Equis
Forum Veteran
Forum Veteran
Routerboard 500 Default IP Address
Mon Jun 06, 2005 7:49 am
I have a Routerboard 500 from Wisp-Router as an AP Bundle.
Can someone tell me the Default IP address to log in?
normis
Mon Jun 06, 2005 9:43 am
you should contact wisp-router as they configured your router.
Equis
Forum Veteran
Forum Veteran
Mon Jun 06, 2005 9:48 am
Ok Thanks
I was able to use a rs232 cable and got in that way
Thanks Again
mfennell
Mon Jun 06, 2005 7:48 pm
Just so everyone knows, its on the paper work that wisp-router sends with the unit. Its something like 10.10.10.1
hitek146
Wed Jun 08, 2005 10:09 pm
Since the 3rd Ethernet port is the last one to get dedicated to a non-management purpose, I use it for management at it's default address of 10.1.1.1, pre-programmed by Wisp-Router.....
Hitek
hitek146
Fri Jun 10, 2005 4:45 am
With our latest batch of RB532s, I see that Wisp-Router did not pre-assign IP addresses to the interfaces. Also with the latest batch, I was unable to control the OS through the serial console port. I could enter the boot loader and set options, and I could watch the board boot, but after the words "Starting Services...." appeared on the screen, I would see no more text, and the boards would not take anymore input, even though they booted just fine. I haven't investigated that, since I was able to assign the interfaces IP addresses through WinBox.....
Hitek
normis
Fri Jun 10, 2005 9:16 am
if something like that happens, it is possible that the Baud Rate is wrong. Change to 9600 in your terminal program, or to 115000
Users browsing this forum: No registered users and 3 guests
