We have an ~2mile point to point with good line of sight. We have great signal strength (-50db) and connectivity. The link itself is strong and stable. One point of the connection is on a 150 foot tower that is also used by the local Sheriff departments repeater for their car radio units. The Sheriff is experiencing some interference from our link.
We are in the 5ghz range, they are between 155-159mhz, so I don't think we are walking on their band. At one point we were sharing a power source but that has been changed.
The only thing left I can think of is that the tower climber used unshielded cable for the run up the tower. That will be changed very soon once the cable arrives and I can reschedule the tower climber.
What else have I not thought of? The connection it self is using RB532 boards with SR5 radios in 19dbi Rootennas.
parts list:
1 RB532-4 RB532 Level 4 Lic WISP-AP
2 POE-48 48v Input POE Injector
3 SR5-80211a SuperRange5 802.11a 400 mW mini-PCI
4 SP-POE-MJ8 POE Surge Sup (60V POE, 7.5V Data Clamp)
5 RJ45-ECS RJ45 Field Replaceable Ethernet
6 R2T58W-19-XXX 5GHz 19dBi Roo2, White
7 5210004-006UFL Cable Jumper Ufl to SMA Male 8" RG174
