Vyrtu
Enable and Disable Ethernet ports
Thu Oct 03, 2013 12:00 pm
Hi, i'm newbie with API's Mikrotik right now, and I need some help :S
I need know how to enable and disable ethernet ports with api and php..
I was testing with these codes, but i cant fix them..Im so bad :(
if ($API->connect($ipRouteros , $username , $pass, $api_puerto)) {
   $API->write('/interface/ethernet',false);
   $API->write('=disable=ether4',true);
   $API->write("interface/ethernet",false);
   $API->write("=SET=");
   $API->write("ether4",false);
   $API->write("=disabled=yes",true);
P.D: I trying create 2 php, one of them to active an specific ethernet port, and another php to desactive it.
It's my first project with mikrotik API :S
Noob with Pear2 API :(
boen_robot
Re: Enable and Disable Ethernet ports
Thu Oct 03, 2013 12:17 pm
Think about how you do it from terminal.
If you do "/interface ethernet ?", you'll see "disable" is a command. If you then do "/interface ethernet disable ?", you'll see it accepts "numbers" as an argument, which is the interface(s) to disable.
Therefore:
$API->write('/interface/ethernet/disable',false);
$API->write('=numbers=ether4',true);
P.S. I'd really like to know what made you pick that particular PHP client.
PEAR2_Net_RouterOS(1.0.0b5) - My API client in PHP
(Rate my posts? If you want... no pressure...)
Vyrtu
Thu Oct 03, 2013 12:27 pm
Thanks, but i still having problems. It's my full code:
<?php require_once('routeros_api.class.php');
<?php
    $ipRouteros="192.168.2.1"; // tu RouterOS.
     $Username="adminapi"; // usuario API
     $pass="adminapi"; // contraseña del usuario API
     $api_puerto=8728; // Puerto API por defecto
$API = new routeros_api();
$API->debug = false;
$API->disconnect();
Vyrtu
Mon Oct 14, 2013 12:59 pm
My problem is solved. I post the final script.
<?php require_once('api_mt_include2.php'); ?>
<?php
// ESTE EJEMPLO SE DESCARGO DE www.tech-nico.com ///////////////////
// Creado por: Nicolas Daitsch. Guatrache. La Pampa ////////////////
// Contacto: administracion@tech-nico.com //////////////////////////
// RouterOS API: Busco interfaz ethernet y la activo o desactivo  //
$ipRouteros="200.20.30.40";  // tu RouterOS.
$Username="blog.tech-nico.com";
$Pass="tupassword";
$api_puerto=8728;
$name="ether1";    // -------> aqui el nombre de tu interfaz!!
if ($API->connect($ipRouteros , $Username , $Pass, $api_puerto)) {
       $API->write("/int/ether/getall",false);
       $API->write('?name='.$name,true);
       $READ = $API->read(false);
       $ARRAY = $API->parse_response($READ);
       if(count($ARRAY)>0){ // SI LA INTERFAZ EXISTE!!
            $id_interfaz = $ARRAY[0][".id"];
            $disabled = $ARRAY[0]["disabled"];
            if ($disabled=="true"){ // SI ESTA DESACTIVADA!!
                $API->write("/int/ether/enable",false);
                $API->write("=.id=".$id_interfaz,true);
                echo '<strong>'.$name.'</strong> esta ahora activada <img alt="" src="icon_led_green.png" /> ';
            }else{ // SI ESTA ACTIVADA!!
                $API->write("/int/ether/disable",false);
                echo '<strong>'.$name.'</strong> esta ahora desactivada <img alt="" src="icon_led_grey.png" /> ';
    }else{  //el servidor API esta of line
           echo 'Ocurrio un error: '.$ARRAY['!trap'][0]['message'];
}else{
    echo "<span style="color: #ff0000;">La conexion ha fallado. Verifique si el Api esta activo.</span>";
$API->disconnect();
Users browsing this forum: No registered users and 6 guests
