fedorovic
no supported channel - after upgrade
Fri Jan 21, 2022 8:35 am
After upgrade from 6.48.6 to 7.1.1 on x86 server and rb18 (8 minipci cards) with level 5 license and extra-channels I can't set any frequency. Downgrade to v6 doesn't help. There is just "auto" frequency and I get "no supported channel" error.
Shahid
Re: no supported channel - after upgrade
Sun Jun 05, 2022 2:23 am
Same Problem with me, After update from 6.48.6 wifi is not working on x86 level 4 licence with extra channels
Using Atheros AR9300
Errors
--No Supported Channel
--Scan list does not contain valid channels
--Empty scanlist
On 6.48.6 everything is working fine
holvoetn
Sun Jun 05, 2022 10:58 pm
Have seen that a couple of times.
In my case it was each time a mismatch between country setting and channel to be used
Ros7 is a lot more strict on that.
Can you check country setting and if the allowed channels for that setting are compatible with what you want to use ?
cklee234
Mon Jun 06, 2022 4:46 am
Could you elaborate more? Which country you base? Can you make it work?
I encounter the same issue
holvoetn
Mon Jun 06, 2022 8:57 am
Assuming you are not using wifiwave2
From terminal
/interface wireless info country-info=<chosen country>
For wifiwave2
/interface/wifiwave2/info country-info=<chosen country>
It will show which channels etc are allowed for the selected country. Omit country-info parameter to get all countries.
For a lot if countries it is illegal to set wrong channels/width/... for wifi, hence the reason ROS7 is a lot more strict on which channel can be used for which country.
Selecting the right country is the user's responsibility!!
cklee234
Tue Jun 07, 2022 4:18 pm
From terminal
For wifiwave2
Empty output from my x86 device. must be missing something
Ca6ko
Long time Member
Long time Member
Fri Jun 10, 2022 2:16 pm
I recently encountered this problem when I set my list of channels 1, 6, 11. It turned out that there were continuing problems with the scan list name. If the name of the sheet begins with a number, we get an error message, if with a letter, everything works.
Also, if there is a dot in the list name, then the list name is imported incorrectly when exporting-importing the configuration.
PS hAP ac2 and ROS7.2.3
cklee234
Sun Jun 19, 2022 3:56 am
I am using an x86 and install an MikroTik R11e-5HacT
Always no supported channel
mkx
Sun Jun 19, 2022 12:51 pm
Set installation to "any" ... the way MT understands the "indoor" is very restrictive ... device will select only channets which are allowed exclusively for indoor use ... and there might be none. Usually all channels are allowed for indoor and outdoor, but allowed Tx power might be lower when used outdoor.
You may also want to change band to "5GHz-n/ac" (omit a) and (for starters) channel width to 20MHz only.
Ca6ko
Long time Member
Long time Member
Sun Jun 19, 2022 2:00 pm
@cklee234
Tap the Advanced mode button. The Scan List window appears. Check which list is selected there.
You can create your own Scan List and select it.
cklee234
Mon Jun 20, 2022 3:26 am
@cklee234
I have manually added the scanlist and it appears in the scan list.
Unfortunately, it does not work upon trying one by one.
Besides, it should be a dual band card, it does not show up 2.4G.
The same for my older atheros.
Nevertheless, when I have time, I may try again in ROS version 6. and also in 32 bits. Currently it is version 7.4.beta in 64 bits mode.
mkx
Mon Jun 20, 2022 8:05 am
Where did you get that idea? Official product page only mentions 5GHz radio. All product pages of products supporting both bands clearly mention that in specifications, even for Groove 52 which is dual-band capable single radio device (and one has to try a bit harder to find this crucial bit of information on product page). Just because radio chip has ability of running either band, it doesn't mean that particular card implementation offers it.
cklee234
Mon Jun 20, 2022 8:26 am
I see, my mistake
Reason: removed excessive quotting of preceding post; be wise, quote smart.
cklee234
Sat Jul 02, 2022 3:05 pm
May I know if V7 has x86 wifi driver included?
Shahid
Fri Sep 23, 2022 3:11 am
Yup
i am using latest stable version 7.5 with Atheros AR9300 on x86 working excellent.
All the bugs are removed.
cklee234
Thu Oct 13, 2022 5:07 am
Can you share with me where you got the AR9300?
I have been using the mikrotik branded R11e-5HacT which is still not working
SMARTNETTT
Sat Oct 15, 2022 11:32 pm
some solution mikrotik ???
x86 v7+ no suport channels in 2,4ghz !!!
cklee234
Sun Oct 16, 2022 3:00 am
The support said it would be fixed. But so far, only "no support channels issue" has been fixed. still not yet able to connect to wifi device and works
Likely the driver is not fully activated
SMARTNETTT
Sun Nov 06, 2022 9:34 pm
MIKROTIK, Some Solution of this ? Please answer !!!!
SMARTNETTT
Mon Nov 07, 2022 12:18 am
MOKROTIK Some Answer ???
cklee234
Mon Nov 07, 2022 1:19 am
So far not working
I set is AP mode, wifi scan found the SSID but unable to connect. Frequency scan all - 130db
killersoft
Mon Nov 07, 2022 4:48 am
Have you tried the official mikrotik support channel.
https://mikrotik.com/support
or via email : support@mikrotik.com
SMARTNETTT
Mon Nov 07, 2022 4:54 am
NOT ANSWERED
cklee234
Tue Nov 08, 2022 1:12 am
Yes, they replied me with a support ticket and to wait for their fixes
SMARTNETTT
Sat Nov 19, 2022 3:31 am
Finaly solved thanks for nothing Mikrotik
mkx
Sat Nov 19, 2022 11:08 am
What was the solution then?
cklee234
Sun Nov 20, 2022 3:45 am
Really, what was the fix?
SMARTNETTT
Sun Nov 20, 2022 6:39 am
mikrotik, your clients call
mkx
Sun Nov 20, 2022 10:06 am
@SMARTNETTT, my question was directed towards you ... you posted that issue was solved without giving any details about solution. Such posts are IMO outright rude, specially towards people having seemingly similar issues and googling for solutions. Your post doesn't help them. At all.
Shahid
Thu Dec 01, 2022 1:11 pm
Model: AW-NB097H
I bought it from Aliexpress
using it in HP T610 Plus Thin Client which comes with mini pcie slot, along with PCIE slot for extending LAN interfaces
https://www.aliexpress.com/item/1005003351247270.html
SMARTNETTT
Thu Jan 19, 2023 5:43 am
the problem is : mikrotik no contesta y nosotros somos sus ingenieros gratis??? eso no esta bien
holvoetn
Thu Jan 19, 2023 6:02 am
Didn't even need Google translate for that ...
It is still rude to keep the solution for yourself towards the rest of the users.
Users browsing this forum: No registered users and 2 guests
