awonglk
RSTP with VLAN .. How does it work?
Wed Sep 08, 2021 6:06 am
I have a CSS610 switch that I believe only supports RSTP (being a limitation with SwOS).
It has multiple VLANs setup and I have the same VLANs setup on all of my other switches as well:
I am wondering:
  • Is RSTP aware of VLANs? My understanding that I should be using MSTP with VLANS?
  • I believe I can only have a single root bridge with RSTP. Is it possible to have "per VLAN" RSTP where VLAN10 goes via EdgeSwitch.. and VLAN30 goes via CRS309 (as root bridge)?
tdw
Re: RSTP with VLAN .. How does it work?
Wed Sep 08, 2021 6:23 pm
RSTP knows nothing of VLANs. If you have the same untagged and tagged VLANs on all the non-edge links using RSTP is fine, it will block all traffic on one of the links to prevent a loop.
If you wish to have the block in different places around the loop for differing groups of VLANs you need MSTP.
Users browsing this forum: No registered users and 5 guests
