arm920t
Couldn't remove NAT Rule ... notpermitted
Tue Aug 02, 2022 5:49 pm
ros 7.4 show "couldn't remove NAT Rule ... notpermitted "when removing upnp nat.What is the soluation?
rextended
Re: Couldn't remove NAT Rule ... notpermitted
Tue Aug 02, 2022 5:53 pm
Disable and re-enable upnp, or tell to programs you use to release the rule, or set it to do not lock a port with upnp.
arm920t
Tue Aug 02, 2022 6:15 pm
Thanks for the reply.But disable upnp delete all the dynamic nat rule.
rextended
Tue Aug 02, 2022 6:41 pm
Yes, all dynamic rules opened from UPNP (not generically "any" dynamic rules)
Instruct the application to close the ports, and the rule is deleted.
Users browsing this forum: No registered users and 1 guest
