volkirik
BUG REPORT: queue-tree CLI causes hangs and freeze
Sun Jun 12, 2022 9:04 pm
hello there
we use queue-tree on pppoe-in interfaces to apply customer limits... we do not limit upload (upstream traffic).
BUG REPORT: queue-tree CLI modify(set cmd), enable, disable causes hangs and freeze on router QUEUE TREE tab.
for example if we modify using CLI;
/queue tree set [find name~"downstream"] burst-threshold=0 burst-time=0 burst-limit=0 max-limit=3M queue=default-small
the changes are not applied immediately.
for example if we disable queue tree rules;
/queue tree set [find] disabled=yes
they are disabled. but if we re-enable using disabled=no; they stay disabled. reentering command seems to do the trict but we will use scripts soon.
hope this can be fixed ASAP because we do not want scripts to cause any problem or changes stay un-applied.
thanks and regards...
note: already reported to MT support
volkirik
Re: BUG REPORT: queue-tree CLI causes hangs and freeze
Tue Jun 14, 2022 7:59 pm
CLI does not hang. sorry for typo
Winbox Queue Tree window hangs (becomes empty)
thanks and regards
Users browsing this forum: No registered users and 4 guests
