strods
6.33 version released!
Fri Nov 06, 2015 2:02 pm
6.32.3 has been moved to bugfix channel.
What's new in 6.33 (2015-Nov-06 12:49):
*) dns - initial fix for situation when dynamic dns servers could disappear;
*) winbox - dropped support for winbox v3.0beta and v3.0rc (use winbox v3.0);
*) dhcpv6 - various improvement and fixes for dhcp-pd client and ippool6;
*) defconf - fixed rare situation where configuration was only partially loaded;
*) net - fix possible never ending loop when bad CDP discovery packet is received;
*) log - make default disk file name to reside in flash dir if it exists;
*) romon - change port list to be not ordered in export;
*) capsman - limit number of simultaneous DTLS handshakes;
*) capsman - fixed memory leak on CAP joining CAPsMAN when ssld is used;
*) winbox - added allow-fast-path to eoip, gre & ipip;
*) winbox - do not show power-cycle properties on non poe ports;
*) l2tp: implemented PPPoE over L2TP in LNS mode, RFC3817;
*) webfig - some of the setting were shifted to the right;
*) packages - allow to reinstall from bundle to separate packages & vice versa;
*) packages - prefer out of bundle packages when both of them are installed;
*) packages - fix a problem of upgrading bundle package to non bundled ones;
*) ipsec - force flow cache validation once in 1h;
*) winbox - make sure that all setting names get shown in full;
*) winbox - added poe power-cycle-ping settings to ethernet interfaces;
*) ppp - handle properly case were ppp client is given same address for local & remote end;
*) winbox - added vlan-mode & vlan-id to virtual-ap interface;
*) winbox - added timeout column to ipv6 address lists;
*) winbox - show SFP Tx/Rx Power properly;
*) winbox - added min-links to bonding interface;
*) winbox - do not show health menu on RB951Ui-2HnD;
*) winbox - added support for Login-Timeout & MAC-Auth-Mode in hotspot;
*) cerm - added option to disable crl download in '/certificate settings';
*) winbox - make user ssh key import work again;
*) webfig - make "Copy to Access List" work in CAPsMAN Registration Table;
*) userman - fix report generation problem which could result in some users being skipped from it;
*) winbox - fix to allow cpu-port as mirror-target
*) proxy - error.html parsing enhancement to improve performance
*) CCR1072 - improve ether1 performance under heavy load
*) routerboard - indicate RouterBOOT type in /system routerboard print;
*) mpls - properly use mpls mtu for routes;
*) cerm - fix key description for signed certificates;
*) trafflow - report flow addresses in v1 and v5 without NAT awareness;
*) hotspot - add mac-auth-mode setting for mac-as-passwd option;
*) hotspot - add login-timeout setting to force login for unauth hosts;
*) auto-upgrade - fixed auto upgrade for smipsbe;
*) dns - do not create duplicate entries for same dynamic dns server addresses;
*) ipsec - fix set on multiple policies which could result in adding non existent dynamic policies to the list;
*) email - allow server to be specified as fqdn which is resolved on each send;
*) fastpath - eoip,gre,ipip tunnels support fastpath (new per tunnel setting "allow-fast-path");
*) ppp, pptp, l2tp, pppoe - fix ppp compression related crashes;
*) cerm - also accept downloaded CRLs in PEM format;
*) userman - added 'history clear' to allow flushing undo history, which may take up significant amount of memory for huge databases with hundreds of users;
*) health - fix voltage for CRS109, CRS112 and CRS210 if powered from external adapter;
*) userman - added phone number support to signup form;
*) ip pool6 - try to acquire the same prefix if info matches recently freed;
*) ipsec - fix transport mode ph2 ID ports when policy selects specific ip protocol on initiator;
*) ipsec - use local-address for phase 1 matching and initiation;
*) route - fixed crash on removing route that was aggregated;
*) ipsec - fix replay window, was accidentally disabled since version 6.30;
*) ssh - allow host key import/export;
*) ssh - use 2048bit RSA host key when strong-crypto enabled;
*) ssh - support RSA keys for user authentication;
*) wlan - improved WMM-PowerSave support in wireless-cm2 package;
*) pptp & l2tp - fixed problem where android client could not connect if both dns names were not provided (was broken since v6.30);
*) auto-upgrade - added ability to select which versions to select when upgrading;
*) quickset - fixed HomeAP mode;
*) lte - improved modem identification to better support multiple identical modems;
*) snmp - fix system scripts table;
*) tunnels - eoip,eoipv6,gre,gre6,ipip,ipipv6,6to4 tunnels now support dns name as remote address;
*) fastpath - active mac-winbox or mac-telnet session no longer suspends fastpath;
*) fastpath - added per interface fastpath counters;
*) fastpath - added trafflow support in basic ipv4 and fasttrack ipv4 fastpath;
*) ppp - added on-up & on-down scripts to ppp profile;
*) winbox - allow to specify dns name in all the tunnels;
*) pppoe - added support for MTU > 1492 on PPPoE;
*) cerm - fix scep server certificate-reply degenerate PKCS#7 signed-data content;
*) ppp-client - added default channels for Alcatel OneTouch L100V;
*) defconf - fix for boards that had bridge with only wlan ports;
*) ovpn: support OpenWRT ovpn clients (or any other with enable-small option enabled);
*) cerm - use certificate file name for imported cert name;
*) fetch - fixed error message when error code 200 was received;
*) cerm - rebuild crl for local ca if crl file does not exist;
*) winbox - make directed broadcasts work for neighbor discovery;
*) upnp: automatically adjust mappings to new external ip change;
*) ppp - added ppp interface to upnp internals/externals if requested;
*) ppp - when adding ipv6 default route use user provided distance;
*) userman - allow to correctly enable CoA on router;
*) cerm - show crl nextupdate time;
*) ppp - added CoA support to PPPoE, PPTP & L2TP (Mikrotik-Recv-Limit, Mikrotik-Xmit-Limit, Mikrotik-Rate-Limit, Ascend-Data-Rate, Ascend-XMit-Rate, Session-Timeout);
*) ppp - added new option under "ppp aaa" - "use-circuit-id-in-nas-port-id";
*) userman - refresh active sessions/users view dynamically;
*) package - added version tag and show everywhere alongside of version number;
*) wlan - improved 802.11 protocol single connection TCP performance for ac chipset with cm2 package.
freemannnn
Forum Veteran
Forum Veteran
Re: 6.33 version released!
Fri Nov 06, 2015 3:46 pm
"hotspot - add mac-auth-mode setting for mac-as-passwd option"
so what exactly does this? why is different from ip binding?
ddejager
Fri Nov 06, 2015 3:58 pm
I am running 6.33rc14 on a RB711GA-5HnD. I try to to winbox autoupdate on the "Current" channel. I'm told that the latest version is 6.33 as expected. I click on either download or download & install. In either case nothing gets downloaded and the message at the bottom of the winbox "check for updates" window says: "New version is available". Why does it not download and update?
The same thing happens on an STX HG5 radio.
In either case if I manually download and then copy to the files folder on the device and reboot the upgrade takes place.
krisjanis
It allows to use mac address both as user-name and password. Old one allowed it be used just as user-name. In some situations it might make things easier for various devices to login if mac login is enabled.
/ip hotspot profile set mac-auth-mode=
MacAuthMode ::= mac-as-username | mac-as-username-and-password
normis
Fri Nov 06, 2015 3:59 pm
Did it try to reboot? Reboot manually and see the LOG
freemannnn
Forum Veteran
Forum Veteran
Fri Nov 06, 2015 4:02 pm
so if i understand, if you have a hotspot you can tell a friend to login with his device (laptop,phone,tablet) mac address.
1. of course he needs to find mac address by going to device settings. right?
2. its an easy way for hotspot so you dont have to add usernames and passwords each time you want to give away a free access account. right?
krisjanis
Fri Nov 06, 2015 4:06 pm
@freemannnn
You still need to add that mac-address as user in your hotspot or radius, before that persons phone can get authenticated with system. but essentially, yes. This might be useful for all kind of mobile POS systems and things like that in environment where all devices are behind a hotspot server.
ddejager
Fri Nov 06, 2015 4:07 pm
It did not try to reboot. Nothing was in the log. I updated my original post to indicate that I could (and did) manually download and manually upgraded successfully.
CrazyMonkey
Fri Nov 06, 2015 4:31 pm
Thank you !!!
ganewbie
Fri Nov 06, 2015 5:47 pm
Thanks a million ;-)
Vaxter
Fri Nov 06, 2015 5:51 pm
WinBox is missing from build.
Ther is an 404 when clicked on winbox link in web interface.
StubArea51
Trainer
Trainer
Fri Nov 06, 2015 6:19 pm
Upgraded our CCR1072 to 6.33 and got an interesting error when trying to login
Looks like WInBox 3.0 is not a release candidate anymore :D Was able to get in after downloading Winbox 3.0.
andriys
Fri Nov 06, 2015 6:21 pm
That's actually mentioned in ChangeLog...
freemannnn
Forum Veteran
Forum Veteran
Fri Nov 06, 2015 6:39 pm
and what is this doing exactly...
msport
Fri Nov 06, 2015 8:39 pm
I would want to know that as well! Probably it is not what i need but still it would be interesting to have new features explained. Manual is not updated with info as far as i can see.
M
freemannnn
Forum Veteran
Forum Veteran
Fri Nov 06, 2015 10:10 pm
I found out, Add login-timeout is the timeout a device stays in hosts tab list . After that time it is deleted.
Balmungmp5
Trainer
Trainer
Fri Nov 06, 2015 10:12 pm
What was broken?
UpRunTech
Fri Nov 06, 2015 11:32 pm
Given the single stream TCP/IP speed up is in wireless-cm2, if we are not using Capsman v1 should we all start using wireless-cm2 instead of wireless-fp by default?
gius64
Fri Nov 06, 2015 11:57 pm
Speaking about that, if I would make my users to use wireless-cm2 on their CPEs, is this package mature enough also on point to multipoint?
The last time I changed my users wireless package was from "wireless" to "wireless-fp", but 6.30 did this automatically, so I simply upgraded all users to 6.30.
Are there any improvement to nv2 point to multipoint on wireless-cm2?
msport
Sat Nov 07, 2015 12:01 am
Thanks!
Really dont see the benefit, but then again, not used to the hotspot yet, but getting there.
M
krisjanis
Sat Nov 07, 2015 12:56 am
@msport, freemannnn
Regarding "login-timeout" for hotspot. In some situations there was a problem that automatic login or redirect to hotspot portal didn't occur for some reason. Mostly by host being to long in host table and/or user account could being added to hotspot/radius after it was already in host table. Usually people were solving this problem by script that deletes these host entries after a while or manually.
For more neat approach we added this timer. Which by default is disabled, so if desired then needs to enabled by setting it to interval value that best fits your setup.
ckleea
Sat Nov 07, 2015 1:08 am
My KVM image does not start. When click enable and start, it just briefly indicates start and then stopped.
timoid
Sat Nov 07, 2015 1:41 am
the final 6.33 still has the IPv6 addresses going missing bug... should I open a support case?
macgaiver
Sat Nov 07, 2015 2:05 am
Yes, definitely.
ckleea
Sat Nov 07, 2015 2:37 am
An update: openwrt x86 images work as before but debian i386 images does not. Logging shows kvm error. VNC does not allow me to connect.
nje431
Sat Nov 07, 2015 2:54 am
Please elaborate. And does this apply to EoIP ipsec?
andersonlich
Sat Nov 07, 2015 9:16 am
example configuration please. :D
andersonlich
Sat Nov 07, 2015 11:23 am
example please ?
as far as i know, default when create profile pppoe-server should be 1480, so we can put in 1492 ?
omidkosari
Trainer
Trainer
Sat Nov 07, 2015 11:29 am
Is it what i requested many years ago ??? http://forum.mikrotik.com/viewtopic.php?f=2&t=42698 "PPPoE option 82"
pe1chl
Sat Nov 07, 2015 11:31 am
Please add the possibility of using an arbitrary username and password.
(entered in a text field when configuring)
lishniy
Sat Nov 07, 2015 11:35 am
DNS fully broken for me.
/ip dns> print
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
/ip dns> set servers=8.8.8.8
MartijnVdS
Sat Nov 07, 2015 12:53 pm
/ip dns> print
Have you contacted MikroTik support and sent them a supout file?
Ulypka
Sat Nov 07, 2015 2:48 pm
Where is "fastpath - added per interface fastpath counters"?
I haven't found it.
jebz
Sun Nov 08, 2015 10:48 am
Torrent?
Going by past Torrent URLs this should work -
http://www.mikrotik.com/download/router ... 33.torrent
But it responds "Broken", past versions have torrented with this URL pattern.
aboiles
Sun Nov 08, 2015 3:28 pm
drusha
Sun Nov 08, 2015 7:39 pm
I confirm this KVM behavior with i386 Debian image on x86
ckleea
Mon Nov 09, 2015 12:28 am
The same still appears in the 6.34 release candidate. After downgrade back to 6.32.3, it is back to normal
bjornr
Mon Nov 09, 2015 12:58 am
After upgrading I see a lot of unsolicited HTTP requests towards 169.254.169.254:80 from all devices, on most of which no scripts or scheduled jobs are running. The request is rather persistent until the device receives some kind of answer, and happens (at least) after reboots.
This is the HTTP request:
GET /latest/meta-data/public-keys/0/openssh-key HTTP/1.1
Host: 169.254.169.254
Could anyone explain what my devices are suddenly asking for? Is this behaviour hinted at somewhere in the changelog?
bjornr
Mon Nov 09, 2015 1:29 am
[quote="bjornr"]After upgrading I see a lot of unsolicited HTTP requests towards 169.254.169.254:80 from all devices, on most of which no scripts or scheduled jobs are running. The request is rather persistent until the device receives some kind of answer, and happens (at least) after reboots.
Could anyone explain what my devices are suddenly asking for? Is this behaviour hinted at somewhere in the changelog?[/quote]
An update to the above: Below is what RouterOS 6.33 asks for. Seems to be remnants of some testing setup, with funny side effects when released to the public :-)
x.x.x.x - - [09/Nov/2015:00:12:04 +0100] "GET /latest/meta-data/public-keys/0/openssh-key HTTP/1.1" 200 604 "-" "-"
x.x.x.x - - [09/Nov/2015:00:12:05 +0100] "GET /latest/meta-data/hostname HTTP/1.1" 200 230 "-" "-"
Just for fun, I supplied the requested files. Something™ in the boot process sets the hostname from the second request:
[admin@those-are-my-juniper-bushes\n] >
I can't seem to find that the key has been installed anywhere, and since it does not seem to be applied to the "admin" account (the only preconfigured account) I'm anxious to find out what it really does.
kemerovo
Mon Nov 09, 2015 5:29 am
when will support igmp snooping ?
janisk
Mon Nov 09, 2015 8:35 am
bjornr and ckleea would be nice if you sent support output files to the support. Create the file after your attempt to start your image file.
Also, while at it, check if you have kernel and initrd files supplied for the configuration.
bjornr
Mon Nov 09, 2015 8:54 am
I just submitted the supout from one of the devices. Please note that I'm seeing this on regular units (RB-SXTs, RB75x, RB95x, etc), not a CHR image. This behaviour is not limited to the device from which I gathered the supout, it's common for all units that were updated to 6.33.
bronx
Mon Nov 09, 2015 1:22 pm
+1
chg123
Mon Nov 09, 2015 3:49 pm
Is the 404 on http://{routerip}/winbox/winbox.exe a bug or a feature?
Together with the incompatibility of the v3 betas of Winbox this really sucks.
strods
Mon Nov 09, 2015 3:56 pm
chg123 - Have you used Branding maker to modify this router? Winbox is not saved on router any more. It is on our server and you should be directed to http://www.mikrotik.com/download/winbox.exe
qwwwizx
Mon Nov 09, 2015 5:49 pm
solved my issues with NAT and Trafficflow :D
jarda
Mon Nov 09, 2015 6:24 pm
Not so good idea. It is preventing to download compatible winbox from ros device when no access to Internet from any reason. It is big step back.
Cha0s
Mon Nov 09, 2015 6:39 pm
I agree with jarda.
pe1chl
Mon Nov 09, 2015 6:48 pm
winbox.exe went from 125KB to 1620KB so I can understand that.
not so easy to understand why it increased so much in size...
NetflashTechnical
Mon Nov 09, 2015 7:58 pm
Ok, LNS Support! Does that include LAC support? It'd be nice to aggregate all our line edge routers to central powerhouse routers for PPPoE, and ideally if we can do separate domains it would let us set up a reseller network through our infrastructure!
Aarriaga
Mon Nov 09, 2015 8:27 pm
+1
+1
It's a good idea.
bardelot
Mon Nov 09, 2015 10:05 pm
In 6.33 my configured IPSec RoadWarrior tunnel stopped working. It will still connect and the client is able to reach the router but no systems behind it (multiple subnets including the same as the router). Interestingly everything is working when I enable packet sniffing or torch on the interface.
Anyone else affected by the same issue or able to explain it?
andriys
Mon Nov 09, 2015 10:11 pm
In 6.33 my configured IPSec RoadWarrior tunnel stopped working... Interestingly everything is working when I enable packet sniffing or torch on the interface.
Make sure your inner-tunnel IPsec traffic is exempt from Fasttrack.
rioven
Mon Nov 09, 2015 10:15 pm
This is my config (simple queue)
[admin@MikroTik] /queue simple> print
0 name="queue1" dst=Streamyx parent=none packet-marks="" priority=8/8
queue=synchronous-default/synchronous-default limit-at=0/0
max-limit=405k/4M burst-limit=425k/0 burst-threshold=384k/0
burst-time=10s/0s
1 name="QoS1" parent=queue1 packet-marks=QoS1 priority=1/1
queue=default-small/default-small limit-at=0/0 max-limit=0/0
burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
2 name="QoS7" parent=queue1 packet-marks=QoS7 priority=7/7
3 name="QoS8" parent=queue1 packet-marks=QoS8 priority=8/8
this is sample of /ip firewall mangle
6 ;;; QoS1
chain=prerouting action=mark-packet new-packet-mark=QoS1 passthrough=no
protocol=icmp in-interface=Streamyx log=no log-prefix=""
7 chain=postrouting action=mark-packet new-packet-mark=QoS1 passthrough=no
protocol=icmp out-interface=Streamyx log=no log-prefix=""
8 chain=prerouting action=mark-packet new-packet-mark=QoS1 passthrough=no
protocol=udp in-interface=Streamyx src-port=53,88 log=no log-prefix=""
9 chain=postrouting action=mark-packet new-packet-mark=QoS1 passthrough=no
protocol=udp out-interface=Streamyx dst-port=53,88 log=no log-prefix=""
10 chain=prerouting action=mark-packet new-packet-mark=QoS1 passthrough=no
protocol=tcp in-interface=Streamyx src-port=53,80,443 log=no
log-prefix=""
11 chain=postrouting action=mark-packet new-packet-mark=QoS1 passthrough=no
protocol=tcp out-interface=Streamyx dst-port=53,80,443 log=no
log-prefix=""
It was working on previous version 6.32.3
(edit..add more info)
bardelot
Mon Nov 09, 2015 10:35 pm
Indeed, thanks. Removing the FastTrack rules solved the issue. Will have to find a solution how to properly exempt the IPSec traffic from these rules now.
andriys
Mon Nov 09, 2015 10:39 pm
I guess they changes the core of WinBox architechture. WinBox used to download (and cache) a set of DLLs from the router on connect, one DLL per RouterOS package (i.e. system, wireless, security, etc.). Those DLLs is what actually implements UI for a particular package. WinBox 3 does not appear to be doing that any longer. Mikrotik devs, I guess, moved all the logic into the WinBox itself. That means they also introduced a new way for WinBox and the router to communicate which configuration options are available in the RouterOS version you are connected to at the moment. The main advantage of this approach is it will allow (sooner or later) Mikrotik guys to make WinBox truly portable without the need in Wine or similar crutches.
andriys
Mon Nov 09, 2015 10:42 pm
You can use a recently introduced 'ipsec-policy' firewall rule matcher. It should easily solve your task, provided you do not NAT your inner-tunnel traffic.
bardelot
Mon Nov 09, 2015 10:56 pm
I was trying to add a simple FastTrack rule for the related / established connections in the forward chain for inbound as well as outbound traffic.
With the IPSec policy matcher I don't see an option to solve it that easily as it will be either inbound or outbound. E.g. when I restrict the firewall rule to in,none it will still capture the out,ipsec traffic right? Or is there an option to apply a rule to non-ipsec traffic only regardless of the direction?
Edit:
I acutally solved it by marking the connections for both in,ipsec and out,ipsec policies which allows me to apply the FastTrack rule to non ipsec marked connections only.
agnostic
Tue Nov 10, 2015 12:17 am
hello after upgrade to ros 6.33 on rb951 and rb750 not available to work with smb anymore...just try to navigate through files and folders and connection gets dropped with no messages on log...cannot even read a file...downgraded again to 6.32.3 and fixed it :)
chg123
Tue Nov 10, 2015 1:05 am
Nope, I did not apply any branding maker. The Winbox link on the routers site still goes to the dead local winbox.exe link.
Really sad.
chg123
Tue Nov 10, 2015 1:07 am
If there is a chance for a really portable winbox please launch a natively looking mac version soon!
Xyl
Tue Nov 10, 2015 1:45 am
What has changed regarding MTU sizes on PPPoE interfaces?
I have been using 6.30.2 on a RB2011UAS-2HnD-IN and was able to use an MTU of 1500 bytes when connecting to my ISP's PPPoE server.
After upgrading to 6.33 I am no longer able to connect with an MTU of 1500 bytes. RouterOS keeps reverting back to 1480 bytes after connecting.
1488 was the max MTU I was able to set without it reverting back to 1480.
I have downgraded back to 6.30.2 for now where an MTU of 1500 bytes still seems to be working for me.
I'm not sure if I'm doing something wrong or if this is a bug. I have not yet been able to test out the versions between 6.30.2 and 6.33.
gius64
Tue Nov 10, 2015 3:51 am
Same problem here.
I opened a ticket to support!
If you can do the same, maybe they can look at the issue with more situations!
strods
Tue Nov 10, 2015 8:37 am
Everyone who is noticing unusual traffic on your router - we have managed to reproduce this issue and we will fix it as soon as possible. The router is checking the ssh key for amazon cloud installation environments, a feature coming later.
As a temporary workaround you can use this solution:
/ip route add distance=1 dst-address=169.254.0.0/16 type=blackhole
normis
Tue Nov 10, 2015 8:48 am
Really sad.
Please post a screenshot of the problem. Which Winbox link specifically is not working
strods
Tue Nov 10, 2015 8:50 am
jarda - Winbox is too large to store it on router. Since there are flash directories on routers for a while now and HDD space is limited we decided to store Winbox on our download site. Any way Winbox is portable tool and even if you do not have internet access and you want to use router, then there is always Webfig, CLI and you can carry Winbox on your USB drive.
chg123 - Can you please write to support and send supout file from your router and also make a screen shot from the place where you try to download Winbox?
karina
Tue Nov 10, 2015 10:48 am
Netmetal 5 No SNMP since upgrade. anybody else having same issue before I report this?
strods
Tue Nov 10, 2015 11:12 am
karina - Please be more precise. Are you using snmpget? If yes, then which values are you not being able to get? What error do you receive?
ckleea
Tue Nov 10, 2015 11:27 am
I use Debian Wheezy and Jessie to install the KVM. After successful installation, I take out the reference to the netinstall iso image, then I can boot into the debian directly without the need of kernel or initrd files in the setting. It is different from that of the image prepared from openwrt x86.
pe1chl
Tue Nov 10, 2015 11:35 am
Hmm that is not good... I will have to stick with 6.32.3 until this is fixed!
I note that with that version MTU 1500 on a PPPoE link is working fine, but the router does not seem to do the RFC4638 negoitiation that is mandatory for a larger MTU than 1492.
Maybe in 6.33 the support for RFC4638 was added, although it is not mentioned in the release note?
This can mean two things: either the RFC4638 support is broken and thus the router falls back to a lower MTU, or your ISP does not support RFC4638 and there is no longer a way to still override the MTU as before.
The limit of 1488 is strange, it should be 1492 for PPPoE connections over a 1500 byte medium.
Is your PPPoE link running over plain ethernet or on top of a VLAN? What modem do you use?
juanvi
Tue Nov 10, 2015 2:44 pm
+1
normis
Tue Nov 10, 2015 2:48 pm
+1
This frees up a lot of space in the router, and ensures you always get newest Winbox. When you have no access to internet, you still have Webfig, which is 1:1 in layout and features.
Cha0s
Tue Nov 10, 2015 2:54 pm
Yeap. It frees a whole 1.5 mbyte of data! HUGE savings! :D
We can now use our routers as fileservers with so many data free! :lol:
juanvi
Tue Nov 10, 2015 3:07 pm
You are right but I used to dowload winbox from router because winbox works better than webfig. It's hard for me to understand how much can cost 1MB in year 2015... IMHO... There you will be getting very far maximizing profits/cutting costs?
Respectfully, juanvi
Xyl
Tue Nov 10, 2015 3:15 pm
Uplink runs from the RouterBOARD to a TP-Link SG3210 switch which then goes out over a VLAN to an ethernet to fiber media converter to my ISP.
An MTU of 1500 seems to be working fine when using 6.30.2, confirmed by pinging various hosts over the internet with a data length of 1472 bytes and fragmentation disabled and checking via a packet capture done on the RB2011. I was also able to confirm that pinging with a data length of 1472 bytes is no longer working on 6.33.
I will try to get and post packet captures of what happens on 6.30.2 and on 6.33 when connecting to the PPPoE server using various MTU sizes.
At first glance it seems that the ISP's PPPoE server first tries to acknowledge an MTU of 1500 by itself. So the ISP side supports and defaults to an MTU of 1500.
normis
Tue Nov 10, 2015 3:18 pm
some SPI based products have 16 and 8MB of storage, so yes, that is a lot.
war3boy
Tue Nov 10, 2015 4:10 pm
I have a weird issue that , my CPU keep spam up to 50% and then it will start over.
Even router in IDLE mode it is still spamming up to 50%.
Anyone facing this issue before? I have no clue what is happening on this.
normis
Tue Nov 10, 2015 4:45 pm
Open "Tool -> Profile" and see what is causing it.
slarocque
Tue Nov 10, 2015 5:03 pm
Hi folks. Is there somewhere that indicates if a new version of RouterOS (such as 6.33) is a "security" update? that is, how urgent is it to upgrade production machines from 6.32? I imagine there is some indicator somewhere I am overlooking on the wiki or release notes or email notifications that says this.
Thanks,
Steve
BartoszP
Tue Nov 10, 2015 5:07 pm
Rule of thumb: If it is not broken, then do not fix it.
If your network is working why do you want to change/fix it ?
slarocque
Tue Nov 10, 2015 5:10 pm
Thanks for your reply. The trouble is that I don't know about a security vulnerability (that is, if it is "broken"). I have a working system and would rather not update it unless it addresses a security vulnerability. Hence the request.
BartoszP
Tue Nov 10, 2015 5:16 pm
It is changelog: http://www.mikrotik.com/download
slarocque
Tue Nov 10, 2015 5:22 pm
Thanks. I didn't see anything in there that sounds to me like an important security hole is patched, so I will leave things at 6.32 for now.
Cheers,
Steve
rac
Tue Nov 10, 2015 5:41 pm
The Dude is loosing interest in RouterOS devices. The package information was lost before in the device list (tab RouterOS) - now also the RouterOS version is gone. This view was a great help for updates.
Are there such changes in some API or is it gone by mistake?
Xyl
Tue Nov 10, 2015 7:21 pm
Same problem here.
I opened a ticket and included supout.rif and packet capture files for both 6.30.2 and 6.33.
My ISP does have support for RFC4638 and reports a max payload of 1500 bytes.
Excerpt from packet capture under RouterOS 6.33 (also by comparing packet captures between 6.30.2 and 6.33 I was able to confirm that RFC4638 has been added in 6.33, as the PPP-Max-Payload tag is missing on 6.30.2):
No.     Time           Source                Destination           Protocol Length Info
     15 3.054014       Routerbo_xx:xx:xx     Broadcast             PPPoED   42     Active Discovery Initiation (PADI)
Frame 15: 42 bytes on wire (336 bits), 42 bytes captured (336 bits)
Ethernet II, Src: Routerbo_xx:xx:xx (d4:ca:6d:xx:xx:xx), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
802.1Q Virtual LAN, PRI: 0, CFI: 0, ID: 6
PPP-over-Ethernet Discovery
    0001 .... = Version: 1
    .... 0001 = Type: 1
    Code: Active Discovery Initiation (PADI) (0x09)
    Session ID: 0x0000
    Payload Length: 18
    PPPoE Tags
        Host-Uniq: 00dc0001
        PPP-Max-Payload: 05dc
     16 3.057052       HuaweiTe_xx:xx:xx     Routerbo_xx:xx:xx     PPPoED   65     Active Discovery Offer (PADO) AC-Name='195.xxx.xxx.xxx'
Frame 16: 65 bytes on wire (520 bits), 65 bytes captured (520 bits)
Ethernet II, Src: HuaweiTe_xx:xx:xx (e0:97:96:xx:xx:xx), Dst: Routerbo_xx:xx:xx (d4:ca:6d:xx:xx:xx)
802.1Q Virtual LAN, PRI: 7, CFI: 0, ID: 6
    .... 0001 = Type: 1
    Code: Active Discovery Offer (PADO) (0x07)
    Session ID: 0x0000
    Payload Length: 41
    PPPoE Tags
        Host-Uniq: 00dc0001
        AC-Name: 195.xxx.xxx.xxx
jarda
Tue Nov 10, 2015 11:34 pm
I can understand that. I also have the winbox on my computer for such reason. But I liked the possibility to grab the winbox directly from any ros device (excluding smips due to low disk space). There is no need to spare 1,5MB on devices having 64MB or more flash.
Why not to have winbox as separate package, preinstalled by default in devices that has enough space for it and without it on low space devices?
jarda
Tue Nov 10, 2015 11:36 pm
I do not see this behaviour on my laboratory devices. It looks correctly like with previous versions.
kemerovo
Wed Nov 11, 2015 3:35 am
to my messages and no one answers , it's sad((
shinobi
Wed Nov 11, 2015 7:16 am
Really sad.
on my CCR the link is correct, but on x86 and mipsbe the link refer to router itself:
Genkun
Wed Nov 11, 2015 7:33 am
No :D
strods
Wed Nov 11, 2015 8:49 am
shinobi - Can you test with another browser or clear cache? At this point it seems that cache might be causing this issue.
rac
Wed Nov 11, 2015 11:34 am
In my screenshot the "white labeled versions" have been updated to 6.33 and the last column lost it's content I think about half a year ago.
war3boy
Wed Nov 11, 2015 12:16 pm
It is management that causing it.
snoozer
Wed Nov 11, 2015 12:36 pm
I have updated a CCR1036-12G-4S from 6.32.3 to 6.33 this morning at 06:00 ish and just now (4h later) the router rebooted for no apparent reason.
remote syslog shows only:
Nov 11 10:09:28 [IP-Addrsss] system,error,critical router was rebooted without proper shutdown
Have other people have experience sudden reboots ? I can rule out a power issue.
Regards
Jan
shinobi
Wed Nov 11, 2015 2:02 pm
indeed before posting here, i did that. in IE, Firefox and also google chrome. sure it's not cached.
jarda
Wed Nov 11, 2015 2:31 pm
As I said, not a problem in my case:
Maybe some other problem you have than general problem of v 6.33...
normis
Wed Nov 11, 2015 2:41 pm
We plan to make a new Dude release this year, it should fix this, and many other bugs that have been gathered over the last years. Please post about RouterOS v6.33 and make new Dude posts in a separate thread.
Chupaka
Wed Nov 11, 2015 2:43 pm
checked my x86 installation - the link points to mikrotik.com...
yahooo!!!
strods
Wed Nov 11, 2015 3:03 pm
shinobi - Please send supout file to support@mikrotik.com
napismizpravu
6.33; 6.34rc3 error USB Flash disk.
Wed Nov 11, 2015 4:12 pm
RB433UAH (power 24V 2A) 6.33 ; 6.34rc3
After several versions reappeared error USB Flash disk.
doush
Long time Member
Long time Member
Wed Nov 11, 2015 4:27 pm
Man ...
Best news. Thanks a lot.
Kraken2k
Wed Nov 11, 2015 5:19 pm
Updated 3 days ago... I really hoped that route cache overflow issue will be solved by this update but... no :( the issue was reported more than 4 years ago, not just once and repeatedly with no fix, workaround or even finding the source of this issue.
If you put it together: there is a "feature" called ip route cache, which cannot be printed (so you don't know what is inside), cannot be flushed without router reboot and just constantly grows, despite the fact you turned it off in the ip settings. The only thing you can do is just sit back and watch it growing until its max value (you can't change that one either) is reached and your device stops all IPv4 traffic and force you to restart it every three or four days at least. Pretty frustrating after all those months if you ask me.
Reported by myself to MT support 3 months ago... Ticket number #2015081766000633 but they were unable to help or identify the cause if this issue. Seriously, I ran out of ideas.
jarda
Wed Nov 11, 2015 5:52 pm
We plan to make a new Dude release this year...
This year? Does it mean year 2015 as usually counted on this planet - after the born of Jesus Christ?
Holy Jesus! Lets go to pray for Dude!
pe1chl
Wed Nov 11, 2015 8:08 pm
So it looks like its implementation is broken in the router :-(
Let's see what the result of the ticket is. For now I will not update...
changeip
Wed Nov 11, 2015 11:08 pm
So how do you move firewall / other rules in webfig? There is no re-ordering capability as far as I can tell so I have to keep using winbox.
Chupaka
Wed Nov 11, 2015 11:23 pm
well, I drag it - and it moves :) just like in WinBox...
105547111
Thu Nov 12, 2015 2:32 am
New Dude - ah :)
kemerovo
Thu Nov 12, 2015 3:34 am
I hope in the new release will be finalized multicast and IGMP, I'm tired to use routers from other manufacturers for normal viewing of IPTV wi-fi, 'cause when I start viewing HD IPTV via wi-fi picture fray and computers from the local network do not meet , and in the log File, pops up a message that the loop can be as soon as I switch off all IPTV continues to operate normally , I ask you to correct this problem please:
macgaiver
Thu Nov 12, 2015 8:48 am
As far as my testing goes (I'm not an expert in this all LNS/LAC stuff), configuration looks straight forward
There are new menu:
/ppp l2tp-secret
You need to specify IP address of remote end where L2TP will be created to.
pppoe packet Pre-Authorization feature is not supported atm, but is coming soon
WDS
Thu Nov 12, 2015 9:16 am
I have the same situation on my RB951G-2HnD. The link points to the local winbox storage on the router and is actually dead (404). Tried different browsers, for sure this is not cache issue.
But on another device mAP 2n the link works and points to mikrotik website download location.
And yes, I fully support Jarda on the proposal to make a separate package with winbox so it could be installed on a router as an optional module for those who need it I'm one of them, actually.
strods
Thu Nov 12, 2015 10:10 am
okoun
Thu Nov 12, 2015 10:12 am
Hello, it is not working on the latest version 6.33 radius requirement Coa. I do not know if I have something of a special turned on routerboard except incoming. Routerboard after sending this command:
echo "User-Name=test" | /usr/bin/radclient -d /etc/freeradius/ -r 2 -x 10.55.1.54:3799 coa "mikrotik-rate-limit=10M/10M 20M/30M 950k/9500k 2000/20000" "secret"
just writes bad request the counter icoming.
andriys
Thu Nov 12, 2015 10:49 am
Try enabling multicast helper in your wireless interface settings. Please note that 'default' means 'disabled' currently.
andriys
Thu Nov 12, 2015 10:53 am
You probably need to supply RADIUS attributes (like 'Acct-Session-Id') to identify a particular user session, not just the user itself. Haven't tried it myself, just guessing.
strods
Thu Nov 12, 2015 2:38 pm
shinobi - We managed to reproduce your problem with Winbox link. It is now reported to our developers. It should be fixed in next version. Thank you!
pe1chl
Thu Nov 12, 2015 7:21 pm
It was also an item for user Xyl.
Will the fix be in 6.34 only or will there be a 6.33.x version that fixes it too?
(so I know to skip 6.33 if not)
barmaley
Fri Nov 13, 2015 6:24 am
updated yesterday
ntp server disappeared in 6.33
[...@MikroTik] > /system ntp
client export
no announcement in a change log
strods
Fri Nov 13, 2015 7:00 am
pe1chl - Of course, it will be included in next bug-fix version as it is a fix for a bug not a new feature.
normis
Fri Nov 13, 2015 10:26 am
updated yesterday
client export
did you include the NTP server package when you updated? is it enabled?
chg123
Fri Nov 13, 2015 11:02 am
Really sad.
Here's the Screenshot. What you cannot see is my mouse pointer hovering over the winbox icon. On the left bottom you see the URL behing this icon which is http://{routerip}/winbox/winbox.exe
[attachment=0]winboxlink.PNG[/attachment
I would like to suggest that the router hosted winbox.exe is an OPTION. Alle the folks with small memory size routers can save space and on all bigger devices winbox can be added as a package or in any other convenient way.
Webbox definitely IS A GREAT alternative. But once you get into trouble with IP addresses and need mac based communication or just want to "inspect" the available devices webbox comes to its end. Also the terminal of webbox does not run as rock solid as the one inside winbox.
I would REALLY appreciate a native Mac version of Webbox.]
normis
Fri Nov 13, 2015 11:14 am
Looks like you will need to Netinstall the device to replace some old/incorrect HTML file with the new one that links to correct winbox :(
bondkbc
6.33 version PROBLEM
Fri Nov 13, 2015 12:31 pm
Hi, I have problem with queues and download limit when its updated to v6.33. I'll upload you a picture to see. When I disable a fasttrack its start to working. It's a big problem for me becouse I have a lot of RB with that version.
strods
Fri Nov 13, 2015 1:28 pm
bondkbc - That is whole point of FastTrack. If connection is "fasttracked" then it will not be checked by other firewall rules and queues.
zojka
Fri Nov 13, 2015 4:06 pm
Problem with connection via PPTP in 6.33 for x86, correct login and password but got error 619 or 628.
It's looks like the same problem as 6.31 fixed in 6.32
I downgraded to 6.32.2 and works fine
Abdock
Fri Nov 13, 2015 7:42 pm
I am using Radius manager API dynamic speed, and it was working till 6.30.2 and then when i upgraded in between it broke today i was trying to troubleshoot and finally decided to downgrade and it started working again, whats changed in 6.30.2 > anybody else noticed this ?
thanks,
Chupaka
Sat Nov 14, 2015 12:46 am
Probably, it's changing dynamic queues' parameters, and now dynamic queues are read-only. You should switch to newly-added CoA
rextended
Sat Nov 14, 2015 12:55 pm
updated yesterday
client export
NTP package are missing from smips only.
The user not specify what routerboard try to use.
I have try to access branding maker page to fix the html link on my branded pages, from
/winbox/winbox.exe (for non-smips)
or
http://mt.lv/winbox (for smips)
to
I can successfully login and I see some of my device,
but on branding maker page i do not see any item,
and when I click on log out this message appear:
"Access Denied! (email address of user 0 is banned)"
This error appear also if I simply log in and log out on www.mikrotik.com account page.
The branding page are down because you are working on it?
Thanks.
oyermolenko
Sat Nov 14, 2015 3:34 pm
Hi, All,
Mikrotik RB750Gr2, upgraded to 6.33
still observed this strange issue:
working through LAN interface !
1. from "quick set":
1.1 change mode from dhcp to static
1.2 enter correct IP/mask/gateway/dns (for example, 8.8.8.8) !!!
2. apply configuration.
there is no internet access.
investigation: observing "unreachable" status on default route
3. enter any diff dns server (for example, 8.8.4.4) and apply configuration again.
And ... what do you think ? ... default route became reachable ... :-( strange ...
To sum up:
- wan mode change can be completed only from LAN and in two steps ...
tensink
Sun Nov 15, 2015 6:30 pm
My CRS125-24G-1S-2HnD (mipsbe) is currently running RouterOS v6.30.1. When I try to use the "Check For Upgrades" option it returns "Could not resolve address upgrade.mikrotik.com". The DNS servers are configured to 8.8.8.8 and 8.8.8.4. What should I do to solve this?
cdemers
Sun Nov 15, 2015 11:42 pm
Check your gateway settings, can you do a traceroute?
Sent from my Nexus 5 using Tapatalk
BartoszP
Mon Nov 16, 2015 1:19 am
Probably router asks DNS server from interface which is not NATed or masquaraded properly and DNS's responses are "lost in space".
Neilson
Mon Nov 16, 2015 8:47 am
Just a note (don't think this will help with your issue of not finding the server) but the second server should be 8.8.4.4 (2 8's and 2 4's). Hopefully this may help with DNS stability.
Regards
Alexander
saaremaa
Mon Nov 16, 2015 11:42 am
I send commands from the server to the NAS mikrotik
echo "User-Name=pppoeuser-1, NAS-IP-Address=123.17.8.34,Mikrotik-Rate-Limit = '1M 1536k 768k 8 8 1M'," | radclient -r 2 123.17.8.34:3799 coa  drowssap
And I get answers
Received response ID 198, code 44, length = 45
        NAS-Identifier = "KGD-123-17-8-34"
        NAS-IP-Address = 123.17.8.34
In simple queue automatically appears constraint pppoe user-1. Everything is working. Check the command syntax, available port radius and password
karwos
Tue Nov 17, 2015 1:05 am
Dear support,
FIRST of ...
SFP DDM has gone in this (or some of previous) version.
I could read DDM data normally from my SFP modules (AscentOptics OEM, branded and popular in Poland like OPTON, OPTEC, etc) from other devices, like :
Transceiver type: SFP or SFP+
Transceiver: 1000BASE-LX
Length: 3 Km [ Single Mode ]
550 m (OM1) / 550 m (OM2) / 0 m (OM3) [ Multi Mode ]
Speed: 1250 Mb/s
Wavelength: 1310 nm
Connector Type: SC
Vendor name: OEM
Vendor part number: AOPB-3524S-R03
Vendor revision: A0
Vendor serial number: S1235041040266
Product date: 141022
DDM Temperature: 36.5352 C (Warn :-128.0000 / -128.0000) DEFAULT
(Alarm:-128.0000 / -128.0000) DEFAULT
DDM Vcc: 3.3384 V (Warn : 0.0000 / 0.0000) DEFAULT
(Alarm: 0.0000 / 0.0000) DEFAULT
DDM TX bias: 12.8860 mA (Warn : 0.0000 / 0.0000) DEFAULT
DDM TX power: -10.0130 dBm (Warn : -40.0000 / -40.0000) DEFAULT
(Alarm: -40.0000 / -40.0000) DEFAULT
DDM RX power: -13.0364 dBm (Warn : -15.0000 / -8.0000) ADMIN
(Alarm: -19.0000 / -6.0000) ADMIN
DDM power state: TX ON RX ON
I'm attaching memory map for my modules - maybe you can add support for them. (should be quite easy)
SECOND of ...
Can you consider in next release, loading operator logo (in format like PNG) and showing it off during slideshow on LCD ? It's could be quite usefull for some configurations.
Best Regards
marcin21
Tue Nov 17, 2015 6:06 pm
Dear Mikrotik staff!
I use PPPoE for client authorization since 2003. As I succesfully migrated from our linux based pppoe concentrators to mikrotik few years later I started to rely on routeros.
I devoloped way to work on queues to achieve desired effect. because I couldn't go with radius parameters since mikrotik didn't support them I did a workaround.
few years of optimizing solution and now my work is being smashed to dev/null because You disable possiblity of editinig queues? option is disabled and forces me to do work opposite way I did for last few years. My scripts doesn't work anymore and had to downgrade from 6.33 to 6.30.4. Is there an option to use old way accesiible queues or do I have to stick to 6.30.4 forever?
Kindis
Tue Nov 17, 2015 11:09 pm
I get the same error and the reason I get it is because I have a drop rule for all traffic in input chain last in my firewall. If I disable this rule check for updates work.
barmaley
Wed Nov 18, 2015 8:22 pm
updated packages from separate download file, no luck.
CRS125-24G-1S
Current firmware: 3.24
Architecture name :Mipsbe
Version:6.33 (stable)
/system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-mipsbe 6.33
1 system 6.33
2 X wireless-cm2 6.33
3 X ipv6 6.33
4 X wireless-fp 6.33
5 hotspot 6.33
6 dhcp 6.33
7 mpls 6.33
8 routing 6.33
9 ppp 6.33
10 security 6.33
11 advanced-tools 6.33
Pea
Wed Nov 18, 2015 9:33 pm
The mipsbe v6.33 and ntp package works fine.
Did you try to upload separate ntp-6.33-mipsbe.npk and reboot?
If yes, what was the log report?
whitbread
Wed Nov 18, 2015 9:52 pm
Strange behaviour here - action timed out:
When changing interfaces the following appears after a long while:
Same issue in the console:
Supout.rif already provided to Support.
strods
Thu Nov 19, 2015 10:03 am
v6.33.1 is released, please use this version for current!
http://forum.mikrotik.com/viewtopic.php?f=1&t=102335
Users browsing this forum: normis and 55 guests
