danielcs
dude-install.sh - The Dude Client for Mikrotik installer on Linux.
Tue Aug 30, 2022 5:19 am
The main purpose of this tool is to automate the installation of The Dude Client in Linux.
Current support for Debian, Ubuntu, Linux Lite & Linux Mint.
✅ Support:
  • Debian 11 (Bullseye)
  • Debian 10 (Buster)
  • Ubuntu 22.04 (Jammy Jellyfish)
  • Ubuntu 21.10 (Impish Indri)
  • Ubuntu 20.04 (Focal Fossa)
  • Ubuntu 18.04 (Bionic Beaver)
  • Linux Lite 6.0 (Based on Ubuntu 22.04)
  • Linux Mint 21 (Vanessa)
  • Linux Mint 20 (Ulyana)
  • Linux Mint 19 (Tara)
⬇️ Installing:
git clone https://github.com/danielcshn/dude-install.sh.git
cd dude-install.sh
chmod +x dude-install.sh
./dude-install.sh
🛠️ Usage:
  • Select the Check Dependencies option to verify that you meet the required system and dependencies.
  • Select the Install The Dude Client option. Then indicate the version to install. Example: 7.1 or 7.5beta11.
  • Select the Launch The Dude Client option to start the program.
🧪 Tested distros:
Image Image Image Image Image
💾 Project Link:
Reason: Link -> Linux
rextended
Re: dude-install.sh - The Dude Client for Mikrotik installer on Linux.
Tue Aug 30, 2022 10:07 am
"intall"?
✅ Support:
Nice, you report also what is not tested... it is so because it is the MikroTik forum?
danielcs
Wed Aug 31, 2022 5:02 am
This is a humble contribution to the community.
Supported is not the same as tested, it's detailed for a reason.
This is an open source project, if you want you can contribute, otherwise do not despise the work of another.
rextended
Wed Aug 31, 2022 10:19 am
I haven't written a word of contempt, I just point out things.
For example, "intall"... with find and replace it's a snap to fix it...
This should make you understand that I have looked at it, that if I thought it was useless, I would not have bothered to read it or report it.
mducharme
Trainer
Trainer
Fri Sep 02, 2022 2:06 am
You also have "Link Mint" instead of "Linux Mint"
rextended
Fri Sep 02, 2022 12:01 pm
(fixed)
Larsa
Fri Sep 02, 2022 12:57 pm
@rextended: Hey dude, please consider this is a volventerly open source project. I really wish you were at least as thorough regarding MT's professionell release management as well ! ;-)
rextended
Fri Sep 02, 2022 2:04 pm
@Larsa, read first the other posts, like #4.
But...
You should reread what I wrote at the end of #2 in a different light...
If you guess the right light, everything will be much clearer...
andrejpodzimek
Mon May 01, 2023 10:50 pm
[DudeInstaller] Please run the tool as root or use: sudo ./dude-install.sh
Ain’t gonna happen. :? Are there any other options? This↑ is reported already at step 1, “Check Dependencies”. No root needed, no root granted.
jult
Mon Aug 07, 2023 6:46 pm
Dude, you may want to show some screenshots/printscreens. It's not even clear if this requires a desktop or if it's shell-based. Or make a video showing us what it looks like. This is such a weird self-involved promo-page. You seem to forget that there are humans out there who see this not even knowing what the Dude is. Please, take the effort for 5 minutes to describe what you've created, for crying out loud.
Amm0
Mon Aug 07, 2023 7:18 pm
That's a bit harsh. If you don't know what the Dude is or need Dude client run on a normal Linux desktop ... I think it's obvious the shell script might not be of much use ;).
For background, the Dude client* is 32-bit Windows app. While wine allows Windows apps to run on linux, modern Linux do not include 32-bit architecture libraries that wine needs to run 32-bit Windows applications, via "wine" emulator package. It's 32-bit part that necessitates a rather complex, and disto specific, process to actually get the Dude running on Linux.
Since winbox does have a 64-bit executable, the steps to install wine are more streamlined. But the Dude client does not have a 64-bit version, thus a rather complicate road to get running on Linux – why OP created a script since one thing wrong and wine/Dude wouldn't run ;)
And to the post about "root" — get the concern — but it not that hard to read the script and perform same steps by hand. But it the really the pre-req packages that require root to be install in my quick read (e.g. 32-bit architecture ones, among others).
* FWIW, the Dude server runs on a Mikrotik with extra-package installed – so that has nothing to do with this, other than without a server, a client be useless ;).
Users browsing this forum: No registered users and 0 guests
