wispmikrotik
OSPF area NSSA LSA type 7 to type 5
Fri Mar 05, 2021 6:15 pm
Following RFC 1587 "4.1 Translating Type-7 LSAs Into Type-5 LSAs", and according to mikrotik's own documentation "https://help.mikrotik.com/docs/display/ ... +Solutions" Section LSA Types:
"type 7 - type 7 LSAs are used to tell the ABRs about these external routes imported in NSSA area. Area Border Router then translates these LSAs to type 5 external LSAs and floods as normal to the rest of the OSPF network"
In my lab this does NOT work, my scheme is very simple:
R1 is an ASBR connected to area 0 (default type) to R2.
R2 is an ABR connected in vlan 2 to area 0 (defualt type) and in vlan 3 to area 1 (NSSA)
R3 is a simple RI transit router in area 1 NSSA
R4 is another ASBR router, connected to area 1 NSSA, which knows the prefix 7.7.7.7/32 by static route.
The question is, R4 imports the route in area 1 NSSA as type 7 (7.7.7.7 static), the lsa travels through area 1 perfectly, but when it reaches R2, it is not able to convert the lsa type 7 to type 5 and import it to the backbone (area 0 R1). This with cisco and juniper works perfectly without making any invention (create 2 instances and redistribute-other-ospf).
Attached configurations.
R1
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
set [ find default-name=ether3 ] disable-running-check=no
set [ find default-name=ether4 ] disable-running-check=no
set [ find default-name=ether5 ] disable-running-check=no
/interface vlan
add interface=ether5 name=vlan2 vlan-id=2
/routing ospf instance
set [ find default=yes ] metric-bgp=200 metric-connected=0 metric-other-ospf=110 metric-rip=120 metric-static=5 name=ospf100 redistribute-connected=as-type-1 router-id=1.1.1.1
/system logging action
add disk-file-name=log_ASBR name=action1 target=disk
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add interface=ether3
add interface=ether4
add address=192.168.2.1/30 interface=vlan2 network=192.168.2.0
/ip dhcp-client
add disabled=no interface=ether1
set servers=1.1.1.1
/routing filter
add action=accept chain=ospf-out prefix=192.168.122.0/24 prefix-length=24-32
add action=discard chain=ospf-out prefix=0.0.0.0/0 prefix-length=0-32
/routing ospf interface
add dead-interval=4s hello-interval=2s interface=vlan2 network-type=point-to-point priority=105 retransmit-interval=1s use-bfd=yes
/routing ospf network
add area=backbone network=192.168.2.0/30
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=R1
/system logging
add action=action1 topics=ospf,!raw
/system package update
set channel=testing
/tool romon
set enabled=yes
R2
/interface vlan
add interface=ether1 name=vlan3 vlan-id=3
/routing ospf area
add area-id=0.0.0.1 default-cost=1 inject-summary-lsas=no name=area1 translator-role=translate-always type=nssa
set [ find default=yes ] metric-bgp=200 metric-connected=0 metric-other-ospf=110 metric-rip=120 metric-static=5 name=ospf100 redistribute-other-ospf=as-type-2 router-id=2.2.2.2
/user group
/interface bridge vlan
add tagged=ether3,ether4,ether5,*6 vlan-ids=2
add address=192.168.2.2/30 interface=vlan2 network=192.168.2.0
add address=192.168.3.1/30 interface=vlan3 network=192.168.3.0
/ip dhcp-client
set servers=1.1.1.1
add dead-interval=4s hello-interval=2s interface=vlan3 network-type=point-to-point priority=105 retransmit-interval=1s use-bfd=yes
add area=area1 network=192.168.3.0/30
/system clock
/system identity
set name=R2
/system logging
set channel=testing
/tool romon
set enabled=yes
R3
/interface vlan
add interface=ether5 name=vlan4 vlan-id=4
/routing ospf area
add area-id=0.0.0.1 default-cost=1 inject-summary-lsas=no name=area1 translator-role=translate-never type=nssa
set [ find default=yes ] metric-bgp=200 metric-connected=0 metric-other-ospf=110 metric-rip=120 metric-static=5 name=ospf100 router-id=3.3.3.3
/user group
add address=192.168.3.2/30 interface=vlan3 network=192.168.3.0
add address=192.168.4.1/30 interface=vlan4 network=192.168.4.0
/ip dhcp-client
set servers=1.1.1.1
add dead-interval=4s hello-interval=2s interface=vlan4 network-type=point-to-point priority=105 retransmit-interval=1s use-bfd=yes
add area=area1 network=192.168.4.0/30
/system clock
/system identity
set name=R3
/system logging
set channel=testing
/tool romon
set enabled=yes
R4
add name=bdi100
/interface vlan
add interface=bdi100 name=vlan5 vlan-id=5
/routing ospf area
set [ find default=yes ] metric-bgp=200 metric-connected=0 metric-other-ospf=110 metric-rip=120 metric-static=5 name=ospf100 redistribute-static=as-type-2 router-id=\
    4.4.4.4
/user group
add bridge=bdi100 interface=ether1
add address=192.168.4.2/30 interface=vlan4 network=192.168.4.0
add address=192.168.5.1/30 interface=vlan5 network=192.168.5.0
set servers=1.1.1.1
add distance=1 dst-address=7.7.7.7/32 gateway=192.168.5.2
/system clock
/system identity
set name=R4
/system logging
set channel=testing
/tool romon
set enabled=yes
Routes R1
[admin@R1] > /ip ro pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          192.168.122.1             1
 1 ADC  192.168.2.0/30     192.168.2.1     vlan2                     0
 2 ADo  192.168.3.0/30                     192.168.2.2             110
 3 ADo  192.168.4.0/30                     192.168.2.2             110
 4 ADC  192.168.122.0/24   192.168.122.125 ether1                    0
[admin@R1] > /routing ospf lsa pr
AREA        TYPE         ID             ORIGINATOR     SEQUENCE-NUMBER        AGE
area2        router       1.1.1.1        1.1.1.1             0x80000005       1404
area2        router       2.2.2.2        2.2.2.2             0x80000006       1410
area2        summary-n... 192.168.3.0    2.2.2.2             0x80000001       1517
area2        summary-n... 192.168.4.0    2.2.2.2             0x80000001       1517
area2        summary-asbr 4.4.4.4        2.2.2.2             0x80000001       1516
external        as-external  192.168.122.0  1.1.1.1             0x80000001       1407
LSA R2
[admin@R2] > /routing ospf lsa pr
backbone        router       1.1.1.1        1.1.1.1             0x80000006         79
backbone        router       2.2.2.2        2.2.2.2             0x80000006         73
backbone        summary-n... 192.168.3.0    2.2.2.2             0x80000003         77
backbone        summary-n... 192.168.4.0    2.2.2.2             0x80000001         62
backbone        summary-asbr 4.4.4.4        2.2.2.2             0x80000001         49
area1        router       2.2.2.2        2.2.2.2             0x80000002         68
area1        router       3.3.3.3        3.3.3.3             0x80000003         56
area1        router       4.4.4.4        4.4.4.4             0x80000002         52
area1        summary-n... 0.0.0.0        2.2.2.2             0x80000001         78
area1        type-7       7.7.7.7        4.4.4.4             0x80000002         50
external        as-external  192.168.122.0  1.1.1.1             0x80000002        431
Regards,
sarah
Re: OSPF area NSSA LSA type 7 to type 5
Sat Mar 06, 2021 6:22 am
I just reproduced this too in my lab.
If you change the NSSA area to default, the lsa seems to be flooded correctly. At this point if you change the area back to NSSA things work correctly. HOWEVER if you now change the RIP network to other prefix, the old prefix will continue to be flooded.
Maybe time to email support@mikrotik.com?
nichky
Sat Mar 06, 2021 7:15 am
you can do email to support. They will give you maybe better answer.
From what i can see, i not sure what you want to achieve, but i think your topology is wrong. NSSA you can't use in this case.
Please see the folowing atachent to get an idea in which caisess you can play with NSSA
wispmikrotik
Sat Mar 06, 2021 9:11 am
Thanks for the answers, yes, I have a ticket open to mikrotik for 7 days without an answer.
Regarding the topology, I was testing ospf in mikrotik, as for the network is not correct, why? This same network you change R2 for a cisco, vyos, junos and it works perfectly, it is broken in translate-role routerOS.
Regards,
wispmikrotik
Sat Mar 06, 2021 10:12 am
Confirmed is a BUG
v6.46 - OK
v6.48.1 and v6.49beta11 not working
Regards
wispmikrotik
Sat Mar 06, 2021 10:42 am
Total disaster:
All current versions affected :(
long term: v6.47.9
stable: v6.48.1
testing: v6.49beta11
development: v7.1beta4
Regards.
nichky
Sat Mar 06, 2021 11:10 am
im not sure,
try on R3
/routing ospf area
MrZoidberg
Fri Sep 08, 2023 9:42 am
Hi, I had the same problem. After some tinkering with Cisco and ROS 6.46 I was able to discover the following:
1) In Cisco and RouterOS 6.46, everything works, the route to the network announced in NSSA appears on R1. LSA Type 1 are as follows:
RouterOS 6.46
Cisco
As you can see, there are E and B bits that tell us that this router (R2) is an ABR and an ASBR
2) The route is not displayed in RouterOS 7.11.2, but the LSA type 5 is available in the database
We also see that in LSA type 1, the R2 only sets the B bit, which tells us that this is just an ABR
However, if we configure R2 to perform radio distribution, for example RIP, it will additionally mark itself as an ASBR, and R1 will place the route from NSSA in the routing table
antosusan
Fri Oct 27, 2023 6:59 am
im not sure,
try on R3
/routing ospf area
yes i try this is work properly for nssa
Users browsing this forum: No registered users and 1 guest
