Ufdah
Dude Agent On hEX Lite RB750r2?
Fri May 13, 2022 11:31 pm
Can the hEX Lite RB750r2 be configured to act as a Dude Agent? I'm about to deploy 200 RB750r2's and each will be behind another router/firewall so I'm interested in having them act as Dude Agents. Is this possible? If not, is there any way to make them visible to The Dude through firewall rules?
stmx38
Long time Member
Long time Member
Re: Dude Agent On hEX Lite RB750r2?
Sat May 14, 2022 8:51 am
Accordingly to the documentation - The Dude v6/Agents
Starting from RouterOS 6.38.x any RouterOS device can be a Dude agent without any installation or configuration required
And Agents should be directly accessible and in case of front router it will require a Winbox port forwarding.
You can forward Winbox port on front placed router/firewall to your RB750r2 and then add it to Dude Server for monitoring and also use as an Agent.
               Winbox port
Dude Server  -->  Router  -->  RB750r2
But probably it is a good idea to do some tests before implementation, because on the forum we already discussed related issues Dude server v.6 - not working with port forwarding and Dude - Device RouterOS on no-standard Port.
Users browsing this forum: No registered users and 0 guests
