dpal80
Images on dude are deleted randomly
Wed Sep 07, 2022 1:16 pm
We are using dude since 2015 to create maps and submaps of our guests.
We creeate always new devices and upload photos of the devices, but the Image Files are randomly deleted.
Any idea on how to solve this problem?
This is a problem we have from the first day of usage.
DUDE is installed on a RB4100 Dude Edition, but it was the same thing when it was installed on a virtual machine.
rextended
Re: Images on dude are deleted randomly
Wed Sep 07, 2022 1:50 pm
Non mettere le immagini nelle cartelle predefinite che crea The Dude automaticamente quando si avvia.
Qualsiasi cosa messa in .../dude/files/default/... viene cancellata.
Devi fare una sottocartella, per esempio se The Dude è installato in disk1/dude/ devi fare la cartella disk1/dude/files/images e piazzare le immagini lì.
Saluti a VT da GR... ;)
[EN]
Do not put images in the default folders that The Dude creates automatically when it starts up.
Anything placed in .../dude/files/default/... is deleted.
You have to make a subfolder, for example if The Dude is installed in disk1/dude/ you have to create the folder disk1/dude/files/images and place the images there.
Greetings to VT from GR... ;)
dpal80
Sun Sep 11, 2022 8:51 pm
Grazie per la dritta.
Se non ricordo male però le immagini sono già in una sottocartella.
Domani controllo e ti dico.
Anche se il problema non è che le cancella tutte.... ma ne cancella solo alcune... senza una logica apparente.
Possibile si tratti dello stesso problema?
Grazie mille.
Un saluto a tutta GR!
Users browsing this forum: No registered users and 3 guests
