Krisken
Re: RouterOS v6.25
Tue Jan 20, 2015 4:03 pm
Is there yet any news about BGP peer status in SNMP so we can monitor BGP sessions?
How about BGP4-MIB?
siscom
Re: RouterOS v6.25
Tue Jan 20, 2015 4:29 pm
We upgraded our Routerboard CCR1036 with V6.25 from V6.19 (Firmware was also upgraded). Upgrade was done mainly to solve packet discards on the interfaces.
We have, after a few hours, suddenly lost our bridges inside the bridge configuration, but not the bridge ports which are showing 'unknown' as the interface they should be bound too. Subsequently, some firewall rules are now RED since they depend on these bridge interfaces.
Have checked via terminal to see if the config is a winbox issue but bridges also do not show. Also checked output from an 'export file' command with the same result.
Anyone seeing this?
Ticket submitted [Ticket#2015012066000425]
Rgds,
Mark
ufm
Re: RouterOS v6.25
Tue Jan 20, 2015 4:39 pm
ufm
What model routerboard are you using?
We have a few units with 100+ PPPoE, I am worried to experiment with this.
Do you use RADIUS as well?
CCR1036-8G-2S+
I have about 1200~1500 PPPoE sessions on router.
Yes, authorization by the radius.
I think this problem becomes noticeable with a large number of sessions.
StubArea51
Trainer
Trainer
Re: RouterOS v6.25
Tue Jan 20, 2015 7:18 pm
Just installed 6.25 in the IPA Area 0.0.0.51 development lab ( Flowood, MS) and seems to be running fine. Boot times do seem to be improved...Thanks MT!
Equipment we have tested in the dev lab (will update the list as we test more):
RB2011UiAS
RB951G-2HnD
RBcAP2n
RBmAP2n
mickaelmonsieur
Re: RouterOS v6.25
Tue Jan 20, 2015 7:47 pm
For me, the 6.25 contains a major bug.
I upgraded 2 CCR1036 this afternoon, and bandwith test tool no longer works, it displays 0bps ... After downgrade to 6.24, the tool works.
dzikis
Re: RouterOS v6.25
Wed Jan 21, 2015 12:41 am
Hi dudes
I have got problem with booting my ccr with 6.25. After sending to device 6.25 firmware i reboot device and i had info on lcd about booting kernel from nand only.
I disconected device from power suplay and it works now.
Where was / is problem ?
Jakub
nkourtzis
Re: RouterOS v6.25
Wed Jan 21, 2015 10:50 am
Anyone seeing this?
Rgds,
Mark
Same here, on ONE of our two Omnitiks. Wlan interface became "unknown". For an unknown reason, it was changed to "wlan2" on a previous upgrade, and it was reverted to wlan1, thus becoming unknown.
N.
erreferre
Re: RouterOS v6.25
Wed Jan 21, 2015 12:56 pm
Previously to v6.25, we had installed 6.21.1 a lot of RB450G had problems with dhcp and dns processes, and the CPU take 100%.
After upgrade to v6.25, most of the problems disappeared, but now we have a few RB450G with ssh process take all CPU. We don't have "idle" process in these RB450G, and the CPU is 100% all the time.
[xxx@XXX] > tool profile
NAME CPU USAGE
snmp all 0%
spi all 0%
ethernet all 1.5%
console all 0.5%
ssh all 74.5%
dns all 7.5%
firewall all 1%
networking all 1%
hotspot all 0.5%
winbox all 0%
logging all 0%
management all 8%
dhcp all 0%
profiling all 0%
queuing all 2%
web-proxy all 3%
telnet all 0.5%
unclassified all 0%
sergejs
Re: RouterOS v6.25
Wed Jan 21, 2015 1:00 pm
boscolee,
Please provide us with more details about your problem.
What configuration did you have at 6.24? How did you apply it?
We are try to repeat your issue.
taknamecom,
Do you have the particular problem in the previous versions?
Do you have bridge in your setup?
jarda,
more information is required about your problem.
I have upgraded RB751 from 6.24 to 6.25, admin-mac-address stayed on the router.
siscom, thank you very much for the file.
We are working on your problem.
mickaelmonsieur, please provide us with more information, how you were using bandwidth test on your router.
nkourtzis, please contact MikroTik support (support@mikrotik.com) with support output file, when problem is present.
nkourtzis
Re: RouterOS v6.25
Wed Jan 21, 2015 1:25 pm
boscolee,
taknamecom,
jarda,
On this unit, requesting a supout takes forever and seems to trigger the watchdog due to very high cpu utilization during the creation of the supout file.
sergejs
Re: RouterOS v6.25
Wed Jan 21, 2015 3:56 pm
nkourtzis,
mail remote access to support for your device, it will be fine too,
jarda
Re: RouterOS v6.25
Wed Jan 21, 2015 4:18 pm
Sergejs, I cannot provide more info as I filled again the missing administrative mac addresses to the bridges.
noyo
Re: RouterOS v6.25
Wed Jan 21, 2015 5:42 pm
@normis @sergejs why do not you want to provide a detailed list of changes RouterOS?
Each of your change, results have faults in my scripts.
Get email alerts for longer in this case one does not suit me. :(
sorry for my english
MadriSX
Re: RouterOS v6.25
Wed Jan 21, 2015 6:24 pm
After updating all my SSTP VPN clients with Windows 8 / 8.1 doesn´t work anymore, error 619 appears and I can not fix it like I did in previous Router OS releases, any idea?
Thanks.
THG
Re: RouterOS v6.25
Wed Jan 21, 2015 10:42 pm
Are you going to fix this issue? TCP traffic through the Ethernet interface shows over 80 percent more than the VLAN interface. UDP shows the correct speed on both interfaces and the issue appears only in the X86 version of RouterOS.
dynek
Re: RouterOS v6.25
Wed Jan 21, 2015 10:58 pm
Just updated RB450G from 6.19 to 6.25 it never rebooted so I helped it reboot and now it seems to boot OK (one beep and abt 30 seconds later two beeps) but I'm not assigned an IP anymore, none of my devices is.
If I try to set an IP manually, it doesn't work either.
I tried to connect to ether1 with ip 192.168.88.2, no luck either.
Last time I updated I had the same issue, don't think I'll update next time if I can't get the device back on the track...
What should I do ? Reset it and upload backup of configuration ?
1st edit:
So I went for the reset using the internal reset pins, it made the "weird" beep and rebooted.
But even like this I can't reach 192.168.88.1 on ether1
2nd edit:
Oh and now each time I boot it does the weird beep to say "I'm resetting everything" - what is going wrong, all of this just for an update... really guys....
3rd edit:
com port is showing, shit:
-/-#���59!#7�!�5#5�544y=��-#1�;!!��y=�T��=#!=����q����}U�35#9
dynek
Re: RouterOS v6.25
Thu Jan 22, 2015 12:55 am
Try Netinstall to recovery device firmware.
I have netinstall working with wine on OS X. Great stuff.
However, even selecting "Apply default config" doesn't give me 192.168.88.1 on ether1.
And the RB450G still makes this "I am resetting everything" sound each time I put power.
dynek
Re: RouterOS v6.25
Thu Jan 22, 2015 2:17 am
OK so if that's of interested for you guys @ Mikrotik, I flashed back 6.19 and the router started working again. What a waste of time.
Any explanation as to why 6.19 -> 6.25 breaks everything ?
Finally I flashed each version from 6.20 to 6.25 and it worked. Also I first did a /system routerboard upgrade cause it was running 3.10 and 3.18 was there to be flashed.
jarda
Re: RouterOS v6.25
Thu Jan 22, 2015 8:37 am
Did you connect by mac address to proove what is wrong? Or how did you "try to set ip manually"?
jarda
Re: RouterOS v6.25
Thu Jan 22, 2015 8:40 am
Do you have DHCP client on bridge? If so, it might loose administrative mac address so then it could be impossible to get ip from DHCP server, as I realised by update from 6.24 to 6.25.
normis
Re: RouterOS v6.25
Thu Jan 22, 2015 9:06 am
please clarify what has changed that caused your script not to work. there are no changes to email
noyo
Re: RouterOS v6.25
Thu Jan 22, 2015 9:23 am
No, I want a detailed list of changes to be able to react before!
normis
Re: RouterOS v6.25
Thu Jan 22, 2015 9:28 am
there are no other changes apart from the changelog. LIke I said, nothing that could have changed email behavior.
andris
Re: RouterOS v6.25
Thu Jan 22, 2015 9:55 am
After update to 6.25 could not connect to sstp server from W8.1 client.
Had to downgrade to 6.24 and sstp connection worked again.
Is there any changes in sstp also?
RB951G-2HnD
keema
Re: RouterOS v6.25
Thu Jan 22, 2015 11:02 am
RB951G-2HnD
Same here. Fantom changes....
normis
Re: RouterOS v6.25
Thu Jan 22, 2015 11:46 am
sstp has no changes, I checked the commit log. it could be effect of something else. please send debug log output to support, and some more info - error message etc.
andris
Re: RouterOS v6.25
Thu Jan 22, 2015 1:25 pm
Sent debig logs to support.
MadriSX
Re: RouterOS v6.25
Thu Jan 22, 2015 2:35 pm
Jan/22/2015 13:33:46 sstp,packet SSTP_DUPLEX_POST /sra_{BA195980-CD49-458b-9E23-C84EE0ADCD75}/ HTTP/1.1
Jan/22/2015 13:33:46 sstp,packet SSTPCORRELATIONID: {93C5D5D6-EA3C-4A6E-A7AB-9D9535EDA8C0}
Jan/22/2015 13:33:46 sstp,packet Content-Length: 18446744073709551615
Jan/22/2015 13:33:46 sstp,packet Host: vrpv.******.***
Jan/22/2015 13:33:46 sstp,packet sending
Jan/22/2015 13:33:46 sstp,packet HTTP/1.1 200
Jan/22/2015 13:33:46 sstp,packet Server: MikroTik-SSTP
Jan/22/2015 13:33:46 sstp,packet Date: Thu, 22 Jan 2015 12:33:46 GMT
Jan/22/2015 13:33:46 sstp,packet recv control packet type: connect request
Jan/22/2015 13:33:46 sstp,packet 10 01 00 0e 00 01 00 01 00 01 00 06 00 01
Jan/22/2015 13:33:46 sstp,packet sent control packet type: connect ack
Jan/22/2015 13:33:46 sstp,packet 10 01 00 30 00 02 00 01 00 04 00 28 00 00 00 03
Jan/22/2015 13:33:46 sstp,packet a4 a9 51 57 e1 e2 c4 91 7f 8f b0 8e 24 82 98 0c
Jan/22/2015 13:33:46 sstp,packet a3 76 90 bd 11 32 5c 8c c6 71 af fa e8 52 f3 8d
Jan/22/2015 13:33:46 sstp,ppp,debug : LCP lowerup
Jan/22/2015 13:33:46 sstp,ppp,debug : LCP open
Jan/22/2015 13:33:46 sstp,ppp,debug,packet : sent LCP ConfReq id=0x1
Jan/22/2015 13:33:46 sstp,ppp,debug,packet <magic 0x25a908fb>
Jan/22/2015 13:33:46 sstp,ppp,debug,packet <auth mschap2>
Jan/22/2015 13:33:46 sstp,ppp,debug : LCP lowerdown
Jan/22/2015 13:33:46 sstp,ppp,debug : LCP down event in starting state
agrisvv
Re: RouterOS v6.25
Thu Jan 22, 2015 10:58 pm
ebreyit
Re: RouterOS v6.25
Thu Jan 22, 2015 11:06 pm
I can also confirm issue with windows 8.1 sstp vpn clients following upgrade to 6.25. Error 619 reported by windows vpn client when trying to connect.
Immediate downgrade back to 6.24 solved the issue. Windows 7 and server 2008 sstp clients unaffected.
This was on a CCR with Valid Wildcard SSL Certs.
ch36mikrot
Re: RouterOS v6.25
Fri Jan 23, 2015 4:42 am
So can I. (comfirm this issue)
Now All I can do is just downgrade the firmware of my RB750GL to 6.24, and it works well as usual.
I checked the log. There is no record about SSTP login.
The client (Windows 8.1) just shows error message "Error 619'
niamul
Re: RouterOS v6.25
Fri Jan 23, 2015 3:50 pm
after upgrading to 6.25 on my ccr1016-12g we are seeing higher cpu usage and lower bandwidth consumption.
we have simple queues, dhcp and pppoe running and dns cache. cpu usage hitting 85 to 90%
bandwidth consumption dropped from 700mbps to ~550mbps on the same config as before
has some config changed somewhere that i should look into?
we have 3 mangle rules and about 10 nat rules. firewall only has drop rules and thats about 8 of them.
i'd gladly provide more info when required.
thank you
niamul
steen
Re: RouterOS v6.25
Fri Jan 23, 2015 10:32 pm
Major bug!
It is not possible to upgrade devices using "The Dude", we manage all our network through "The Dude", how come ?
Please explain why this now happened and when we can expect it work again ?
Without having the dude doing upgrade work, we are almost dead in water, it will take us forever to sit manually and upgrade devices one by one, we are back to very basic home user type of upgrading like in old days when we had only 3-4 routers out there.
Please come back with a solution on this quickly.....
dcavni
Re: RouterOS v6.25
Sat Jan 24, 2015 12:53 pm
When i check the "Vpn Acess" option in "Quick set" menu and press "Apply" the option doesn't stay checked. VPN still works afterwards, just the option isn't checked. RB2011UiAS-2HnD.
mars
Re: RouterOS v6.25
Sat Jan 24, 2015 2:03 pm
Major bug!
+1
mars
Re: RouterOS v6.25
Sat Jan 24, 2015 2:06 pm
well ros 6.24 still worked fine with thedude upgrading
so when will the dude be upgraded then?
+1
leetw302
Re: RouterOS v6.25
Mon Jan 26, 2015 6:00 am
in x86 base Terminal, exporting error.
Anyone same problem like this?
herbrico
Re: RouterOS v6.25
Mon Jan 26, 2015 8:18 am
I have a same router RB2011UiAS-2HnD and for my stay checked.
bax
Re: RouterOS v6.25
Mon Jan 26, 2015 12:11 pm
for me command
/tool user-manager database save name=database
work normaly ... which command does you using ?
sergejs
Re: RouterOS v6.25
Mon Jan 26, 2015 12:30 pm
Thank you very much for your reports and help. At the moment there have been fixes introduced to 6.26rc version, that is available from our download page.
Note the latest rc contains improvements for queues on CCR boards, those who have queues on CCR and testing rc version. We will wait for your feedback on this.
bax
Re: RouterOS v6.25
Mon Jan 26, 2015 12:57 pm
Sergejs can you check this example :
/ip firewall layer7-protocol
add name=tftp regexp="^(\\x01|\\x02)[ -~]*(netascii|octet|mail)"
/ip firewall mangle
add action=mark-packet chain=prerouting comment=\
    "FTP - File Transfer Protocol " dst-address=!192.168.11.200 in-interface=\
    public layer7-protocol=ftp new-packet-mark=qos-5_in-wan1 passthrough=no
add action=mark-packet chain=postrouting dst-address=!192.168.11.200 \
    layer7-protocol=ftp new-packet-mark=qos-5_out-wan1 out-interface=public \
    passthrough=no
/queue tree
add name=WAN1_IN parent=global priority=1 queue=default
add limit-at=1M max-limit=12M name=qos-5_in packet-mark=qos-5_in-wan1 parent=\
    WAN1_IN priority=5 queue=default
add name=WAN1_OUT parent=global priority=1 queue=default
add limit-at=100k max-limit=1M name=qos-5_out packet-mark=qos-5_out-wan1 \
    parent=WAN1_OUT priority=5 queue=default
Explanations:
I trying to setup qos but some thing dont work.
My ftp server (192.168.11.200) is in my public zone and have same gateway like mikrotik 192.168.11.1
Im try to exclude my ftp server from bandwith limit for users behind mikrotik ... which is visible in ip firewall mangle rule , but this is not working ... is this some bug or just im doing something wrong ?
Thanks!
sergejs
Re: RouterOS v6.25
Mon Jan 26, 2015 1:18 pm
This does not have too much relation to the specific version.
I assume it is much better to use port and src/dst-addresses to filter FTP traffic, instead of layer7 rules.
padrecc
Re: RouterOS v6.25
Mon Jan 26, 2015 1:38 pm
What about bug in SSTP VPN+Windows 8.1, is it fixed in latest rc?
sergejs
Re: RouterOS v6.25
Mon Jan 26, 2015 1:54 pm
We are aware of the problem, finally we repeated the problem.
Fix will be available very soon.
keema
Re: RouterOS v6.25
Mon Jan 26, 2015 2:00 pm
But Normis said many times, nothing was changed with SSTP....
normis
Re: RouterOS v6.25
Mon Jan 26, 2015 2:04 pm
Yes, but this doesn't mean some other feature is not interfering with it. You can see now, that Changelog is not a universal answer to all problems.
keema
Re: RouterOS v6.25
Mon Jan 26, 2015 4:03 pm
I already know that your changelog is far from anything universal ;)
leetw302
Re: RouterOS v6.25
Tue Jan 27, 2015 3:29 am
Thanks for reply
i try export command
and try /tool user-manager database
it is same problem.
Image Capture URL : https://www.dropbox.com/s/iwgjw88ydvvj0 ... 9.png?dl=0
for me command
drk
Re: RouterOS v6.25
Tue Jan 27, 2015 5:57 pm
Upgraded to 6.25.
SSTP problem exists in client mode also.
In 6.23 client worked like charm
18:46:25 sstp,ppp,info sstp-out1: initializing...
18:46:25 sstp,ppp,info sstp-out1: connecting...
18:46:25 sstp,packet sstp-out1 sending
18:46:25 sstp,packet SSTP_DUPLEX_POST /sra_{BA195980-CD49-458b-9E23-C84EE0ADCD75}/
 HTTP/1.1\r
18:46:25 sstp,packet Content-Length: 18446744073709551615\r
18:46:25 sstp,packet Host: 123.123.123.123\r
18:46:25 sstp,packet \r
18:46:25 sstp,packet sstp-out1 recv
18:46:25 sstp,packet HTTP/1.1 200 OK\r
18:46:25 sstp,packet Date: Tue, 27 Jan 2015 15:46:25 GMT\r
18:46:25 sstp,packet Server: Microsoft-HTTPAPI/2.0\r
18:46:25 sstp,packet sstp-out1 sent control packet type: connect request
18:46:25 sstp,packet 10 01 00 0e 00 01 00 01 00 01 00 06 00 01
18:46:25 sstp,packet sstp-out1 recv control packet type: connect ack
18:46:25 sstp,packet 10 01 00 30 00 02 00 01 00 04 00 28 00 00 00 02
18:46:25 sstp,packet f6 79 08 34 51 fc b9 aa cd 5c 57 2f 51 dc 82 f9
18:46:25 sstp,packet bc 1a d8 62 97 16 fc c7 0c c5 55 4a 99 c5 59 c6
18:46:25 sstp,ppp,debug sstp-out1: LCP lowerup
18:46:25 sstp,ppp,debug,packet  sstp-out1: sent LCP ConfReq id=0x55
18:46:25 sstp,ppp,debug,packet    <magic 0x304a90b4>
18:46:25 sstp,ppp,debug,packet    <mrru 1600>
18:46:25 sstp,ppp,debug sstp-out1: LCP open
18:46:25 sstp,ppp,debug sstp-out1: LCP lowerdown
18:46:25 sstp,ppp,info sstp-out1: terminating... - terminated by remote peer
18:46:25 sstp,ppp,debug sstp-out1: LCP down event in starting state
18:46:25 sstp,ppp,info sstp-out1: disconnected
elgrandiegote
Re: RouterOS v6.25
Wed Jan 28, 2015 5:43 pm
*) ovpn server - added support for address lists;
Any details about this one?
What They Mean to "What They Mean to "ovpn server - added support for address lists;"
voljka
Re: RouterOS v6.25
Thu Jan 29, 2015 5:31 pm
ROS 6.26 RC16 - SSTP problem with Windows 8.1 Client not fixed. On Client error 619.
On router: see attachment
Mitar
Re: RouterOS v6.25
Sat Jan 31, 2015 2:15 pm
I have identical problem with SSTP Server on RouterOS 6.25 , downgrade to 6.24 resolved the problem.
pukkita
Trainer
Trainer
Re: RouterOS v6.25
Mon Feb 02, 2015 10:01 am
Tested 6.25.
On SXT G-5HPacD works incorrectly automatic start configuration file after the reset configuration. If a file .rsc contains any mention of the wlan interface - configuration is interrupted at the location in the file where it is mentioned about it. If you remove from the file rsc any mention of the wireless interface - configuration updates correctly.
Also on SXT G-5HPacD still does not work tab «Current TX Power» on the wlan interface and don't work spectral scan.
spectral scan/ history doesn't work yet on wireless-fp driver (used by AC).
Are you using these units in a PTP? Any advised ROS version / Wireless settings (If I recall correctly nstreme wasn't useable yet) for a reliable PTP Link with STX AC units?
OlegM
Re: RouterOS v6.25
Mon Feb 02, 2015 1:20 pm
On ppp server (pptp) using torrent tumbled session (lost pumping).
voljka
Re: RouterOS v6.25
Mon Feb 02, 2015 3:32 pm
routeros-mipsbe-6.26rc20 - SSTP client Windows 8.1 update 1 - works OK.
lcrhea25
Re: RouterOS v6.25
Tue Feb 03, 2015 12:04 am
Is there an answer yet to not being able to upgrade units from Dude? Upgrading will be a long painful task without being able to do it from dude now.
astounding
Re: RouterOS v6.25
Tue Feb 03, 2015 8:39 pm
I use a script via CRON to periodically SSH into a bunch of MikroTik devices and do "/export compact" to archive device configurations. When there's a change, it email's me the diff.
PROBLEM:
One RB433AH device running RouterOS v6.25 serving DHCP on a LAN (ethernet port) to a group of users keeps reporting configuration changes (via my "/export compact" configuration diff-generator script). First I'll see this as the only change:
-add address=192.168.88.9 always-broadcast=yes comment="Device 7" \
-    mac-address=06:17:F6:E6:DA:41 server=lan_dhcp
+add address=192.168.88.9 comment="Device 7" mac-address=06:17:F6:E6:DA:41 \
+    server=lan_dhcp
Then anywhere from an hour to several hours later:
-add address=192.168.88.9 comment="Device 7" mac-address=06:17:F6:E6:DA:41\
-    server=lan_dhcp
+add address=192.168.88.9 always-broadcast=yes comment="Device 7" \
+    mac-address=06:17:F6:E6:DA:41 server=lan_dhcp
THEN this cycle will repeat again in some random short time period. This will happen 6-12 or so times in each 24-hour period.
Note the ONLY change is the appearance and disappearance of this parameter: always-broadcast=yes
No humans are logging in nor making changes via any mechanism. Therefore it MUST be the device's own behavior changing the configuration spontaneously, possibly in response or triggered by one or more DHCP clients' requests.
OBVIOUSLY THIS IS A BUG - I mean a device should ALWAYS retain a configuration that is identical without some administrative intervention UNLESS there is some WELL-DOCUMENTED feature that automatically changes device configuration in response to network events. In this instance, I see no such documented feature anywhere.
I don't know how to reproduce this bug, however.
ANY SUGGESTIONS?
Thanks!
sergejs
Re: RouterOS v6.25
Wed Feb 04, 2015 2:46 pm
Thank you very much for your help and report!
v6.26 is released,
http://forum.mikrotik.com/viewtopic.php?f=2&t=93710
Users browsing this forum: Google [Bot], infabo, maigonis and 106 guests
