Fomos
Dude, huawei s6720, MA5683T, no message to telegram
Fri Mar 19, 2021 12:28 pm
Hello.
I have such a problem, messages in telegrams are not sent only to the huawei olt or huawei switch. The log and pop-up messages come, but no messages about the "ports down" are received in the telegrams. in the services tab, probes down status, but messages do not come to telegrams.
There are no problems with vendors zte C320, Dlink and others
Does anyone have any ideas?
thanks.
nabilx
Re: Dude, huawei s6720, MA5683T, no message to telegram
Sun Mar 28, 2021 12:41 am
I think it's a problem in the notification element can you post it?
Fomos
Wed Apr 21, 2021 3:05 pm
/tool fetch url="https://api.telegram.org/bot**********: ... &text=Dude server: Service [Probe.Name] on [Device.Name] ([Device.FirstAddress]) is now [Service.Status] ([Service.ProblemDescription])" keep-resul=no
rextended
Re: Dude, huawei s6720, MA5683T, no message to telegram  [SOLVED]
Wed Apr 21, 2021 3:30 pm
some sites require to replace spaces with "+" sign and escape the other characters as url format.
if you try this on terminal is working?
add for debug the url string on the log:
/log warning "https.......";/tool fetch......
Users browsing this forum: No registered users and 1 guest
