paweldud
Problem with connect to Dude server on mikrotik
Sat Jan 24, 2015 12:59 am
I describe my problem and please help me.
I install Dude 3.6 on my RB750 Mikrotik and use win7 as client to connect it . It work perfectly. Unfortunately I uncheck remote access to my server and cannot connnecting now.
I try everything
1. Uninstall Dude package from MT, and re-install
2. Uninstall Dude client from PC and re-install
3. Hard reset my MT and install Dude again.
It doesn't take effects.
How can I reset configuration on mikrotik or remove it definitely?
lebowski
Re: Problem with connect to Dude server on mikrotik
Tue Jan 27, 2015 12:55 am
Change the allowed network to something like 192.168.0.0/16 then if it starts working change it back to 0.0.0.0/0 if you need to.
Users browsing this forum: No registered users and 67 guests
