Gianpy
protected-routerboot not enable in 7.2.3
Sat May 21, 2022 11:40 am
First , sorry for my poor english...
I`ve a problem.
I`ve 10 RBwAPGR-5HacD2HnD connected to a CCR2004-16G-2S+ in LTE to create a small SSTP VPN network. Until a 6.49.6 , the protected routerboard seems working fine, after upgrade to 7.2.3 (upgraded packages,firmware and modem firmware), although I have performed the procedure correctly (i think), the protected routerboard option disappears from winbox and from the CLI i receive the request to press reset button , but when i press , nothing happens and sometimes , i receive warnings from CPU frequency settings. All the RBwAPGR-5HacD2HnD are new and i reset the configuration more times.
What i can do?
Thank you
Gianpy
pe1chl
Re: protected-routerboot not enable in 7.2.3
Sat May 21, 2022 11:43 am
To remove that warning, set CPU frequency to AUTO. Or, ignore the warning.
Otherwise I see no problem. It is normal that it now asks to press the RESET button as confirmation for this dangerous action.
Zacharias
Sat May 21, 2022 12:37 pm
Exactly, it was added on ROS v 6.49.1
*) routerboot - enabling "protected-routerboot" feature requires a press of a button;
https://mikrotik.com/download/changelogs
Gianpy
Tue May 24, 2022 11:31 am
thank you for reply,
yes,this it`s true.
But, in 7.2.3, if i press the reset button, nothing happens, the warning remain and after 60 second disapper and the protect routerboard is`t enable.
pe1chl
Tue May 24, 2022 12:06 pm
Maybe it is a bug? I do not use that feature, and I am not willing to experiment with it either.
The best thing is to make a ticket in the support system https://help.mikrotik.com/servicedesk providing exact details and no unrelated fluff.
Gianpy
Sat May 28, 2022 7:16 pm
Placed a ticked for a bug.
Thank you
Users browsing this forum: winap and 0 guests
