MUM 2010
It is currently Tue Feb 09, 2010 5:13 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: why this script does work? who can help me
PostPosted: Fri Dec 07, 2007 9:42 pm
Offline
:local new-address
:local status
:local x
:set x 2
:for i from=1 to=$x do={
:set staus [/interface get [/interface find name=("ppoe")] runnig]
:if ($status=ture) do={
:set new-address [/ip address get [/ip address find dynamic=yes interface=("ppoe")] address]
:set new-address [:pick $new-address 0 ([:len $new-address] -3)]
/ip fir nat set [/ip fir nat find comment=$i] to-addresses=$new-address
tip: 1.2 this my dstnat rule's name. ppoe is interface name. i was hope this script can Automatic mapping port . whats wrong? why does work? im very confuse....
Top
 Profile
 Post subject: Re: why this script does work? who can help me
PostPosted: Fri Dec 07, 2007 9:45 pm
Offline
you misspelled 'true'. you also misspelled 'running'.
_________________
Colo and Wholesale Bandwidth Available! Sales at ChangeIP dot com
Top
 Profile
PostPosted: Sat Dec 08, 2007 1:07 pm
Offline
:local new-address
:local status
:local x
:set x 2
:set staus [/interface get [/interface find name=("ppoe")] 'running']
:if ($status='ture') do={
thx for u reply. but also does work.. my ros is 2.9.27
best regard
Top
 Profile
PostPosted: Sat Dec 08, 2007 3:23 pm
Offline
Cleaned from bad syntax (you have more than those 2 mentioned above):
Code:
:local new-address
:local status
:local x
:set x 2
:set status [/interface get [/interface find name="ppoe"] running]
:if ($status=true) do={
:set new-address [/ip address get [/ip address find dynamic=yes interface="ppoe"] address]
/ip firewall nat set [/ip fir nat find comment=$i] to-addresses=$new-address
Notice: "[:pick $new-address 0 ([:len $new-address] -3)]" - how do you know the last number in ip address will have 3 digits?
interface name "ppoe" is questionable (did you type it right, the correct spelling is "pppoe"
Avoid for x from... at all costs - that causes only problems
Top
 Profile
PostPosted: Sat Dec 08, 2007 6:04 pm
Offline
DEAR DRAGONMEN
thx for you interset. im follow u guide check my script agagin. im preety sure about that my interface name is "ppoe " and i have no idea this line :set new-address [:pick $new-address 0 ([:len $new-address] -3)] whats mean. if i wanna make ros automatic mapping port. how should i do? can u write a script for me?
thx a loooooooooooooooot.
best regard.
Top
 Profile
PostPosted: Sat Dec 08, 2007 8:11 pm
Offline
Staff
Staff
this is bad, because in some cases you will get incorrect IP. To do this correctly you must search for slash '/' from new-address then strip all characters starting from '/' position. Now you will get correct ip.
/ip firewall nat set [/ip fir nat find comment=$i] to-addresses=$new-address this line is in for loop, it means that you have two identical NAT rules? Why?
Also I think that there is absolutely no need to write this script, instead of srcnat you can use masquerade, it will solve dynamic IP problem.
Top
 Profile
Display posts from previous:  Sort by
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
MUM Poland and MUM China free REGISTRATION OPEN
