MrHae
CHR Azure
Wed May 26, 2021 8:25 pm
Hey,
i went with my CHR Instance from AWS to Azure and now i am not able to get my Cloud DDNS working. The Field "Public IP" still keeps empty and i don't know why. Does anyone have had the same issue?
MrHae
Re: CHR Azure
Mon Sep 27, 2021 4:00 pm
*push*
Nobody got the same Problem? Still tried everything but no Public IP show up for my /ip/cloud DDNS Service
SiB
Re: CHR Azure
Mon Sep 27, 2021 4:07 pm
in CHR the IP > Cloud not work at free license.
https://wiki.mikrotik.com/wiki/Manual:IP/Cloud
Note: IP/Cloud requires a working license on Cloud Hosted Router (CHR).
FurfangosFrigyes
Re: CHR Azure
Mon Sep 27, 2021 4:25 pm
Hey,
Azure provides public fix IP with FQDN so not necessary to use DDNS for it. If there is a NSG than you need to manage the ports on the Network Security Group to open the necessary ports!
MrHae
Re: CHR Azure
Mon Sep 27, 2021 4:42 pm
I have a license and i dont have a NSG and i want to use the DDNS feature cause i cant find any pricing for fixed IP
SiB
Re: CHR Azure
Mon Sep 27, 2021 4:59 pm
If you have a license and IP Cloud feature not work then write directly to http://help.mikrotik.com .
In general
/ip cloud set ddns-enabled=yes
/ip cloud force-update
/ip cloud print
And this should be all. Sometimes a force-update do activation job but if this not work, send msg to MikroTik Support..
MrHae
Re: CHR Azure
Mon Sep 27, 2021 5:20 pm
Yep, nothing worked, but only in Azure if i go to AWS theres no Problem.
SiB
Re: CHR Azure
Mon Sep 27, 2021 5:48 pm
Maybe in Azure you must create a rule in AzureCloudFirewall for outgoing/outbound traffic ?
In documentation you have addresses and udp ports.
nbctcp
Re: CHR Azure
Wed Jan 25, 2023 10:05 am
what is ur chr aws setting?
I can't make ddns chr working in chr with P1 trial license
Are you using valid license?
Nothing displayed on public ip
AWS security group
1. allow inblound 15252 from 159.0.0.0/8 udp
2. allow inbound ssh from my home ip
3. allow winbox from my home ip
4. allow outbound all
# /tool sniffer quick ip-address=159.0.0.0/8 interface=ether1
Here my export
> export
# jan/24/2023 17:45:25 by RouterOS 7.7
set [ find default-name=ether1 ] disable-running-check=no
/interface lte apn
/port
set 0 name=serial0
set discover-interface-list=none
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/ip cloud
set ddns-enabled=yes update-time=yes
/ip dhcp-client
add !dhcp-options interface=ether1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh port=8022
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-autodetect=no time-zone-name=US/Pacific
/system clock manual
set time-zone=-08:00
/system identity
set name=ip-.ec2.internal
/system ntp client
set enabled=yes
/system ntp client servers
add address=107.155.79.3
/tool bandwidth-server
set enabled=no
/tool mac-server mac-winbox
/tool mac-server ping
Users browsing this forum: No registered users and 5 guests
