mafiosa
PPPoE disconnected doesn't dial up auomatically
Mon May 16, 2022 6:09 pm
I am using RB5009 with PPPoE. If by any chance the link to an intermediate switch fails and comes back the pppoe doesn't dial up automatically. The state of the PPPoE interface is disconnected.
Znevna
Re: PPPoE disconnected doesn't dial up auomatically
Mon May 16, 2022 8:15 pm
I don't believe you.
Proof?
Zacharias
Mon May 16, 2022 8:42 pm
The pppoe tunnel, should and will go up as long as the pppoe server responds to the discovery messages of the pppoe client and all the stages get completed successfully.
https://wiki.mikrotik.com/wiki/Manual:I ... _Operation
mafiosa
Mon May 16, 2022 9:04 pm
Proof?
You want me to disrupt the connection to show you proof?
mafiosa
Mon May 16, 2022 9:05 pm
Yes but that should put the pppoe interface into connecting state but it isn't.
Znevna
Mon May 16, 2022 9:08 pm
I'm guessing you have some logs that support your statement, sorry, I don't want you to disrupt your network intentionally.
mafiosa
Mon May 16, 2022 11:03 pm
Here are the attachments.
msatter
Mon May 16, 2022 11:13 pm
I have an Internet connection over PPPoE and when I get disconnected I can connect again but have to wait till the server offers a reconnect. This is a window that passes my connection and can take up to 7 minutes.
You can press in winbox the blue-V twice, to force a reconnect but that does not work brcause I have wait for the window to pass by.
Znevna
Mon May 16, 2022 11:37 pm
Pictures are nice, but they don't say much here.
Check some.. you know, logs. Like I've said above.
aoakeley
Wed May 18, 2022 4:09 pm
Turn on the PPP logging and post the logs. Those attachments don't show much that can be used for diagnostics.
Users browsing this forum: No registered users and 6 guests
