zleppy
7.4beta4 Testing Docker containers
Mon Jun 20, 2022 4:23 pm
I was wondering does anyone know if you can mount a config file in a docker container.
like this
-v /path/to/config.yml:/app/config.yml
i tried this
/container/mounts/add name=config src=disk1/path/to/config.yml dst=/app/config.yml
but the container can't see the file and/or load it.
Is this not possible currently?
antonsb
Re: 7.4beta4 Testing Docker containers
Mon Jun 20, 2022 4:28 pm
have you added this mount entry to container as well?
/container set 0 mounts=config
Please use main container thread for questions regarding containers.
viewtopic.php?t=178342
DeviceLocksmith
Wed Jun 22, 2022 2:02 am
Here is a working example of a mount:
add name=containers
add bridge=containers interface=unifi-controller
/interface veth
add address=192.168.102.2/25 gateway=192.168.102.1 name=unifi-controller
add address=192.168.102.1/25 interface=containers network=192.168.102.0
/container mounts
add dst=/config name=unifi-controller_config src=/disk1/containers/unifi-controller/config
/container
add file=disk1/unifi-controller.tar hostname=unifi interface=unifi-controller logging=yes mounts=unifi-controller_config root-dir=disk1/containers/unifi-controller workdir=/usr/lib/unifi
start 0
zleppy
Fri Jun 24, 2022 11:54 pm
yeh im not trying to import a container *tar.gz tarball.
Im trying to mount in a custom config file into the docker img. So far i cant find a way to do it.
skipping network config and repo part...
/container/mounts/add name=blocky_config src=disk1/containers/blocky001/config.yml dst=/app/
/container add hostname=blocky001 interface=veth1 logging=yes mounts=blocky_config root-dir=disk1/containers/blocky remote-image=spx01/blocky:latest
This should show the config file at /app inside the container but all i can find in the log is that the it cant find it.
devinganger
Mon Jul 04, 2022 7:11 am
From my (very limited) experience, the mounts point to directories on your RoS filesystem. The contents of those directories are not seen.
For example:
[admin@MYROSDEVICE] /container/mounts> print
 0 name="pihole-etc" src="/disk3/docker/pihole/mount/etc" dst="/etc/pihole"
 1 name="pihole-etc-dnsmasq.d" src="/disk3/docker/pihole/mount/etc-dnsmasq.d" dst="/etc/dnsmasq.d"
[admin@MYROSDEVICE] /file> print
Columns: NAME, TYPE, SIZE, CREATION-TIME
 #  NAME                      TYPE             SIZE      CREATION-TIME
 1  disk3/docker              directory                  jun/29/2022 15:20:47
 2  disk3/docker/pihole       directory                  jun/29/2022 15:20:47
 3  disk3/docker/pihole/root  container store            jun/29/2022 15:22:17
Even though the mounts point to directories, not individual files, and you don't see the full target directory, the configuration files for pihole and dnsmasq.d are being persisted across start/stop of the container.
Users browsing this forum: Google [Bot] and 4 guests
