I have some mikrotiks in differents countries and I have "mark routing" to some IP for going to that IP using that route.
The problem is... I have a mark routing with the "vpn internface" but when the vpn is down, the vpn name dissapear, and all the relations are loose, when the VPN reconnect, the "interface: are still missing.... and I need to do fix it manually.
Is some way to fix it? Any trick...
Thank you
PD: Here, some useful info
[admin@Sprinfield Mikrotik] /ppp active> print
Flags: R - radius
# NAME SERVICE CALLER-ID ADDRESS UPTIME ENCODING
0 casavzla l2tp 186.14.xxx.xxx 192.168.16.11 3d20h... cbc(aes) + hmac(sha256)
1 gutierolm... l2tp 190.77.xxx.xxx 192.168.16.26 1d11h... cbc(aes) + hmac(sha1)
2 mayjo l2tp 80.27.xxx.xxx 192.168.16.10 3h54m47s cbc(aes) + hmac(sha256
[admin@Sprinfield Mikrotik] /ip firewall mangle> export
# sep/26/2018 12:25:49 by RouterOS 6.42.3
# software id = xxxx-xxxx
# model = 2011UiAS-2HnD
# serial number = xxxxxxxxxxxx
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Marcado via VPN USA" new-routing-mark=VIA_VPN_USA passthrough=yes src-address-list=\
salida-via-vpn-usa
add action=mark-routing chain=prerouting comment="Marcado via VPN Troca" connection-state=new connection-type="" new-routing-mark=VIA_VPN_TROCA \
passthrough=yes src-address-list=salida-via-trocadero
add action=mark-routing chain=prerouting comment="Marcado via Sat" disabled=yes new-routing-mark=VIA_SAT passthrough=yes src-address-list=\
salida-via-sat
add action=mark-routing chain=prerouting comment="Marcado via Vzla" connection-state=new new-routing-mark=VIA_VPN_VZLA passthrough=yes \
src-address-list=salida-via-vpn_vzla
add action=mark-routing chain=prerouting comment="Marcado via Vzla para banesco" connection-state="" dst-address-list=banesco new-routing-mark=\
VIA_VPN_VZLA passthrough=no src-address=192.168.10.0/24
add action=mark-routing chain=prerouting comment="Salida via Troca" new-routing-mark=VIA_VPN_TROCA passthrough=yes src-address-list=\
[admin@Sprinfield Mikrotik] /ip firewall nat> export
# sep/26/2018 12:27:44 by RouterOS 6.42.3
add action=masquerade chain=srcnat comment="Default Gateway FTTH" out-interface=ether1-gateway
add action=masquerade chain=srcnat comment="FTTH con marca" out-interface=ether10-gateway routing-mark=VIA_SAT
add action=masquerade chain=srcnat comment="Via VPN_USA" dst-address=0.0.0.0/0 out-interface=ppptp-usa src-address-list=salida-via-vpn-usa
add action=masquerade chain=srcnat comment="Via VPN_VZLA" dst-address=0.0.0.0/0 out-interface=<l2tp-casavzla> routing-mark=VIA_VPN_VZLA \
add action=masquerade chain=srcnat comment="Via VPN_VZLA Banesco" dst-address-list=banesco out-interface=<l2tp-casavzla> routing-mark=VIA_VPN_VZLA \
add action=masquerade chain=srcnat comment="Via VPN_Troca" dst-address=0.0.0.0/0 out-interface="Trocadero-vpn Oficina" routing-mark=VIA_VPN_TROCA \
[admin@Sprinfield Mikrotik] /ip route> export
# sep/26/2018 12:30:39 by RouterOS 6.42.3
# serial number = xxxxxxxxxxxxxxx
add comment="Salida via USA" distance=1 gateway=ppptp-usa routing-mark=VIA_VPN_USA
add comment="Salida via Troca" distance=1 gateway="Trocadero-vpn Oficina" routing-mark=VIA_VPN_TROCA
add comment="Salida via WLAN 3G/4G" distance=1 gateway=192.168.42.129 routing-mark=VIA_DOOGEE
add comment="Salida via Sat con Mark Routing" distance=2 gateway=ether10-slave-local routing-mark=VIA_SAT
add comment="Salida via Vzla" distance=1 gateway=<l2tp-casavzla> routing-mark=VIA_VPN_VZLA
add disabled=yes distance=1 gateway=ether1-gateway
add distance=1 dst-address=192.168.0.0/24 gateway="Trocadero-vpn Oficina"
add distance=1 dst-address=192.168.1.0/24 gateway="Trocadero-vpn Oficina"
add comment="Red de Vzla" distance=1 dst-address=192.168.14.0/24 gateway=<l2tp-casavzla>
add distance=1 dst-address=192.168.30.0/24 gateway="Trocadero-vpn Oficina"
add comment="GP Rooms red 30" disabled=yes distance=1 dst-address=192.168.30.0/24 gateway=*F03249
add distance=1 dst-address=192.168.31.0/24 gateway="Trocadero-vpn Oficina"
add distance=1 dst-address=192.168.75.0/24 gateway="Trocadero-vpn Oficina"
add distance=1 dst-address=192.168.76.0/24 gateway="Trocadero-vpn Oficina"
/ip route rule
add dst-address=142.4.201.85/32 interface=ether10-gateway routing-mark=VIA_SAT table=VIA_SAT
add dst-address=142.4.209.197/32 interface=ether10-gateway routing-mark=VIA_SAT table=VIA_SAT
The bold interfaces are missed when this VPN disconnect and I need to configure it again
Thank youuuuuuuu
