08:21 caps,info IPhone6_A@AP_Switchruimte disconnected, registered to other interface
12:13:05 caps,info Samsung_Tab@AP_Switchruimte connected
12:26:38 caps,info Laptop@AP_Switchruimte connected
12:26:38 caps,info Laptop@AP_Woonkamer_Pa_en_Ma disconnected, registered to other interface
12:32:10 caps,info Laptop@AP_Woonkamer_Pa_en_Ma connected
12:32:10 caps,info Laptop@AP_Switchruimte disconnected, registered to other interface
instead of
12:08:15 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte connected
12:08:21 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma connected
12:08:21 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte disconnected, registered to other interface
12:13:05 caps,info D4:F4:6F:9B:EB:9A@AP_Switchruimte connected
12:26:38 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte connected
12:26:38 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma disconnected, registered to other interface
12:32:10 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma connected
12:32:10 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte disconnected, registered to other interface
Beone
Trainer
Trainer
Sat Jun 27, 2015 3:58 pm
For mobile wireless device compatibility reasons (the wireless goes on/off everytime they go into standby) i need to change the WPA2 group-key timeout to something higher; to something like an hour as example
It seems it is currently not possible to set the group-key timeout in capsmanv2? (tested up to V6.30rc22)
Is this functionality planned to be added? (it is required to avoid continuous disconnects for mobile clients)
juanvi
Mon Jun 29, 2015 10:22 am
Why cannot v1 CAPs connect to v2 CAPsMAN or vice-versa? Aren't CAPsMAN v1 and v2 both RFC5416 (CAPWAP) compliant?
-- Nathan
Answered in post 13 of the first page of this thread:
"CAPsMAN v2 is not capwap compliant due to limitations of capwap protocol"
juanvi
Mon Jun 29, 2015 10:29 am
Very interesting, could someone share info about how this "improved logging entries when client roams between the CAPs"
Info like: "MAC XX:XX:XX:XX:XX:XX on CAP X disconnected, registered to other interface" will be displayed. This question was already answered in the 8th post of this thread. You can read all first if you have more questions.
Zwodka
Wed Jul 01, 2015 12:11 pm
Hi All,
I use CAPsMAN and it works "fine". But when I change Cap-Interface -> Channel -> Band to "2ghz-onlyn" the interface shows me:
- managed by CAPsMAN
- channel 2432/20/gn(20dBm)
gn? Why?
uldis
Wed Jul 01, 2015 12:42 pm
It shows GN because that only-n mode only changes the basic-rates setting, G mode data-rates are still used. Here is the table with the explanation for each mode:
http://wiki.mikrotik.com/wiki/Manual:In ... Rate_table
Zwodka
Wed Jul 01, 2015 5:57 pm
MegaThanx
panosla
Wed Jul 01, 2015 6:35 pm
Is DHCP option 138 suitable for configuring CAPsMAN address on all CAP enabled devices?
uldis
Thu Jul 02, 2015 12:45 pm
Yes.
Configuring DHCP Server Option 138 for setting the CAPsMAN address on the CAP boards:
/ip dhcp-server network set <network-id> caps-manager=<capsman-server-ip>
DHCP client this CAPsMAN IP will see in "/ip dhcp-client print detail"
solaoxo
Mon Jul 06, 2015 7:12 pm
Just across the middle CAPsMAN other brands would not recognize the switch.
P2k1
Wed Jul 15, 2015 5:13 pm
where do I find cm2 package for 6.30 6.30.1?
didn't find it on the download page.
karlisi
Thu Jul 16, 2015 8:20 am
Starting from 6.30 it's included in main package.
P2k1
Thu Jul 16, 2015 9:20 am
Thanks, so i'm going to update. :)
karlisi
Thu Jul 16, 2015 11:30 am
After successfull update there will be cm2 package file in /files, AFAIK it is for compatibility purposes, you can delete it, otherwise you will receive error "package already installed" on every reboot.
bartjoo
Thu Jul 30, 2015 5:04 pm
could you tell what the new features are for the next version (v3)?
And could you tell when v3 is planned?
MikroTicked
Tue Aug 04, 2015 1:41 am
Any idea?
Was this issue resolved? I'm having exactly the same problem.
Cornmeister
Tue Aug 04, 2015 10:54 am
*bump*
something like
instead of
Beone
Trainer
Trainer
Tue Aug 04, 2015 3:26 pm
We are massively deploying CAPSMANv2 now but are suffering controller cpu spikes to 100%.
We have a Mikrotik case open (started at V6.29.1 and are now running V6.30.2 but still having the issues) but wanted some feedback of people maybe running into the same issues?
- process ssl @100% cpu when caps try to connect with connection errors (timeouts)
- process wireless suddenly hangs for hours @ 100% cpu after 9-10hours running resulting in caps not failing over to backup controller and just dropping the complete wireless network
The controller is not performing any forwarding of the traffic, it merely manages all the caps and their configuration.
We tried RB450G as controller; then moved on to RB850Gx2 (which is a bit better) but still no luck.
I've read people in the forum here running it on CCR1009 in hotels with no issues. Can they confirm that the ssl and wireless processes are multi-thread capable and can be offloaded to multiple CCR cores?
There currently doesn't seem to be a performance indicator yet on CAPSMAN controller sizing
MikroTicked
Wed Aug 05, 2015 12:44 am
Any idea?
It seems that the problem is related to the CAP not being able to load the certificate that was created when it first registered with the CAPsMAN (on the same device). When I select the issued certificate in the dialog box to enable CAP, the log shows "CAP connect to Router (xxxxx) failed: could not load certificate (6)"
Device 951G-2HnD
OS 6.30.2
Firmware 3.24
karlisi
Wed Aug 05, 2015 8:12 am
We are running CAPsMAN v2 controllers on CCR1009 with no problems. Also have one on RB1100 (1 CPU), works OK. One difference, our controllers are traffic forwarders too.
Zwodka
Wed Aug 12, 2015 11:44 am
Is there any way to change HT-MCS settings under CAPsMAN?
Tr0llk1ng
Sat Aug 15, 2015 11:52 am
Any idea?
I've the same problem with multiple installations running 6.30.2 - did you ever find a solution to this problem? For me it seems to be as the local CAP receives the certificate but the issued certificate does not show as PrivateKey available. (Screenshot shows a CRS109 with Capsman shows CA Cert with 4C5E0CA5654C MAC and Issued_3 shows CAP with MAC 4C5E0CA5654C but no private key available)
Screenshot of the certs of another CAP running on a different hardware shows correct behaviour - CAP Certificate with private key available:
I guess due to this behaviour restarting the CapsMan / CAP prevents the CAP to access the certificate, reissue is no option as it's not possible to issue a cert with the same common name (which seems to be a bug itself,...?)
somebody able to shed some light?
BG Christoph
Cornmeister
Wed Sep 02, 2015 10:21 am
*second bump*
something like
instead of
SirSiggi
Tue Sep 29, 2015 9:18 am
Any idea?
BG Christoph
I'm having the same problem. As soon as I reboot the CAP, it cannot use the generated certificate anymore but can also not generate a new one, because there is already a certificate for that hostname. The client on another router just connects fine.
uldis
Tue Sep 29, 2015 12:20 pm
Please upgrade to the RouterOS v6.33rcX and then check again after you request a new certificate.
bartjoo
Sat Oct 03, 2015 11:03 am
Hello, i have installed Capsman on 1 server and have 50 clients.
Everything works great! Also the upgrades all together in one single click.
But could someone tell me how to upgrade the firmware (routerboard versions) with Capsman? otherwise i need to upgrade every client seperatly.
tnx for your reaction / advise!
SirSiggi
Sat Oct 03, 2015 11:05 am
It seems as if version 6.33rc16 solved the problem for me, at least for the first reboot. I will have an eye on it.
juanvi
Sun Oct 04, 2015 1:19 am
I think is not possible. I was looking for this too.
profek412
Wed Oct 07, 2015 6:06 pm
I have running Capsman v2 on CCR 1016-12G. I have ~500 interfaces. When connect >~150 users then after 5 minuts interfaces was inactive. After 1-2minutes they active to next 5 minutes. I tested 6.30.1 and 6.32.2.
On MT is capsman and hotspot. Bandwidth limit per user is 512kb. All traffic is ~20mb/15mb.
Do you have any idea? Mayby ~500 interfaces is too much?
Beone
Trainer
Trainer
Wed Oct 07, 2015 7:16 pm
Hi profek412;
We are running CCR-1009 running V6.33rc16 with 935 interfaces and 307 caps connected.
This because we regularly loose all caps from the management only to return a few minutes after; while there are no interruptions measured between the caps and capsman (all caps are coming from different locations and we have capsmans in different datacentres with different uplinks)
We have a case open with MT as we try to reproduce the problem.
BTW: do you also regulary see the message : 'disconnected, max key exchange retries'?
We have this at regular basis and then the Apple devices lock and need to be turned wifi off/on again for everything to function properly again until this happens again.
profek412
Wed Oct 07, 2015 8:55 pm
Hi profek412;
Tommorow I separates capsman and firewal to different routerboard. I think problem is in max load core cpu. When I reduce firewall and queue rules The problem is less common.
I start system on Monday, and I don's see 'disconnected, max key exchange retries' in log. We tested system on iphone and we don't have any problem.
Beone
Trainer
Trainer
Thu Oct 08, 2015 1:20 am
For us, we already have a split between FW and CAPSMAN function between separate hardware devices...
For the Max retries, check your apple macos logs for the following error message:
kernel[0]: inputEAPOLFrame: Received non-key EAPOL frame
Drives me nuts... EAP tests on other vendor equipment are working correctly
mavink
Wed Oct 14, 2015 2:48 pm
We found a small bug in the latest (6.32.2) release. In webfig, when trying to copy a client to the access list (from the registrations tab in CAPsMAN v2) we get an internal server error and are redirected to the login screen. Doing the same thing with winbox works fine.
uldis
Fri Oct 16, 2015 12:38 pm
Thank you for the report - we will try to fix it.
uldis
Fri Oct 16, 2015 12:41 pm
If you could provide us remote access to the CAPsMAN where this EAP test isn't working we could try to debug it.
We could need also instructions how to reproduce it on your remote location.
Please send that all to support@mikrotik.com
cleaver
Fri Nov 20, 2015 1:12 pm
Hello everyone!
I'm using CapsMan v2 on routeros 6.33.1 with several CAPs.
I noticed that the CapsMan registration table doesn't show "Last IP" info for connected stations. Caps don't seem to provide this information either. Is there a way, using CapsMan setup, to view "Last IP" info for connected stations?
When not using CapsMan, this info was available in the Registration table. But now it seems to be gone.
Thanks,
Kind regards!
Stoycho
juanvi
Fri Nov 20, 2015 8:32 pm
kick him with Access list and forcé quick roam
bleblas
Ridddick
Mon Nov 23, 2015 3:12 pm
Having the same issue, so sad. Using RB751 as a controller and grooves/caps as APs, ROS 6.34rc6. The controller takes 4 APs and have 50-100% CPU load and memory leakage. When 5th AP connects it just hangs up. I can't believe that controlling caps is so resource-intensive task. What am i supposed to do with that? Buy a CCR?
PS: I tried to turn off requesting a certificate.
anuser
Long time Member
Long time Member
Mon Dec 14, 2015 4:35 pm
let´s add a sizing question. What kind of routerboard would I need for CAPSMAN with
~ 350x 802.11ac access points
~ 5000 clients concurrently connected (currently on my old platform and increasing)
~ 80000 sessions
Would a CCR1072 be enough? Should I wait for Cloud Hosted Router on some x86 server, instead?
(Btw, IPv6 traffic with CAPSMAN is running without any problems, right?)
Regards
Beone
Trainer
Trainer
Wed Dec 16, 2015 5:41 pm
We see the same thing on MIPS platforms running capsman having memleaks when hotspot and capsman is combined.
Case with MT opened, no feedback yet.
CPU resources for DTLS setup are important as well if you want to add quite an amount of CAPS to the CAPSMAN.
we've requested sizing notes to MT as well, but only received feedback that we should look at the forwarding capacity table to know how they the platforms scale.
PS; secondary bug: at bootup; almost all caps select 2412Mhz channel (not great)
Test471
Tue Jan 05, 2016 12:54 am
Are we going to get WMM support in CAPsMAN any time soon?
juanvi
Tue Jan 05, 2016 11:21 am
 What's new in 6.30 (2015-Jul-08 09:07):
*) wireless - added WMM power save suport for mobile devices;
andriys
Tue Jan 05, 2016 1:21 pm
This has no relation to CAPsMAN.
Test471
Tue Jan 05, 2016 1:44 pm
Yes, but how do you turn it on on CAPsMAN configuration? I had 3 stand-alone APs working fine when I enable WMM on their interfaces but yesterday I put them to work as CAPs and now I cannot enable WMM. Looking at Registration table on CAPsMAN I can see that devices are not staying registered more than 2-3 minutes (only when they are in use).
So, how do I enable it?
juanvi
Tue Jan 05, 2016 2:39 pm
You are right, sorry: This feature was enabled for capsman in 6.30 and revised in later firmwares because bugs.
What's new in 6.31 (2015-Aug-14 15:42):
*) wireless - improved WMM-PowerSave support in wireless-cm2 package
Test 471. It is enabled by default in CAPSMAN. No option for disable
Test471
Tue Jan 05, 2016 4:29 pm
Ok, but then, why are clients keep disconnecting after they go to sleep mode? As I said, I am looking at registration table on CAPsMAN and not a single client is registered for more than 3-5 minutes (except laptops):
- disconnected, received disassoc: sending station leaving (8)
All devices are running with cm2 package and v6.33.3. Before, when they were running as stand alone APs everything was fine (so, there was no other change except for setting up CAPsMAN).
Any ideas or hints?
uldis
Tue Jan 05, 2016 5:35 pm
This is wireless client decision to disconnect from the AP. We don't have any control why they want to connect.
WMM PowerSave feature is always enabled in the CAPsMAN and can't be disabled.
Test471
Tue Jan 05, 2016 9:32 pm
I guess you missed something. I said everything was working fine before CAPsMAN. In the meantime I tried some of those devices on another AP without CAPsMAN and it is working without disconnect.
How is that?
Test471
Wed Jan 06, 2016 3:20 pm
Ok, now I am pretty sure there is some problem with CAPsMAN. I took one device (iPhone 6S with iOS 9.2) and connected it to CAP. It stays connected until it goes to sleep mode. Then I disabled CAP on that access point and configured it like stand alone AP. Then phone stays connected even when in sleep mode.
CAP = 951-2n
CAPsMAN = 750G
So, please have this checked or give me a hint what else is there to try?
Well, maybe not directly but if AP says to a client "No, I don't support WMM" and then client decided to disconnect because of that I would say it is one way of indirect control of client behaviour.
uldis
Wed Jan 06, 2016 3:30 pm
we need configuration for the CAPsMAN and for the Standalone AP.
Please send us the support output files from both to support@mikrotik.com.
Test471
Mon Jan 18, 2016 12:09 am
I've sent config to you the same day you asked for it.
In the meantime I did some testing and it looks like that clients are disconnecting fast when dhcp gives them very short lease. When DHCP is giving 60 seconds lease to clients then they are disconnecting. Now i changed it to 24h and they are not disconnecting.
whyfly
Trainer
Trainer
Tue Feb 09, 2016 4:57 pm
Are there any plans to specific data rates (ht-basic-mcs, supported-rates-b, etc) via CAPsMAN?
I would like to be able to allow only 24, 36, 48, 54, and HT MCS 3,4,5,6,7,11,12,13,14,15 on g/n 2.4 GHz, and only HT MCS 3,4,5,6,7 and VHT MCS 3,4,5,6,7,8,9 on n/ac 5 GHz on hAP ac lite wireless interfaces managed by CAPsMAN.
Beone
Trainer
Trainer
Wed Feb 10, 2016 6:49 pm
We asked this as well to increase wireless quality/roaming for 2.4Ghz clients. As using the access-lists RSSI Kick-method is incompatible with most MacOS devices (they get stuck!)
We got informed it's on the todo list, but i do not understand what makes this so difficult as it's already there in standalone modus.
lcffbr
Thu Feb 11, 2016 8:34 pm
In the configuration of CAPsMAN, one of the described steps is: Create bridge. What is the reason for this new bridge? In my configuration I already have a local-bridge that includes all Ethernet and Wlan interfaces, so every connection gets access to all network.. This required bridge in CAPsMAN has to be a different one? The third step is to add an IP address, DHCP Server and a masquerade rule to this bridge. Does it need to be different from the other bridge we already have?
Thanks in advance
LCFFBR
karlisi
Fri Feb 12, 2016 9:09 am
You can use any bridge if You integrate CAPsMAN in existing network.
dragelec
Tue Feb 23, 2016 6:20 pm
Hi profek412;
Hi, I have the same issue, my capsman run on CCR-1036 v6.34.2 with 160 interface and 80 caps connected. Capsman regularly loose all caps from the management only and then return a few minutes after. This issue appear every about 4hours, after loose times my capsman auto reboot. :(. I'm so tired to find out what error.
Did you fixed it?
tks
Beone
Trainer
Trainer
Wed Feb 24, 2016 9:09 pm
We havent fixed this, we are currently on v6.35rc12 for the memory leak issue we had massive issues with (router runs out of memory and then reboots)
anuser
Long time Member
Long time Member
Thu Mar 10, 2016 1:10 pm
With CAPsMAN v2 package and new "wireless-rep" package IPv6 for clients is lost, i.e.
o problem: with CAPsMANv2 and „wireless-rep“ package clients don´t receive any IPv6 traffic, no IPv6 router adverisements at all iff VLAN assignement is done dynamically. Dynamic VLAN assignment within datapath works for IPv4 traffic, though. If I assign a VLAN ID wihin datapath configuration of CAPSMAN, IPv6 and IPv4 is working without any problems.
(with traffic forwarding @CAPSMAN controller)
[UPDATE]
+ It works when I change multicast-helper setting to full on the Cap interface
SolarW
Fri Jun 10, 2016 1:41 am
+1 to this improvement
Hello everyone!
Thanks,
Kind regards!
Stoycho
joncolby
Sat Jun 25, 2016 11:12 pm
I would like NV2 with encryption on capsman.
southgate
Thu May 03, 2018 4:00 pm
+1 on the nv2 support. We have a network of ca 50 devices where each has a 3 connected bridged sectors and capsman would be a nice feature to centralize the management since our clients are mostly routeros
Users browsing this forum: Google [Bot] and 70 guests
