andredossantos
Variables and the 4096 bytes limit
Mon May 22, 2017 4:21 pm
The manual for scripting, under Variables (https://wiki.mikrotik.com/wiki/Manual:S ... #Variables), says the following:
Note: Variable value size is limited to 4096bytes
Does that apply somehow to arrays?
> :global v [/interface print as-value]
> :global s [:tostr $v]
138
> :put [:len $s]
11767
The above three commands were run on RouterOS version 6.36.4.
They show variable $s with more bytes than the documentation says is the limit.
Did I misunderstand the manual?
I tried to add this to the Wiki Discussion page, but I don't have permission to edit.
User janisk, in the message at viewtopic.php?f=9&t=40830&p=202842#p203413, says that there was never any limit on variable size, but only on files:
always variables could hold more data than 4KB. Only limitation is how much you can write/read to file.
User rextended has this warning in the message at viewtopic.php?f=9&t=82972&p=415090&hilit=4096#p415090:
On RouterOS the maxmimum length of a String variable are 4096 Byte
any Array have maximum size of "the sum of lenght of all single elements on Array" + "number of Array elements" <= 4096 Byte!!!
Could someone please clarify?
I'm currently using a global variable that's larger than 4096 bytes, and I want to make sure that future versions of RouterOS are not going to break that.
PackElend
Re: Variables and the 4096 bytes limit
Wed Dec 27, 2023 10:57 pm
have you ever got your answer (by yourself) ?
Are you aware of viewtopic.php?t=197190 and viewtopic.php?p=1012747#p1012747 ?
rextended
Thu Dec 28, 2023 11:04 am
2017-05-22
do not necroposting
Users browsing this forum: No registered users and 12 guests
