Eising
Default configuration on RB750
Fri Jul 17, 2009 3:23 pm
Hi there,
We're considering to go for the RB750 when it is available, but since there's no console port, I'm a little worried about provisioning, which is today done by a provisioning script and a cut'n'paste into the console.
What kind of configuration will the RB750 be shipped with?
The road to hell is paved with good intentions.
normis
Re: Default configuration on RB750
Fri Jul 17, 2009 3:26 pm
it's preconfigured with a DHCP client on the WAN port, and DHCP server on the bridge that's ports 2-5
it also has a masquerade rule and some basic firewall rules to prevent any access from the WAN side
Eising
Fri Jul 17, 2009 4:00 pm
Hi Normis,
Thank you very much for your reply.
An unexpected configuration, but nevertheless, I should be able to work with that.
normis
Fri Jul 17, 2009 4:01 pm
it's designed for ease of use. plug in LAN, plug in WAN, and it will work.
miahac
Long time Member
Long time Member
Sat Aug 08, 2009 5:20 pm
you could auto provision with a shell script since it will have default ip
Network Administrator
Kansas Hosting and Wichita Data Centers
ayufan
Sat Aug 08, 2009 5:51 pm
normis: what about netinstall? will it be possible?
hAP AC, TP-Link Archer C7 v2, RB951G, RB450G, RPI2, RPI zero
mrz
Sat Aug 08, 2009 6:32 pm
Yes, you will be able to use netinstall.
ayufan
Sat Aug 08, 2009 6:57 pm
how? with reset button?
normis
Mon Aug 10, 2009 3:52 pm
yes, reset button will load etherboot.
ayufan
Mon Aug 10, 2009 4:03 pm
is that feature already/will be present in other routerboards? it's simplier than using null-modem...:)
normis
Mon Aug 10, 2009 4:04 pm
currently it's not possible. it's not a software thing
ayufan
Mon Aug 10, 2009 4:47 pm
but i thinks is in RouterBOOT, so why you wont add it?
uldis
Mon Aug 10, 2009 4:50 pm
In future Routerboot versions maybe.
ayufan
Mon Aug 10, 2009 5:01 pm
or at least add option to /system/routerboard:
boot-device=if-reset-push-boot-from-ethernet
it shouldn't be that hard...
it would help many routerboard administrators
who uses netbooks/notebooks and doesn't have builtin serial port...
wolkan
Tue Aug 25, 2009 5:48 pm
Does it have a Serial Port header on PCB?
Why dont you upload a photo of RB750's board to routerboard.com? there are only photos of plastic case..
janisk
Wed Aug 26, 2009 12:39 pm
no, there is no possibility to connect serial COM cable to RB750. Therefore additional reset button functionality.
msorensen
Wed Aug 26, 2009 8:31 pm
What is the latest news on the availability of the RB/750?
I've had some on backorder for more than a month....
janisk
Thu Aug 27, 2009 2:18 pm
please contact sales@mikrotik.com with that question.
roc-noc.com
Forum Veteran
Forum Veteran
Sat Sep 05, 2009 1:58 pm
Ours landed yesterday and we will begin shipping them on Tuesday (Monday is a US holiday).
I think they began shipping this week to all distributors (who ordered them in July) so you should see yours soon.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
ronniee
Wed Sep 09, 2009 4:02 pm
any chance to make in near future a cheep RB750 with a wireless card?
now every people has a laptop, he need a wifi soho router, not only cable version
normis
Wed Sep 09, 2009 4:03 pm
if there is need for such products, of course we will make them. and I see that there is need for this, so just wait :)
hedele
Sun Sep 13, 2009 11:06 am
Yeah great, a Wireless-enabled rb750 would greatly help Mikrotik usage in our projects :)
normis, do you also see the need for products like a Routerboard with included ADSL2+ or SHDSL.bis connectivity?
Actually that would be awesome, we provide UMTS Backup for our landline DSL services, and as-is we have to give the customer
at least 2 boxes, a Modem and a RB433UAH with USB UMTS Stick...
joecoolzxc
Tue Oct 13, 2009 3:53 pm
Does this Soho Router have same configurability as a RB450? full mikrotik router features?
normis
Tue Oct 13, 2009 4:55 pm
yes
jcheney
Thu Jul 08, 2010 3:42 pm
If I could get a wireless RB750 for less than $100 US, I would probably end up buying 10 or 12 a year, just in my little corner of the world.
normis
Fri Jul 09, 2010 12:49 pm
working on it
ayufan
Fri Jul 09, 2010 1:01 pm
normis wrote:
working on it
any ETA? i would like to buy too :)
gabak
Sat May 28, 2011 2:58 am
here it is the default script if somebody want it
#| ether1 is renamed ether1-gateway, rest of interfaces are switched
#| IP address 192.168.88.1/24 is on switch
#| DHCP client is on ether1-gateway
#| DHCP server is on switch, with address pool 192.168.88.10-192.168.88.254
#| masquerade on ether1-gateway
:global action
# these commands are executed after installation or configuration reset
:if ($action = "apply") do={
/interface set ether1 name=ether1-gateway
/interface set ether2 name=ether2-local-master
/interface set ether3 name=ether3-local-slave
/interface set ether4 name=ether4-local-slave
/interface set ether5 name=ether5-local-slave
/interface ethernet set ether3-local-slave master-port=ether2-local-master
/interface ethernet set ether4-local-slave master-port=ether2-local-master
/interface ethernet set ether5-local-slave master-port=ether2-local-master
/ip address add address=192.168.88.1/24 interface=ether2-local-master comment="default configuration"
:if ([:len [/system package find name="dhcp" !disabled]] != 0) do={
/ip dhcp-client add interface=ether1-gateway disabled=no comment="default configuration";
/ip pool add name=default-dhcp ranges=192.168.88.10-192.168.88.254;
/ip dhcp-server add name=default address-pool=default-dhcp interface=ether2-local-master disabled=no;
/ip dhcp-server network add address=192.168.88.0/24 gateway=192.168.88.1 dns-server=192.168.88.1 comment="default configuration";
/ip firewall {
filter add chain=input action=accept protocol=icmp comment="default configuration"
filter add chain=input action=accept connection-state=established in-interface=ether1-gateway comment="default configuration"
filter add chain=input action=accept connection-state=related in-interface=ether1-gateway comment="default configuration"
filter add chain=input action=drop in-interface=ether1-gateway comment="default configuration"
nat add chain=srcnat out-interface=ether1-gateway action=masquerade comment="default configuration"
/ip dns {
set allow-remote-requests=yes
static add name=router address=192.168.88.1
/tool mac-server remove [find]
/tool mac-server add interface=ether2-local-master disabled=no
/tool mac-server add interface=ether3-local-slave disabled=no
/tool mac-server add interface=ether4-local-slave disabled=no
/tool mac-server add interface=ether5-local-slave disabled=no
/tool mac-server mac-winbox disable [find]
/tool mac-server mac-winbox add interface=ether2-local-master disabled=no
/tool mac-server mac-winbox add interface=ether3-local-slave disabled=no
/tool mac-server mac-winbox add interface=ether4-local-slave disabled=no
/tool mac-server mac-winbox add interface=ether5-local-slave disabled=no
/ip neighbor discovery set [find name=ether1-gateway] discover=no
# these commands are executed if user requests to remove default configuration
:if ($action = "revert") do={
/ip firewall {
:local o [nat find comment="default configuration"]
:if ([:len $o] != 0) do={ nat remove $o }
:local o [filter find comment="default configuration"]
:if ([:len $o] != 0) do={ filter remove $o }
:local o [/ip dhcp-server network find comment="default configuration"]
:if ([:len $o] != 0) do={ /ip dhcp-server network remove $o }
:local o [/ip dhcp-server find name="default" address-pool="default-dhcp" interface=ether2-local-master !disabled]
:if ([:len $o] != 0) do={ /ip dhcp-server remove $o }
/ip pool {
:local o [find name=default-dhcp ranges=192.168.88.10-192.168.88.254]
:if ([:len $o] != 0) do={ remove $o }
:local o [/ip dhcp-client find comment="default configuration"]
:if ([:len $o] != 0) do={ /ip dhcp-client remove $o }
/ip dns {
set allow-remote-requests=no
:local o [static find name=router address=192.168.88.1]
:if ([:len $o] != 0) do={ static remove $o }
/ip address {
:local o [find comment="default configuration"]
/tool mac-server add interface=all disabled=no
/tool mac-server mac-winbox remove [find interface!=all]
/tool mac-server mac-winbox set [find] disabled=no
/ip neighbor discovery set [find name=ether1-gateway] discover=yes
/interface ethernet set ether3-local-slave master-port=none
/interface ethernet set ether4-local-slave master-port=none
/interface ethernet set ether5-local-slave master-port=none
/interface set ether1-gateway name=ether1
/interface set ether2-local-master name=ether2
/interface set ether3-local-slave name=ether3
/interface set ether4-local-slave name=ether4
/interface set ether5-local-slave name=ether5
Users browsing this forum: No registered users and 6 guests
