minelli
Multiple pppoe connections from the same user. - Solved
Wed May 11, 2022 5:58 pm
Good morning, can someone from support tell me how to proceed to try to solve it. I have a CCR1009-8G-1S-1S+ and since we updated to v7 that means from v7.1.5 to the current v7.2.3 I have had this problem. The only thing I didn't do was a netinstall.
It happens that several pppoe connections are open as in the image and the navigation is horrible not to mention that it is not possible to disconnect the connection, having to restart the router.
Ps.: Only with this CCR this happens, the others are working normally.
rextended
Re: Multiple pppoe connections from the same user.
Wed May 11, 2022 7:30 pm
Nice guess game, too hard for me, just only from one pic.
anav
Wed May 11, 2022 8:21 pm
Please use the following as a better way to communicate! - viewtopic.php?p=908118
minelli
Tue Jun 07, 2022 5:37 pm
Good morning guys, I found out that this is a bug in Winbox.
Because when closing it and reopening it, it is no longer displayed duplicity, I believe that in the next versions of Winbox this will no longer occur.
Users browsing this forum: No registered users and 3 guests
