stmx38
Long time Member
Long time Member
Dude v6 - SMS notifications through smspilot.ru - using fetch tool
Thu May 18, 2017 11:52 pm
Related solutions
Requirements
1. Mikrotik ROS with installed Dude server.
2. Account on smspilot.ru
Setup instruction
1. Create new Notification in Dude
Type: execute on server
Command:
# Variables
:local notificationtext "Service [Probe.Name] on [Device.Name] is now [Service.Status]"
:local url "http://smspilot.ru/api.php"
:local apikey "154YCR22XL9IS4UR8YRO7GFQ81PGN6Z3OD1BXY726N854S52I3046CZ0R8JXR2SH"
# First Name Last Name
:local to "+xxxxxxxxxxx"
/tool fetch output=none url="$url\?apikey=$apikey&to=$to&send=$notificationtext"
And test it via pressing Test button.
2. Now you can use it:
Related Wiki topics
Manual:Tools/Fetch
Hope this will help someone.
netx34
Re: Dude v6 - SMS notification through smspilot.ru - using fetch tool
Tue Sep 07, 2021 2:08 am
i got error of "url" invalid how can i test it,
rextended
Tue Sep 07, 2021 2:14 am
(the \ on \? must be set only if tested on terminal, on script the \ must be removed)
probably because after 6 years the service do not work anymore or has changed syntax...
netx34
Tue Sep 07, 2021 2:27 am
its working hehehhee, i forgot to install the Dude Client side
Users browsing this forum: No registered users and 3 guests
