qatar2022
chateau 5G boot loop- netinstall not working
Mon Sep 06, 2021 5:57 am
Hello.
Today I received my mikrotik chateau 5G, and when i try to update it after reboot it will not boot.
So I made a reset After reboot i goot a boot loop So I tried with netinstall, and I have a problem - but I cannot install the firmware - it shows purple led
I tried to install different versions of firmware, but with no luck.
Can you help me?
SiB
Re: chateau 5G boot loop- netinstall not working
Mon Sep 06, 2021 6:10 am
I fix few boot-loop units... with NetInstall and Wireshark, check my HowTo viewtopic.php?f=2&t=167360&p=821518#p821518
Remember that some version of NetInstall.exe not work properly and try use other, e.g. viewtopic.php?f=2&t=176162
theprojectgroup
Thu Aug 31, 2023 10:57 pm
I have the same issue and the linked tips won't work for me.
Did you ever fix this unit?
In my case I can see with wireshark:
- bootp request from chateau 5g and reply from my machine (client ip is assigned)
- tftp transfer for file vmlinux:
- tftp transfer completes after block 2390 and machine seems to send bootp reply again:
During that time the power / system led is blue.
~10 seconds after the transfer (last) completes, all leds turn constant green for about a second except system/power led is purple
- a few seconds later the process starts again
Wireshark capture: https://nextcloud.project-ivo.com/index ... yirXanZKaa
I'm stuck in this loop.
theprojectgroup
Fri Sep 01, 2023 10:00 am
I tried various machines (even an old windows xp), switches in between, etc.
Can anyone test with a "working" chateau 5g if it boots netinstall at all?
DeGlucker
Wed Sep 06, 2023 2:48 pm
The same problem. A few days ago I tried to update ROS to latest version on client's Chateau 5G, router rebooted and no more booted. :(
How to properly do netinstall for this router ?
I tried to connect laptop with netinstall to Ethernet 1 port, pressed and held reset button and then powered on the router, but with no luck. Netinstall doesn't see the router.
theprojectgroup
Wed Sep 06, 2023 3:12 pm
A few others have exactly the same issues: https://www.reddit.com/r/mikrotik/comme ... boot_loop/
Mate I have exactly the same problem after attempted upgrade 7.11.2
sparkus
Wed Sep 06, 2023 11:20 pm
Try Netinstall 7.12beta3 Testing.
Check both regular and backup booters https://help.mikrotik.com/docs/display/ ... kuploaders
themenace
Thu Sep 07, 2023 1:46 am
do you know this is an issue with netinstall - no mention of anything in the changelogs ?
Have you tried this ??
themenace
Thu Sep 07, 2023 4:06 am
UPDATE:[SOLVED]
using Ubuntu Linux fresh install with netinstall-cli (7.12.beta3) and routeros 7.12.beta3 works.
Thanks for the suggestion
DeGlucker
Thu Sep 07, 2023 11:34 am
Confirm, I could repair my Chateau 5G using windows netinstall 7.12beta3 !
chanchan
Sat Sep 16, 2023 8:49 pm
Hi.
I have a same problem, i tried run wireshark but the only display is boot request from ( mac address of chateau 5g ) any one help me?
themenace
Sun Sep 17, 2023 9:05 am
@chanchan
Use Netinstall 7.12.x and reinstall.
Then I found another issue that causes the unit not to boot sometimes, I set the CPU frequency from auto to lowest and never a problem.
chanchan
Mon Sep 18, 2023 4:48 am
@themenace
Thank you. Its now working on the netinstall. 😊😊
Users browsing this forum: No registered users and 6 guests
