robertpenz
How to show OSPF route costs in RouterOS 7?
Mon May 02, 2022 10:05 pm
I've set up my first OSPF on a RouterOS 7 - done a few on previous versions. It works so far for me, but I'm missing a place to see the costs of the route candidates. In RouterOS 6 it was via /routing ospf route print - but that's gone in RouterOS 7 - what's the new way to check that? The new documentation on help.mikrotik.com talks about route selection and so, but not how to see the candidates with their costs.
thx for your help!
Robert
mrz
Re: How to show OSPF route costs in RouterOS 7?
Mon May 02, 2022 11:30 pm
You can see all routes in /routing route menu with all the OSPF attributes.
robertpenz
Tue May 03, 2022 8:33 am
Thx for the reply.
Where do I see the costs? The Cost should be 50 and 60. And where do I see the route candidates I get via OSPF? I should see 192.168.76.0/27 2 times.
[Mikrotik] > /routing/route/print
Flags: A - ACTIVE; c, s, o, y - COPY; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
    DST-ADDRESS                          GATEWAY                                 AFI   DISTANCE  SCOPE  TARGET-SCOPE  IMMEDIATE-GW
 o  0.0.0.0/0                            192.168.76.227%vlanTransit*********     ip4        110     20            10  192.168.76.227%vlanTransit*********
As  0.0.0.0/0                            10.10.188.200                           ip4          1     30            10  10.10.188.200%vlanTransit**************
Ac  **************/24                    vlanTransit**************               ip4          0     10                vlanTransit**************
Ac  10.10.188.8/32                       vrrpTransit*************                ip4          0     10                vrrpTransit*************
Ao  192.168.76.0/27                      192.168.76.234%wireTransitRz1*********  ip4        110     20            10  wireTransitRz1*********
Ao  192.168.76.192/27                    192.168.76.234%wireTransitRz1*********  ip4        110     20            10  wireTransitRz1*********
Ac  192.168.76.224/29                    vlanTransit*********                    ip4          0     10                vlanTransit*********
Ac  192.168.76.224/32                    vrrpTransit*********                    ip4          0     10                vrrpTransit*********
Ac  192.168.76.232/30                    wireTransitRz1*********                 ip4          0     10                wireTransitRz1*********
Ao  192.168.76.236/30                    192.168.76.227%vlanTransit*********     ip4        110     20            10  192.168.76.227%vlanTransit*********
Ac  fe80::%ether1rz1-wan-2_7/64          ether1rz1-wan-2_7                       ip6          0     10                ether1rz1-wan-2_7
Ac  fe80::%vrrpTransit*********/64       vrrpTransit*********                    ip6          0     10                vrrpTransit*********
Ac  fe80::%vrrpTransit*************/64   vrrpTransit*************                ip6          0     10                vrrpTransit*************
Ac  fe80::%vlanTransit**************/64  vlanTransit**************               ip6          0     10                vlanTransit**************
Ac  fe80::%vlanTransit*********/64       vlanTransit*********                    ip6          0     10                vlanTransit*********
Ac  fe80::%wireTransitRz1*********/64    wireTransitRz1*********                 ip6          0     10                wireTransitRz1*********
A H ether1rz1-wan-2_7                                                            link         0
A H vrrpTransit*********                                                         link         0
A H vrrpTransit*************                                                     link         0
A H vlanTransit**************                                                    link         0
A H vlanTransit*********                                                         link         0
A H wireTransitRz1*********                                                      link         0
Did try it on 7.2.1 and 7.2.2
netzwerghh
Tue May 24, 2022 5:16 pm
You can see the cost with the following command. But at the moment you can not see the OSPF candidates. Hope this will come back soon. As this was possible to see under the OSPF menu in Router OS 6.
/rouing/route/print detail where ospf
jadawin
Fri Jul 08, 2022 9:22 pm
In RouterOS 7.3 you can use the column "OSPF Metric" in the route list (in RouterOS 7.1 the OSPF Metric was always shown as 0),
apleschu
Sun Nov 20, 2022 3:57 pm
Is it possible in the meantime to see accurate route costs for the whole path?
The "OSPF Metrics" only show the cost to the next hop and not the cost for the next router(s)
Users browsing this forum: No registered users and 3 guests
