otgooneo
Trainer
Trainer
script based on logs
Wed Jun 22, 2011 12:04 pm
Good day to all,
I have an idea that can read log and change some dynamic user parameters. It is useful while PPPoE server of Router OS doesn`t support CoA. So...
1. I can send CoA request from radius server
echo "User-Name := 'TestUser', Mikrotik-Rate-Limit := <NewSpeed>" | radclient -x -r 3 <ROS ip address>:1700 coa <RadiusSecret>
2. RouterOS shows log, that does not support CoA request.
15:23:08 radius,debug,packet received CoA-Request with id 13 from 192.168.100.1:59547
15:23:08 radius,debug,packet     Signature = 0x434c1b2a9e830259251600a2cb745846
15:23:08 radius,debug,packet     User-Name = "TestUser"
15:23:08 radius,debug,packet     MT-Rate-Limit = "1024000"
15:23:08 radius,debug,packet sending CoA-NAK with id 13 to 192.168.100.1:59547
15:23:08 radius,debug,packet     Signature = 0x135b1bd932f3e9e1f7f8facdc4dcf3d4
15:23:08 radius,debug,packet     Error-Cause = 406
15:23:08 radius,debug,packet     NAS-Identifier = "MobiNetROS"
15:23:08 radius,debug,packet     NAS-IP-Address = 192.168.100.5
3. I can get needed information from this log. Username and new parameters etc, which is need to change.
foreach i in=[/log find where topics=radius,debug,packet] do={:put [log get $i message]
4. How can I find line, which includes text~"received CoA-Request with id"?. Also how can I get next 3 lines?
5. If I can get Username and MT-Rate-Limit, I can do commands
/queue simple set [/queue simple find name=$UsernameOfCoA] limit-at="$MT-Rate-LimitOfCoA"
:log info message="$UsernameOfCoA has changed speed to $MT-Rate-LimitOfCoA"
Please advise.
otgooneo
Trainer
Trainer
Re: script based on logs
Fri Jul 01, 2011 10:30 pm
Hi guys, I tried to do two kind of speed booster on my broadband home internet service without disconnecting active users. Please advise me how to better this script. I have a PowerRouter2282 with FreeRadius server and about 500 active, 1000 total PPPoE users.
Priority1. On demand single speed booster
Priority2. Night speed booster for all users (speedx4)
1. ROS PPPoE server doesn`t support Radius CoA (Change of Authorization) yet. But when we try to send CoA request from FreeRadius, ROS shows log included username and some attributes. So I tried to use this log.
#add logging action to catch this log
/system logging add topics=radius,debug,packet prefix="" action=memory
When user purchase 10Mbps booster for 4 hours. Radius server will change "Rate-Limit=10Mbps, Framed-Pool=boosted" on it`s database and will send CoA request to ROS. As you see, after user name 1 more character "#". It will be used for simple queue comment and also identifies that started on demand speed booster for user1. When purchase speed booster if user account is off-line, we can not change comment of simple queue. Because there is no dynamic queue yet. In this case new boosted user will get address from pool "boosted". Now we can change comment of simple queue, if IP address is from "boosted".
/ip pool add name=boosted ranges=172.16.28.1-172.16.28.254
FreeRadius sends users requests one by one and always retries 3 times. Because some time ROS losses request.
echo "User-Name := '<pppoe-user1>#', Mikrotik-Rate-Limit := 10240k" | radclient -x -r 3 192.168.100.5:1700 coa Secret
After 4 hours FreeRadius will change back his database information and will send booster-off request. Now the additional character will be single space. It will replace comment of simple queue.
echo "User-Name := '<pppoe-user1> ', Mikrotik-Rate-Limit := 2048k" | radclient -x -r 3 192.168.100.5:1700 coa Secret
On the ROS log section, log will be show as below. We can see 3rd row is included Username, 4th row is included speed information.
02:20:38 radius,debug,packet received CoA-Request with id 168 from 192.168.100.1:41649
02:20:38 radius,debug,packet     Signature = 0x3fddd04e7ceb222901d1e7329836f4f3
02:20:38 radius,debug,packet     User-Name = "<pppoe-user1>#"
02:20:38 radius,debug,packet     MT-Rate-Limit = "10240k"
# After 4 hours, on demand booster will be off.
02:23:03 radius,debug,packet received CoA-Request with id 187 from 192.168.100.1:46705
02:23:03 radius,debug,packet     Signature = 0x8ffdbe8c36cef5d433ef64df6e7cbed6
02:23:03 radius,debug,packet     User-Name = "<pppoe-user1> "
02:23:03 radius,debug,packet     MT-Rate-Limit = "2048k"
Then I added script that runs every second.
#In the log section, to find internal ID of rows which include CoA request log. Script runs every second and looks logs of only that moment.
:foreach i in=[/log find where message~"received CoA-Request with id" time=[/system clock get time]] do={ \
#Internal ID will be *72a15 (* and hex number). So need to convert it to ROS friendly hex format (0x72a15)
:local idcoa ("0x".[:pick $i 1 [:len [$i]]]);
#Username of CoA request is third row for this log. So need to add 2 hex number. The result will be converted to dec number. #Because ROS not able to get result in hex numbers.
:local iduser1 [($idcoa+0x2)];
#Need to convert back this number from dec to hex (This dec to hex converter done by Petrn)
:local hexdigit 32
:local nibble
:local hex ""
:for i from=1 to=$hexdigit step=1 do={ \
   :set nibble ($iduser1&0xf)
   :set hex ([:pick "0123456789ABCDEF" $nibble ($nibble+1)].$hex)
   :set iduser1 ($iduser1>>4)}
#Now the result is ready in hex numbers. So we need to convert it to format of ROS internal ID
:local iduser ("*"."$hex");
#The rate limit value will be in the fourth row for CoA request log. Same way to calculate and find internal ID of rate limit.
:local idboost1 [($idcoa+0x3)];
:local nibble
:local hex ""
   :set nibble ($idboost1&0xf)
   :set idboost1 ($idboost1>>4)}
:local idboost ("*"."$hex");
#Now we already have log internal ID of Username and Rate-Limit. So need to pick clear value from text.
:local user [:pick [/log get $iduser message] 17 ([:len [/log get $iduser message]]-2)];
:local boost [:pick [/log get $idboost message] 21 ([:len [/log get $idboost message]]-1)];
#As radius request, next character of Username identifies that booster start request or booster stop request.
:local note [:pick [/log get $iduser message] ([:len [/log get $iduser message]]-2) ([:len [/log get $iduser message]]-1)];
#We have 3 variable Username, RateLimit and booster identification. So we will find queue of user and change speed and will do comment.
#If booster is started, comment will be "#", If booster is stopped there will be no comment.
/queue simple set [/queue simple find where name=$user] limit-at="$boost/$boost" max-limit="$boost/$boost" comment="$note";
#and the last command writes log that which user speed has changed. (Note: That will not exactly that user speed changed or not)
:log warning message="Single_Booster: $user changed speed to $boost $note";}
It works not bad. I have tested few times.
II. Now the second night booster for all users. But if user purchased on demand speed booster, we will not increase his speed again. My FreeRadius and ROS have same NTP server. Their clock is same. So the scripts can run separately on each other. Every day at 21:00 FreeRadius changes it`s database of all customers Rate-Limit="existing_speed x 4" excluding if Framed-Pool=boosted. At that moment, RouterOS runs below script.
#Need to add comment for all users, which are using On-Demand speed booster. Because we don`t want to increase their speed again x4.
#So find interface names of users, which got ip addresses from pool PPPoE_Baganuur. Because for PPPoE, interface and queue simple names are same.
:foreach a in=[ip address find where address~"172.22.28."] do={ \
:local intname [/ip address get $a interface];
#Using interface name, need to find dynamic simple queue and change comment.
/queue simple set [/queue simple find where name="$intname"] comment="#";}
:delay 1s;
#Now we commented all users, who are using On-Demand speed booster. Now we will multiplicate all simple queues without comment "#"
/queue simple; :foreach q in=[find where comment!="#"] do={ \
#Get value of Limit-At and pick only digits. Then need to multiplicate by 4000. Because my format is 1024k,512k,5120k etc. #$speed will be 2048000 if user existing rate was 512k.
:local speed [(([:pick [get $q limit-at] 0 [(([:len [get $q limit-at]]/2)-1)]])*4000)];
/queue simple set $q limit-at="$speed/$speed" max-limit="$speed/$speed";
:local userner [get $q name];
:log warning message="Night_Booster: speed of $userner has grown x4";}
I have tested it for 330 active users. Works no problem yet. Every morning at 09:00, FreeRadius and RouterOS will change all speed to normal case, using same scripts.
vishallumbhani
Thu Aug 30, 2012 7:09 am
I need to login static ip user for pppoe with remote radius server.
1) user will be connect with static ip as a username & password.
i am using MQNsure Radius server ( professional for ISP level )
sample diagram attached.
i configured COA as per your post. which work ok. thax for that.
Last edited by vishallumbhani on Thu Aug 30, 2012 11:02 am, edited 1 time in total.
otgooneo
Trainer
Trainer
Thu Aug 30, 2012 10:05 am
What kind of radius server you use? In my case, freeradius can set which IP need to pool to customer.
vishallumbhani
Thu Aug 30, 2012 11:08 am
I am using Profesional ISP level server for that.
i done configuration in CISCO ASR 1001.
all working with PPPOE
1) simple bandwidth plan
2) DAY NIGHT PLAN
3) Static IP as username for authentication.
4) IP subnet as username for authentication.
Heinsp
Thu Apr 13, 2023 11:03 am
I found a work around by setting the log limit to one and then back to 1000 clears the log, i do this manually but could work easier if you run a schedule for it
system/logging/action/set memory memory-lines=1
delay 5
system/logging/action/set memory memory-lines=1000
Users browsing this forum: Bing [Bot], ko00000000001 and 14 guests
