Fraggi
Extra info for hEXPoE RB960PGS
Tue Apr 12, 2022 4:23 pm
I have the following Mikrotik router/switches:
CRS305-1G-4S+ and hEXPoE RB960PGS
Is there possible to add some extra info on SFPs in the hEXPoE RB960PGS,
like the CRS305-1G-4S+ shows correct info for the Ubiquiti UF-MM-1G,
as shown in the picture of CRS305-1G-4S+.
Is it possible?
The SFP works flawlessly in the hEXPPoE btw.
Fraggi
Re: Extra info for hEXPoE RB960PGS
Fri Apr 15, 2022 11:47 pm
No-One?
k6ccc
Sun Apr 17, 2022 7:55 pm
You asked this question in the SwitchOS section of the forum. Your question does not involve SwitchOS in any way. Suggest you try asking in the Beginner Basics section of the forum. You are far more likely to gt an answer.
Users browsing this forum: Bing [Bot] and 3 guests
