geraldospint
API - ACL Control
Sat Jun 20, 2009 4:44 pm
How to send this command to the router using API
/interface wireless access-list remove [find comment=teste]
geraldo@spint.com.br
Chupaka
Re: API - ACL Control
Sat Jun 20, 2009 7:48 pm
first, you should get .id's of that entry:
/interface/wireless/access-list/print
.proplist=.id
?comment=teste
then remove all items found
/interface/wireless/access-list/remove
=.id=<your_id_here>
and, AFAIR, you may use comma-separated list of ids in <your_id_here>
geraldospint
Wed Jun 24, 2009 6:34 pm
I need dynamically as:
/interface/wireless/access-list/remove=
.id=</interface/wireless/access-list/print
.proplist=.id
?comment=teste>
is possible ?
ayufan
Wed Jun 24, 2009 8:13 pm
no, first you have to getall items
Chupaka
Wed Jun 24, 2009 11:10 pm
do you ask, whether it's possible to join API queries? no, it's not. simply execute one query, then use its result for the second one. what's problem?
juanCasseus
Fri Jul 24, 2009 1:37 am
HI,,
I Understan all to remove, what I dont understand is when you say <your_id_here>
.proplist=.id
?comment=teste ******* isnot ?=comment=teste
=.id=<your_id_here> ****What mean <your_id_here> What exactly Do I have to put
Chupaka
Fri Jul 24, 2009 9:24 am
first, you execute
=.proplist=.id
?comment=teste
"?comment=teste" is short form of "?=comment=teste"
in response, you receive something like
!re=
=.id=*4EB
and then you can delete this entry:
=.id=*4EB
is it clear enough?..
mknnoc
Trainer
Trainer
Sat Nov 07, 2009 4:56 am
can you please write the complete code?
Chupaka
Sat Nov 07, 2009 1:29 pm
complete code of what? it was already done in my prevoius post, no? =)
Arcanjo
Sat Nov 07, 2009 11:08 pm
Hi, im new in this forum. Sorry my English :?
I have try make this example code to start learn Mikrotik API and I get de fallow message:
Connected...
<<< [22] /ip/hotspot/user/print
<<< [14] =.proplist=.id
<<< [14] ?comment=teste
>>> [5/5 bytes read.
>>> [5, 32] !trap
>>> [23/23 bytes read.
>>> [23, 8] =message=argument error
>>> [5/5 bytes read.
>>> [5, 1] !done
<br />
<b>Notice</b>:  Undefined offset: 0 in <b>C:\wamp\www\api\teste2.php</b> on line <b>17</b><br />
testefsfs<<< [20] /ip/hotspot/user/set
<<< [5] =.id=
<<< [13] =disabled=yes
>>> [5/5 bytes read.
>>> [5, 1] !done
Disconnected...
My Code:
if ($API->connect('xxx', 'xxx', 'xxx')) {
$API->write('/ip/hotspot/user/print',false);
$API->write('=.proplist=.id',false);
$API->write('?comment=teste');
$A = $API->read();
$A = $A[0];
  echo "testefsfs".$A;
$API->write('/ip/hotspot/user/set',false);
$API->write('=.id='.$A['.id'],false);
$API->write('=disabled=yes');
$API->read();
   $API->disconnect();
Thanks!!
Chupaka
Sun Nov 08, 2009 3:48 am
what version of RouterOS?
Arcanjo
Sun Nov 08, 2009 5:13 am
v3.13
Chupaka
Sun Nov 08, 2009 1:42 pm
queries (starting with '?') appeared only in the v3.21. not sure about '.proplist'. so you should upgrade
Arcanjo
Mon Nov 09, 2009 3:01 pm
Thanks Chupaka
So I need update de Router O.S. I,m afraid to do this becouse my server is run 100% whit this version 3.13.
May be I have to try a Telnet commands on my APP and forget mikrotik API :(
Chupaka
Mon Nov 09, 2009 6:14 pm
update it. if something goes wrong, you can downgrade to 3.13 again =)
Arcanjo
Tue Nov 10, 2009 1:22 am
I will Take courage. Just in that RB I have up to 200 users lol
Maybe buy a less expensive RB411 just for test. Yes, in Brazil every think is too expensive lol
Chupaka
Tue Nov 10, 2009 9:50 am
I have a router with up to 600 online users - I update it at night ;)
Arcanjo
Wed Nov 11, 2009 1:14 am
Is possible take a same result with Telnet or SSH and PHP?
Chupaka
Wed Nov 11, 2009 10:32 am
/ip hotspot user set [find comment="teste"] disabled=yes
sky_16
Fri Nov 20, 2009 3:58 pm
is there any visual basic 6 class for mikrotik API? or sample maybe?
@chupaka => would you mind give some example using visual basic 6 to build a class for mikrotik API?
is it possible communicate to router API port (8728) using winsock control in visual basic 6
thanks
Chupaka
Sat Nov 21, 2009 5:14 pm
sure you can use Winsock. unfortunately, I haven't see any VB6 API implementations here...
try to look at C# client - maybe it can help a bit
hrodriguesvt
Wed Mar 31, 2010 11:24 pm
Hi Folks,
I've been trying several ways to put this working, but i simply cant find where is my error.
I would like to disconnect the active user from hotspot, using PHP API.
We use routeros 3.2 in some systems and 4.5 in other ones.
I REALLY apreciate your help!
My current code is:
require('routeros_api.class.php');
$API = new routeros_api();
$API->debug = true;
if ($API->connect('1.2.3.4', 'host', 'pass')) {
$varlogin = "TESTLOGIN";
$API->write('/ip/hotspot/active/print', false);
$API->write('=.proplist=.id', false);
$API->write('?user='.$varlogin);
$varloginid = $API->read();
$varloginid = $A[0];
$API->write('/ip/hotspot/active/remove', false);
$API->write('=.id='.$varloginid);
$API->read();
$API->disconnect();
janisk
Thu Apr 01, 2010 9:29 am
from the first look it should work on newer systems. As you can read above queries was introduced later on than some of your installations.
hrodriguesvt
Mon Apr 05, 2010 8:31 pm
Buddy, i've tried to use the same commands on ROS 3.2 and ROS4.5, none of them worked
normis
Tue Apr 06, 2010 12:16 pm
what didn't work?
janisk
Tue Apr 06, 2010 2:23 pm
exactly. It would be greate to see the output you got when you executed that php api.
proplist and queries was introduced only in later version 3 releases. that is, 3.30 have proplist, older may not.
Chupaka
Sun Apr 11, 2010 2:45 am
yep, check your $varloginid variable...
Chofex
Tue May 18, 2010 4:41 am
Did you get lucky with API and Visual Basic 6 ?
I'd REALLY appreciate if someone could tell me how to connect using VB6 to RouterOS API...
I don't mind paying for a component (something reasonable, please!)
I program using VB since 1993, and I use VB 6 every day at job. I've developed an ERP form my ISP also, and it would be very helpfull to connect it to my HotSpot!
Thanks in advance!
Chofex
Christiano
Wed Dec 08, 2010 8:57 pm
I think you want this:
http://forum.mikrotik.com/viewtopic.php?f=13&t=47274
Here you see what do you put in <your_id_here>. Perhapes you need a list of id. So look this link...
rpayan
How Edit a User
Thu Sep 15, 2016 10:37 am
Hello Everibody.
I'm using the version 6.x but I cant edit a user from API with c#. Can you help me.
Here is my code:
mikrotik.Send("/ip/hotspot/user/print", false);
mikrotik.Send("name=" + item.usuarioTicket, false);
mikrotik.Send("=.proplist=.id");
List<string> test = mikrotik.Read();
var x = test[0].Split('=');
mikrotik.Send("/ip/hotspot/user/set");
mikrotik.Send("=comment=killed");
mikrotik.Send("=.id=" + x[2].ToString(),true); //Here the index 2 correspond to my .id
mikrotik.Read();
mikrotik.Close();
Chupaka
Thu Sep 15, 2016 3:42 pm
and what message do you receive in response to the last request?
should be
mikrotik.Send("/ip/hotspot/user/set", false);
mikrotik.Send("=comment=killed", false);
I think :)
rpayan
Thu Sep 15, 2016 6:53 pm
Nothing :(
I get the full data in my variable test : !re=.id=*6=name=Juli26=password=EwMnI=profile=NITE=limit-uptime=1w23h59m40s=uptime=1h55m42s=bytes-in=1912229=bytes-out=1343304=packets-in=5843=packets-out=4392=dynamic=false=disabled=false=comment=life
So in this case x[2].ToString() correspond to *6, but I cant change the comment :(
mikrotik.Send("/ip/hotspot/user/set",false);
mikrotik.Send("=.id=" + x[2].ToString(), false);
mikrotik.Send("=comment=vencido", true);
mikrotik.Read();
mikrotik.Close();
Chupaka
Thu Sep 15, 2016 7:00 pm
--- mikrotik.Read();
+++ List<string> test2 = mikrotik.Read();
and see what's in test2
rpayan
Thu Sep 15, 2016 7:09 pm
test2 shows : "!trap=message=no such command prefix"
Chupaka
Thu Sep 15, 2016 8:09 pm
well, "/ip/hotspot/user/set" looks fine and works for me as a command :) maybe a typo in your actual code?..
rpayan
Fri Sep 16, 2016 10:45 pm
Thank So much
I got this works...
mikrotik.Send("=comment=vencido");
mikrotik.Send("=.id=" + userName, true);
rpayan
CALL SCRIPT FROM API
Fri Sep 16, 2016 10:55 pm
How could I call and run a script from API ??
I was trying this but doesnt work.
mikrotik.Send("/system/script/run", false);
mikrotik.Send("=name=nameScript", true);
mikrotik.Read();
mikrotik.Close();
I got in the Read... no such commad prefix
Chupaka
Mon Sep 19, 2016 2:59 pm
something strange again, just like the last time. this command DOES exist :)
/system/script/run
=.id=script1
!done
=ret=Hello, I'm a script! And this is my output
Users browsing this forum: Google [Bot] and 84 guests
