Dante91
BGP-Routing-Filter "set bgp-med" on ROSv7.2.1
Fri Apr 29, 2022 1:59 pm
Hey @ all,
I just made an upgrade to ROS7.2.1 with my bgp-configuration. So far everything looks good, all settings are correctly migrated.
Only thing thats a bit tricky:
When Router1 wants to announce a route to his neighbor, there is a routing filter set, which changes the bgp-med.
Konfig on ROSv6.49:
/routing filter
add action=accept chain=secondary-out set-bgp-med=110
Konfig on upgraded ROSv7.2.1:
/routing filter rule
add chain=secondary-out disabled=no rule="set bgp-med 110; accept "
On Router2, when I check the received routes from Router1, there is noc MED set in status-field.
What could here be the issue?
Thanks and best regards.
mrz
Re: BGP-Routing-Filter "set bgp-med" on ROSv7.2.1
Fri Apr 29, 2022 2:02 pm
change to bgp-out-med
Dante91
Fri Apr 29, 2022 2:24 pm
Hey, thanks for the quick response.
I tried to set bgp-out-med. No change on the remote side. Also tried to change the distance on the routes. Still no change on remote side.
Another thing is that my default template is red and marked as "invalid".
/routing bgp template
set default as=12345 disabled=no nexthop-choice=force-self output.filter-chain=secondary-out .network=\
bgp-networks .redistribute=static router-id=172.200.36.12 routing-table=main
The routes are announced completely and with the right gateway. Just the output-routing filter does not work
Regards
Update: When I set the med-change on the target router as an input-filter, it works.
TFyre
Thu Jun 30, 2022 11:54 pm
set bgp-out-med
works for ebgp but not ibgp
According to https://help.mikrotik.com/docs/display/ ... nd+Filters we should use
set bgp-med
for ibgp, but it does not work either
Tested on ROSv7.3.1
Workaround is to use something like bgp communities
nichky
Fri Jul 01, 2022 6:49 am
@mrz
can u give us an example of bgp community on v7,, no wiki pls
maxfava
Sun Nov 26, 2023 8:40 pm
I have large BGP deployment and all based on ROS 6 and bgp-med in output is the discriminator.
I have tried ROS last version 7.12.1 I confirm it continue to not work.
to me is abnormal that it does not work.
any tought?
Users browsing this forum: No registered users and 8 guests
