If you are CodeIgniter Framework Programmer, you can get Library for CodeIgniter Spark in this link :
Spark Library : http://getsparks.org/packages/mikrotik_api/show
Spark Repository : https://github.com/vthink/mikrotik_api
Documentation : http://doc.vthink.web.id
Updates Info : http://vthink.web.id/index.php/content/categories/21
if you have codeigniter but doesn't have a spark management package you can install it via terminal with this command :
Code: Select all
php -r "$(curl -fsSL http://getsparks.org/go-sparks)"
http://getsparks.org/install
