mikeghosty
Function Request
Mon Jul 19, 2021 6:36 pm
I'm looking to create a function to reture a value from an HTTP Get comand. or HTTP Head comand.
Currently
Will return an integer however in order to get it into the device appearance i need it in a function. How do i go about this?
m
rextended
Re: Function Request
Mon Jul 19, 2021 8:18 pm
Search the forum, already explained with examples how to save the "get" from fetch to file and after that read the file content as value.
mikeghosty
Mon Jul 19, 2021 9:38 pm
Thanks Rextended,
I've been searching and searching for examples but i haven't found anything helpful. Maybe i'm searching for the wrong thing. I'll have another go using what you've put but if you have any pointers that would be great.
m
rextended
Mon Jul 19, 2021 11:50 pm
https://wiki.mikrotik.com/wiki/Manual:T ... a_variable
I literally wrote you what needs to be done, and let you think, rather than just copy & paste...
:put  ([/tool fetch url="http://x.x.x.x/devices/statistics/online-count" as-value output=user]->"data")
Users browsing this forum: No registered users and 2 guests
